12th May 2012, 10:31 | #83 | Link |
Well, preset DVD MDegrain2_SVP mask4 DLS
#RemoveGrainSSE2.dll #RepairSSE2.dll #mvtools2SVP.dll #svpflow1.dll #svpflow2.dll #fft3dgpu.dll #WarpSharp.dll #mt_masktools-26.dll #average.dll #AddGrainC.dll #GradFun2DB.dll #VagueDenoiser.dll #flash3kyuu_deband.dll #Gradfun2dbmod.avs #Ylevels.avs #LimitedSharpenFaster Mod.avs setmemorymax(768) # ColorYUV(gain_y=0,cont_y=0,cont_u=0,cont_v=0,gain_v=0,gain_u=-0,off_y=0,off_u=-0,off_v=-0) source = last preNR = source.fft3dgpu(wintype=1,degrid=1,bw=16,bh=16,ow=8,oh=8,bt=4,sigma=1.0,sigma2=1.2,sigma3=2.0,sigma4=1.0,plane=4).GradFun2DB(1.01) setmtmode(2) sup1 = preNR.SVSuper( "{ gpu:0, pel:2, scale:{up:2, down:2} }") search_params = "gpu:0, vectors:3, block:{w:16,overlap:3}" v21 = sup1.SVAnalyse("{"+search_params+"}") v22 = sup1.SVAnalyse("{"+search_params+",special:{delta:2}}") bv22 = v22.SVConvert(isb=true) bv21 = v21.SVConvert(isb=true) fv21 = v21.SVConvert(isb=false) fv22 = v22.SVConvert(isb=false) mask1 = source.mmask(bv22, ml=100, kind = 1, Ysc = 255, gamma=0.999) mask2 = source.mmask(bv21, ml=100, kind = 1, Ysc = 255, gamma=0.999) mask3 = source.mmask(fv21, ml=100, kind = 1, Ysc = 255, gamma=0.999) mask4 = source.mmask(fv22, ml=100, kind = 1, Ysc = 255, gamma=0.999) maskb = mt_lutxy(mask1,mask2,"x 255 < y 255 < x y + 2 / x ? y ?") maskf = mt_lutxy(mask3,mask4,"x 255 < y 255 < x y + 2 / x ? y ?") tmask = mt_lutxy(maskb,maskf,"x 255 < y 255 < x y + 2 / x ? y ? 32 - 255 * 223 /")# комбинированная маска оценки движения SAD source2 = mt_merge(source,preNR,tmask,Y=3,U=3,V=3) sup2 = source.msuper(pel=2, levels=1, sharp=2) den = source2.MDegrain2(sup2,bv21,fv21,bv22,fv22,thSAD=300,thSCD1=400,thSCD2=102) Diff1 = mt_makediff(source,den,U=3,V=3) NR = den.VagueDenoiser(method=4, nsteps=8, wavelet=2, Wiener=true, auxclip=preNR, percent=95, chromaT=0.8, wratio=0.75, threshold=0.4) Diff2 = mt_makediff(source,NR,U=3,V=3) lutxy = mt_lutxy(Diff1,Diff2,"x 128 - abs y 128 - abs < x y ?") smB = source.mt_makediff(lutxy,U=3,V=3) # MASKING mE = mt_edge(smB,"prewitt",0,255,0,0,V=1,U=1).mt_lut(expr="x 1.8 ^",U=1,V=1).removegrain(4,-1).mt_inflate(U=1,V=1) mL = mt_logic(tmask.invert(),mE,"min",U=1,V=1).removegrain(20,-1) mF = mt_logic(tmask,mE,"max",U=1,V=1).removegrain(20,-1) # SHARPENING b1c = source.MCompensate(sup2, bv21) f1c = source.MCompensate(sup2, fv21) Sclp = smB.LSFmod(defaults="slow", preblur="ON", strength=100) # Sclp = ContraHD(smB,source,b1c,f1c,0) Tmax = source.mt_logic(f1c,"max",U=1,V=1).mt_logic(b1c,"max",U=1,V=1) Tmin = source.mt_logic(f1c,"min",U=1,V=1).mt_logic(b1c,"min",U=1,V=1) shrp = Sclp.mt_clamp(Tmax, Tmin, 2, 2, U=1, V=1) sL = mt_merge(smB,shrp,mL,U=2,V=2) # DEBANDING # GFc = sL.f3kdb(sample_mode=2,dynamic_grain=false,keep_tv_range=false,dither_algo=3,y=64,cb=64,cr=64,grainY=48,grainC=48) GFc = sL.GradFun2DBmod(thr=1.21,thrC=1.5,mode=2,str=0.6,strC=0.0,temp=50,adapt=64) Frs = mt_merge(GFc,sL,mF,luma=true,U=3,V=3) Frs#.mergechroma(den) YlevelsS(0,1.0,255,0,255,false) # -- visualisations -- # stackvertical(source,last) # interleave(source,last) Last edited by Tempter57; 12th May 2012 at 10:50. |
13th May 2012, 09:24 | #84 | Link |
hey their, im currently using this script
super = MSuper(pel=2,chroma=false) backward_vec1 = super.MAnalyse(isb = true, blksize=16, delta = 1, overlap=8,chroma=false,search=5,searchparam=4,temporal=true) forward_vec1 = super.MAnalyse(isb = false, blksize=16, delta = 1, overlap=8,chroma=false,search=5,searchparam=4,temporal=true) MDegrain1(super, backward_vec1,forward_vec1,thSAD=20,plane=0) i use it to denoise and remove grain generated from sharpening, it works great (the best iv used so far) it keeps the detail of the picture sharp and still theirs no noise or blocks generated.. my sources are bluray content.. i sometimes get slight noise and blocks (depending on the compression) i was wondering if you could translate it or offer a script better with this SVP and il test it out and report back.. thanks ... |
14th May 2012, 11:08 | #85 | Link |
Pig on the wing
One small question: is there any harm in using a super clip created by MSuper instead of SVSuper when the vectors are converted to MVTools2 format after SVAnalyse?
14th May 2012, 12:59 | #86 | Link |
Boulder
There's no difference. bmb Code:
super = MSuper(pel=2,hpad=0,vpad=0) vec = super.SVAnalyse("{block:{overlap:3}}") backward_vec1 = vec.SVConvert(isb=true) forward_vec1 = vec.SVConvert(isb=false) MDegrain1(super, backward_vec1,forward_vec1,thSAD=20,plane=0) Last edited by chainik_svp; 14th May 2012 at 13:05. |
5th June 2012, 04:10 | #87 | Link |
Pig on the wing
I tried to test your modded Avisynth build, but avs2pipemod keeps on crashing during launch so I cannot pipe the output to 64-bit x264. Opening the script in VDub has no issues.
5th June 2012, 09:15 | #88 | Link |
Boulder
tried version from here, works for me (without x264): "avs2pipemod.exe -rawvideo test.avs > out"
SVPflow motion interpolation |
5th June 2012, 09:35 | #89 | Link |
Pig on the wing
Hm, it's possible that I have an outdated piping client (although I have had no problems using Avisynth 2.5.8 or 2.6 earlier). I'll get the latest one and retry.
5th June 2012, 09:47 | #90 | Link | |
I currently use QTGMC for my motion blur needs but MVTools does produce weird artefacts *, I'd be curious to see how SVPflow performs in comparison * these aren't exactly artefacts in my case but more the typical MvTools "morphing effect" between scene changes Last edited by Boulotaur2024; 5th June 2012 at 18:05. |
5th June 2012, 18:15 | #92 | Link |
Pig on the wing
Yep, the latest version seems to work. Now some testing and if results are what I'd like them to be, I think I'm going to ask SEt if he could take a look at the modifications to put them in his 2.6 build
5th June 2012, 20:42 | #93 | Link |
The main idea is to limit each cache size (in frames), opposite to Avisynth approach when all caches uses one common "frames" pool somehow limited with SetMemoryMax value. This can easily lead to cache misses in general case BUT as far as I know that SVP's script is linear frame-by-frame only - it works.
So may be it's not a good idea to include such behavior in official Avisynth, but may be as an additional argument to SetMTMode()...
6th June 2012, 16:43 | #94 | Link |
Pig on the wing
I have some results. In a regular case with "DGSource-Downsize to 720p-MVTools based denoise", your and SEt's Avisynth build are pretty much the same what comes to speed. Your build uses something like 200-250M less memory (svp_cache_fwd=4 vs SetMemoryMax(512)).
In an "MPEG2Source-TFM-TDecimate-MVTools based denoise", SEt's build is slightly faster. The amount is small, 1-2%, and the difference would be even smaller if x264 was set to a slower preset (I used ultrafast to remove the encoding bottleneck). The difference in memory usage is the same as in the first example However, a script with SRestore doesn't seem to work with your build as it crashes upon script loading in VDub and avs2pipemod. I'm not that surprised since it's a mean piece of work and if I'm not entirely mistaken, multithreading is a bit of a no-no although I don't remember anybody really confirming that. But doesn't the same apply to TDecimate as well?
6th June 2012, 18:04 | #95 | Link |
720p is too easy and 250M is nothing I'm talking about situations when official Avisynth can't work at all. For example "canonical" MVTools-based interpolation script can easily run out of memory with 1080p and pel=2 in MSuper regardless of SetMemoryMax value.
SVPflow motion interpolation Last edited by chainik_svp; 6th June 2012 at 18:09. |
6th June 2012, 18:05 | #96 | Link |
Pig on the wing
Hehe, that's true. I was afraid of trying to QTGMC 1080i as the tests would have a taken a veeery long time
6th June 2012, 18:46 | #97 | Link |
4k ?
6th June 2012, 19:00 | #98 | Link |
Pig on the wing
Yeah ----- when the day comes that I can buy a reasonably priced TV that supports the format
7th June 2012, 06:39 | #99 | Link |
interlace this!
for the two people interested:
function frcblur( clip c, int "num", int "den", float "angle", int "samples" ) { num = default(num,24000) den = default(den,1001) samples = default(samples,7) # anything more than 11 is way overkill. internally this number is doubled by default. angle = default(angle,0) # 0 disables motion blur. 180 is standard cine camera. multiplier = angle==0? 1 : round( samples/(angle/360.) ) parmstring = "{rate:{num:" + string( multiplier * num ) + ",den:" + string(den) + ",abs:true},algo:21,cubic:1}}" c spr = svsuper("{pel:2,gpu:1}") vec = svanalyse(spr,"""{block:{w:32,h:32},refine:[{thsad:200}]} """) sorathread() svsmoothfps(spr,vec,parmstring, url="www.svp-team.com") sorathread() angle==0? last : temporalsoften(multiplier/2 -1,255,255,255) angle==0? last : selectevery(multiplier,0) } here's a script example, with stabilization thrown in: Code:
QTinput("x:\things\MVI_1402.MOV",audio=2) assumetff() assumetff() converttoyv12() sorathread() mdata = DePanEstimate(last) DePanStabilize(last, data=mdata,cutoff=0.333,initzoom=1.1,addzoom=true,zoommax=1.5,rotmax=10.,tzoom=3.0,pixaspect=1.0,prev=3,next=3) sorathread() frcblur(num=25,den=1,angle=180) i'm using QTinput because of the luma levels issue with ffms2.
sucking the life out of your videos since 2004 |
7th June 2012, 14:01 | #100 | Link |
Thanks Mug Funky! The result looks very nice.
For Avisynth MT I had to add the mt=x argument to svsmoothfps. Sorry for being a little off topic but what are the issues with FFMS2 and luma? Last edited by Reel.Deel; 7th June 2012 at 14:24. |
frame doubling, frame rate conversion, mvtools, opencl |
