Old 2nd March 2006, 22:20   #121  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Originally Posted by tebasuna51
But I think is not necesary, now work like ffdshow, Cyberlink PowerDVD 6, ...
I really want to cover all besweet functionality. Seems like I must write some custom callback to realize additional DRC modes. Can You help me to write it (i need math and valid coefficients)
Talking about DRC in DTS, maybe it's possible to use same function in it? Does You have DTS samples for testing (i have not)
dimzon is offline   Reply With Quote
Old 3rd March 2006, 12:06   #122  |  Link
dimzon
dimzon's Avatar
http://forum.doom9.org/showthread.ph...573#post793573
Old 3rd March 2006, 13:08   #123  |  Link
tebasuna51
tebasuna51's Avatar
Nice. The most important for me is accept any kind of wav input and split in mono waves (to send after to good ac3 encoders).
Maybe also cover WaveWizard functionality accepting wav > 4GB and WAV_FORMAT_EXTENSIBLE headers.
I think you need not easy algorithms. Just I learn a few with Compand Sox function and there are involved parameters like attack, dekay, delay, ... and I don't understand very much how work. See this image
I think is not a priority, with your new NicAudio.dll is enough for MeGUI.
About NicAc3Source I detect a bug decoding 5.0 (without LFE) ac3 streams. Make a wav 6 channels (with LFE empty) but wrong mapping C_SL_FR_FL_SR_LFE, need Getchannels(4,3,1,6,2,5).
I have a swedish test channel but decoded with NicAudio, foobar, Tranzcode or ffdshow (with errorrs) is always the same. Maybe don't have DRC (optional in DTS, like in Ac3).
I can't test DTS because I don't own a DTS encoder. Maybe other user can test your new NicAudio.dll.
Old 3rd March 2006, 14:23   #124  |  Link
tebasuna51
tebasuna51's Avatar
I still have problems with BeHappy new version.
Using like input this Test1.avs (3 stereo wav's to wav 6 channels)
flfr = WavSource("g:\Test_FL_FR1.wav")
fl = GetChannel(flfr, 1)
fr = GetChannel(flfr, 2)
clfe = WavSource("g:\Test_C_LFE1.wav")
c = GetChannel(clfe, 1)
lfe = GetChannel(clfe, 2)
slsr = WavSource("g:\Test_SL_SR1.wav")
sl = GetChannel(slsr, 1)
sr = GetChannel(slsr, 2)
MergeChannels(fl, fr, c, lfe, sl, sr)
With BeHappy v0.1.0.30756 (20051229) work fine, but with BeHappy v0.1.0.28107 (20060206) don't work, I get:
Starting job Test1.avs->Test.wav
Found Audio Stream
Channels=6, BitsPerSample=16, SampleRate=48000Hz
Writing RIFF header to encoder's StdIn
Writing PCM data to encoder's StdIn
Error: BeHappy.AviSynthException: AudioStreamSource
   at BeHappy.Encoder.encode()
Please, if you need make a new BeHappy version for include NicAudio options, and is easy to modify:
- Don't include EnsureVBRMP3Sync(), or make it optional with a checkbox in Tweak section.
- Don't include the two AudioDubEx() if the checkbox Split is not marked.
- Accept negative values in Amplify.
Old 3rd March 2006, 15:16   #125  |  Link
dimzon
dimzon's Avatar
Isn't possible to accept such files just using DirectShowSource instead WavSource?
I'm planning to perform some reverse-engineering of Dolby AC3 encoder Dll's in order to write my own CLI frontend for it (acceptable to encode 6ch WAV directly) but I plan to do it much more later...
I'm just talking about standart DRC in addition to normal: Neavy/Normal/Light/Inverse
Seems like I found bug:
	case A52_3F2R:
		LFE      = Flags && A52_LFE;
		DecFlags = A52_3F2R;
		if (LFE)
			DecFlags |= A52_LFE;
		ChannelCount = 6;
		break;
In this case LFE variable is always = true.
Replaced to
LFE  = 0!=(Flags &A52_LFE);
Same for DTS, try this binary: http://www.mytempdir.com/489796
I have found same problem just 3 days ago. Unfortunally I can't say nothing about it except it's internal AviSynth problem (exeption is thrown by AviSynth) and it will occured sometimes (not every time). Try to open yor avs script using Import, not WavSource...
All Your suggestions will be implemented in next build BUT I'm not planning to release new BeHappy version during at least next 2 weeks, sorry...
Old 3rd March 2006, 16:47   #126  |  Link
dimzon
dimzon's Avatar
Sorry, I don't know DTS format.
The DTS Coherent Acoustics standard (ETSI 102 114 v1.2.1), as published by the ETSI, is available here (search for DTS Coherent Acoustics)
Old 5th March 2006, 05:00   #127  |  Link
tebasuna51
tebasuna51's Avatar
The DTS Coherent Acoustics standard (ETSI 102 114 v1.2.1), as published by the ETSI, is available here[/COLOR][/B])
After read this I check my test.dts and is encoded without DRC.
Then if anybody want do the test before a new BeHappy version support this issue, can create a new file in BeHappy folder:
NicAudioDRC.extension
<?xml version="1.0"?>
<BeHappy.Extension xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://workspaces.gotdotnet.com/behappy">
  <AudioSource Name="NicAc3SourceDRC" UniqueID="79c27720-ab72-11da-a746-0800200c9a66">
    <Script>NicAc3Source("{0}", DRC=1)</Script>
    <SupportedFileExtension>ac3</SupportedFileExtension>
  </AudioSource>
  <AudioSource Name="NicDtsSourceDRC" UniqueID="880150e0-ab72-11da-a746-0800200c9a66">
    <Script>NicDtsSource("{0}", DRC=1)</Script>
    <SupportedFileExtension>dts</SupportedFileExtension>
  </AudioSource>
</BeHappy.Extension>
With this there are two new input source methods:
NicAc3SourceDRC
NicDtsSourceDRC
The ac3 method work fine, and the bug with ac3 5.0 is also corrected.
Yes, configuring ffdshow Audio Decoder -> Codecs -> WAV -> All supported, I can open wav 32bit float, WAVE_FORMAT_EXTENSIBLE, ... (still not tested > 4 GB).
Is not a easy way, because I need uncheck other functions used for play and after do the conversion recheck them, but work.
Yes sometimes work. If you think the problem is solved using Import maybe we need a new source method:
AvsSource.extension
  <AudioSource Name="AvsSource" UniqueID="0aa78710-aafd-11da-a746-0800200c9a66">
    <Script>Import("{0}")</Script>
    <SupportedFileExtension>avs</SupportedFileExtension>
  </AudioSource>
and disable .avs like extension for WavSource.
Great notice. We need a good free ac3 encoder better than ffmpeg, ac3enc, ...
But split in mono wavs is also needed for other reasons and I think is really easy to do, don't forget this please.
And at last, but not the last, thanks for accept my suggestions for new BeHappy release.
Old 5th March 2006, 10:31   #128  |  Link
dimzon
dimzon's Avatar
@tebasuna51
does you tested new binary (5.0 issue)?
Old 5th March 2006, 10:58   #129  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
Without having read the whole thread: is nicaudio capable of putting out more than 16bit audio sampling precision?
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 5th March 2006, 11:22   #130  |  Link
tebasuna51
tebasuna51's Avatar
Yes:
"The ac3 method work fine, and the bug with ac3 5.0 is also corrected."
Old 5th March 2006, 11:38   #131  |  Link
tebasuna51
tebasuna51's Avatar
Ac3 is a old codec and, AFAIK, internal precision is not greater than 16 bit, you can convert the output to any precision for further conversions.
Old 5th March 2006, 12:29   #132  |  Link
scharfis_brain
brainless
internal precision 'may' be only 16bit, but due to the internal dynamic range control of AC3 (in German it is "Hüllkurve") you won't loose precision in silent scenes when decoding to 24bit.
Also you may decode every psycoacoustic coding to arbitary bit depths because of its frequency nature. Of couse this precision is faked a bit, but it is much better than going from 16bit to 24 (or higher) bit after decoding.
Old 5th March 2006, 14:08   #133  |  Link
dimzon
dimzon's Avatar
Yes:
Oh sorry, thanx a lot for testing. Does it mean I can do new stable release of NicAudio?
Talking about AC3 compression - I have not plans to do it right now but can you tell me wich AC3 encoder does You prefer?
Old 5th March 2006, 14:44   #134  |  Link
tebasuna51
tebasuna51's Avatar
Yes for me. Maybe any dts test, but seems dts_dynrng work like the equivalent ac3.
About free encoders you can see: http://forum.doom9.org/showthread.ph...503#post759503
- DarkAvenger (HeadAC3he) seems solve the low volume issue (50%) in their ac3enc.dll.
- DRC info must be generated in ac3 stream.
- Others parameters: DialNorm, MixLevels, ... must be user defined.
With non-free encoders, I only test the old and slow Sonic Foundry SoftEncode.
Old 7th March 2006, 14:45   #135  |  Link
dimzon
dimzon's Avatar
@tebasuna51
FYI
fresh NicAudio http://forum.doom9.org/showthread.php?t=108112
fresh BassAudio http://forum.doom9.org/showthread.php?t=108254
Can You play with / test BassAudio ?
Old 7th March 2006, 15:12   #136  |  Link
NorthPole
@tebasuna51
I read your post in this thread http://forum.doom9.org/showthread.ph...503#post759503
Thanks for the work...very interesting. What program did you use to test the ac3 output levels?
Did you use wavewizard with the dark avenger ac3enc.dll or were you using the headAC3he frontend?
NorthPole is offline   Reply With Quote
Old 7th March 2006, 18:54   #137  |  Link
tebasuna51
tebasuna51's Avatar
We need decode to wav the ac3 stream with BeHappy-NicAudio or BeSweet-Azid without DRC, ota-normalize, downmix,...
After any wav editor Audacity, Goldwave, Audition...
The HeadAC3he frontend is needed because have the Gain parameter. The ac3enc.dll from HeadAC3he don't work with WaveWizard, but the used is supplied for Dark Avenger to Johnman.
AFAIK the problem is how send this Gain parameter to ac3enc.dll, because is applied internally.
Old 8th March 2006, 01:19   #138  |  Link
NorthPole
@tebasuna51
Thanks for the reply. Sorry about the off thread topic. I have been doing the same as you. Decoding to wave and checking the levels with cooledit. I have been using ffmpeg from http://celticdruid.no-ip.com/xvid/
@Dimzon or maybe @Dayvon
The new logo looks good.
I'll try the bassAudio decoder and let you know if I have any problems.
Old 10th March 2006, 03:16   #139  |  Link
tebasuna51
tebasuna51's Avatar
BASSAUDIO TEST
Seems work ok with mp2, mp3, ogg, wma and stereo aac (LC, HE and PS)
Also work with ac3 5.1 (without DRC), 6 channel ogg and wma.
And with wav stereo and multichannel int16, int32, float32 with canonical or WAVE_EXTENSIBLE_FORMAT headers.
Now is not necesary DirectShowSource for wav, wma, ogg or stereo aac files.
PROBLEMS
With ac3 2.0 make a wav 6 channels R_e_e_L_e_e (e=empty channel).
With aac 5.1 sometimes make a wav6 with all channels equal to a distorted Center channel, and sometimes:
Starting job Test6.aac->Test6.wav
Found Audio Stream
Error: System.NullReferenceException: Object reference not set to an instance of an object.
   at BeHappy.AviSynthClip.dimzon_avs_getaframe(IntPtr avs, IntPtr buf, Int64 sampleNo, Int64 sampleCount)
or
   at BeHappy.AviSynthClip.dimzon_avs_destroy(IntPtr& avs)
   at BeHappy.AviSynthClip.System.IDisposable.Dispose()
Old 10th March 2006, 08:33   #140  |  Link
dimzon
dimzon's Avatar
PROBLEMS
With aac 5.1 sometimes make a wav6 with all channels equal to a distorted Center channel...
Hm. Thanx a lot, seems like this is BASS problem
and sometimes
How often does this bug reproducable. Does it only for 5.1 AAC decoding via bassAudio?
behappy
