16th January 2017, 06:53 | #41 | Link |
I may not have tested that very thoroughly since I had to start demuxing audio via tsmuxer instead of dgi for a couple reasons (not least of which being that d2vsource is slower than l-smash source). There definitely isn't anything in the script to override that value though.
30th March 2017, 19:54 | #42 | Link | |
both:
"G:\Hybrid\vsfilters\SourceFilter\d2vSource\d2vwitch.exe" --output "H:\Temp\552bf3799f50de80782be5bd932be83e_491.d2v" "F:\TESTCL~1\DVDs\ELEPHA~1\VIDEO_TS" Code:
"G:\Hybrid\vsfilters\SourceFilter\d2vSource\d2vwitch.exe" --output "H:\Temp\552bf3799f50de80782be5bd932be83e_491.d2v" "F:\TestClips&Co\DVDs\ElephantsDream\VIDEO_TS" Quote:
Also starting the d2vwitch gui and pressing the 'Browse' or 'Add files' button causes a freeze here. Am I missing something? (d2vwitch.exe is alone in a folder, no other files there) This didn't happen last time I used d2vwitch, but I got no clue what could have changed. (aside from me updating Vapoursynth) disabling firewall and malwarebytes didn't help either,... Last edited by Selur; 30th March 2017 at 20:07. |
30th March 2017, 20:44 | #43 | Link | |
unsigned int
I don't know what the freeze is about. It freezes when you browse to that folder, not when you select the files and click "Open" or whatever, right?
Buy me a "coffee" and/or hire me to write code! |
31st March 2017, 03:42 | #44 | Link | |
It freezes directly when I press the 'Browse' or 'Add files' button. I don't get any file dialog.
31st March 2017, 14:10 | #45 | Link | |
unsigned int
Does this one work?
15th April 2017, 21:58 | #47 | Link |
unsigned int
H264
A test version that might become v3:
http://savedonthe.net/download/1834/...264-win32.html http://savedonthe.net/download/1835/...264-win64.html The main attraction is H264 support in transport streams and elementary streams. Test it, maybe, and let me know how it goes. If you want to compile it: https://github.com/dubhater/D2VWitch/tree/h264 https://github.com/dubhater/d2vsource
16th April 2017, 12:50 | #49 | Link | ||
Clip has 55828 frames. Hashing: 99% Clip hashed. Requested frame 1, got new frame with hash 92bec1c50ed47b951b3c61c1a07845aa. Previous requests: 31256 18668 19099 7457 18422 40536 25822 22063 12993 15999 1 Requested frame 3, got new frame with hash 68dbd285aabc4411091783b4e1528ae4. Previous requests: 48429 20110 51397 36508 49910 32760 21437 24375 7417 1782 3 Requested frame 2, got new frame with hash d81b72522a628d3c28daccbe3f525967. Previous requests: 36580 18291 10236 40548 16399 19554 42655 40192 10424 50369 2 Test complete. It's an interlaced h264 transport stream. Both lsmash and ffms2 are completely broken on that one. |
16th April 2017, 14:00 | #50 | Link |
Got a sample d2vwitch.h264 which the filter can't handle.
Works fine when using LWLibavSource, ffms2 fails on this source too. Found another one I also uploaded (Trailer 3D_MVC). Last edited by Selur; 16th April 2017 at 15:16. Reason: found another file. |
16th April 2017, 16:48 | #52 | Link |
Had to ask.
May be an option to load multiple files? That would also help with DVD handling; I normally know the vobs/m2ts files, which belong to a specific playlist, and their order and it would help if they could be all indexed and opened in one go. |
16th April 2017, 17:03 | #53 | Link |
unsigned int
You can do that with DVDs since v1. Technically you can do it with blurays too, but I just tried and random access doesn't work right. You get the wrong frames.
16th April 2017, 17:08 | #54 | Link |
Lol, you are right about the DVD thing, I even used that a few times and totally forgot about it. Problem with m2ts files is that in a playlist the numbering doesn't have to follow a specific order so autoloading based on the file name would be a bad thing.
16th April 2017, 17:42 | #55 | Link | |
unsigned int
New d2vsource decodes 9 and 10 bit h264 too (that d2vwitch.h264 mentioned above). New D2V Witch has two very small fixes. Git history was edited, sorry. http://savedonthe.net/download/1836/...264-win64.html http://savedonthe.net/download/1837/...264-win32.html
16th April 2017, 18:20 | #57 | Link |
unsigned int
$ ffplay /tmp/Trailer\ 3D_MVC.mts <stuff> [h264 @ 0x7fa370089a40] sps_id 1 out of range Failed to open file '/tmp/Trailer 3D_MVC.mts' or configure filtergraph ffmpeg 3.3 doesn't decode it either.
Buy me a "coffee" and/or hire me to write code! Last edited by jackoneill; 16th April 2017 at 18:52. |
16th April 2017, 20:29 | #59 | Link | |
unsigned int
http://savedonthe.net/download/1838/...264-win32.html http://savedonthe.net/download/1839/...264-win64.html
