Old 28th April 2012, 21:12   #61  |  Link
Anacletus
Anacletus's Avatar
Hi chainik_svp,
would you mind explaining how to translate this standard MDegrain2 call in order to take advantage of your plugins?
AviSource("something.avi")
super = MSuper(pel=2, sharp=1)
backward_vec2 = MAnalyse(super, isb = true, delta = 2, overlap=4)
backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4)
forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4)
forward_vec2 = MAnalyse(super, isb = false, delta = 2, overlap=4)
MDegrain2(super, backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400)
If i understand correctly i should use something like this for MDegrain1?
super = SVSuper("{pel:2, gpu:1}")
vectors = SVAnalyse(super, "{gpu:1,block:{w:8,h:8,overlap:2}}")
forward_mv = SVConvert(vectors, false)
backward_mv = SVConvert(vectors, true)
super_mv = MSuper(pel=1, hpad=0, vpad=0)
MDegrain1(super_mv, backward_mv, forward_mv, thSAD=400)
I'm missing if there the possibility to use more motion vectors as for MDegrain2 or if this is unnecessary with SVP plugins..
Can you please point me to the right direction?
Thanks
Anacletus is offline   Reply With Quote
Old 28th April 2012, 22:07   #62  |  Link
chainik_svp
I think -Vit- already gave a clue how to emulate "delta=2".
Again, I'm not trying to completely replace MVTools, so MDegrain and other things are not in my interests now
But it's not a big deal to add "delta" param so if someone thinks it'll be useful I could do that.
chainik_svp is offline   Reply With Quote
Old 28th April 2012, 23:40   #63  |  Link
-Vit-
My delta=2 method works fine, but don't try to simplify the fVec2 line, I believe it would be an error:
fVec2 = Interleave(vecs2e.SVConvert( isb=false ), vecs2o.SVConvert( isb=false )) # Correct
fVec2 = Interleave(vecs2e, vecs2o).SVConvert( isb=false )  # Error
That's because SVAnalyse generates forward vectors offset by 1 from MVAnalyse so SVConvert shifts the forward vectors back by one. However, with a delta of 2 they need shifted back by 2, so the SVConvert goes inside the Interleave. May not matter for the bVec3 line, but I suggest just to leave it as is in my original post.
For delta=3 do this:
params_string = "{gpu:0}"  # plus any other SVAnalyse settings
vecs30 = super.SelectEvery(3,0).SVAnalyse( params_string )
vecs31 = super.SelectEvery(3,1).SVAnalyse( params_string )
vecs32 = super.SelectEvery(3,2).SVAnalyse( params_string )
fVec3 = Interleave( vecs30.SVConvert(isb=false), vecs31.SVConvert(isb=false), vecs32.SVConvert(isb=false) )
bVec3 = Interleave( vecs30.SVConvert(isb=true ), vecs31.SVConvert(isb=true ), vecs32.SVConvert(isb=true ) )
Never tested that but it's just the same process.
And here's a function to generate MVTools vectors using SVAnalyse and an arbitrary delta. It requires GScript. I've only tested it a little:
# Use SVAnalyse with a given delta and convert vectors to MVTools format
# Returns a single vector clip containing interleaved forward and backward vectors.
# Example:
#   vec3 = super.SVAnalyseConvert( 3, "{gpu:0, pel:2}" ) # delta=3
#   fVec3 = vec3.SelectEven()
#   bVec3 = vec3.SelectOdd()
function SVAnalyseConvert( clip super, int "delta", string "params_string" )
    delta         = default(delta, 1)
    params_string = default(params_string, "{gpu:0}")
    GScript("""
    if (delta == 1) {
	vecs = super.SVAnalyse( params_string )
        return Interleave( vecs.SVConvert(isb=false), vecs.SVConvert(isb=true) )
    else {
        cf = ""
        cb = ""
        sD = string(delta)
        for (i=0, delta-1) {
            sI = string(i)
            Eval( "vecs"+sD+sI+"=super.SelectEvery("+sD+","+sI+").SVAnalyse( params_string )" )
            cf = cf + "vecs"+sD+sI+".SVConvert(isb=false)"
            cb = cb + "vecs"+sD+sI+".SVConvert(isb=true)"
            if (i != delta-1) {
                cf = cf + ","
                cb = cb + ","
	return Eval( "Interleave(Interleave("+cf+"),Interleave("+cb+"))" )
___
And yes, I guess a delta parameter would be nice!
-Vit- is offline   Reply With Quote
Old 29th April 2012, 15:46   #64  |  Link
Anacletus
Anacletus's Avatar
Fair enough, thank you
@-Vit-
Thank you too
Old 2nd May 2012, 12:09   #65  |  Link
chainik_svp
Originally Posted by Bernardd View Post
So in my script i have deleted all Refine params_strings with default values. This line " refine: [ { thsad: 200, search: { type: 4, distance: 4, satd: false }, penalty: { pnew: 50 } } ]" has been deleted. I expect no frame picture change, but i have a little change.
A-ha! Why "distance: 4"? Default value is pel value from SVSuper.
Old 2nd May 2012, 12:42   #66  |  Link
chainik_svp
-Vit-
Ver. 1.0.4
look at special.delta param in SVAnalyse
{block:{...}, main:{...}, refine:{...}, special:{delta:2}}
Old 2nd May 2012, 14:53   #67  |  Link
Bernardd
Hi Chainik,
I apologize, my Refine line is not with whole default values. But always
output for this
SVAnalyse( super, """{ gpu: 0, vectors: 3, block: { w: 16, h: 16, overlap: 0 },
main: { levels: 0,
search: { type: 4, distance: -10, sort: true, satd: false,
coarse: { type: 4, distance: -10, satd: true, trymany: false, bad: { sad: 1000, range: -24 } } },
penalty: { lambda: 10.0, plevel: 1.5, lsad: 8000, pnew: 50, pglobal: 50, pzero: 100, pnbour: 50, prev: 0 } } ,
refine: [ { thsad: 200, search: { type: 4, distance: 2, satd: false }, penalty: { pnew: 50 } } ] }""")
is not same as output for this
main: { levels: 0,
Bernard
Bernardd is offline   Reply With Quote
Old 2nd May 2012, 14:57   #68  |  Link
chainik_svp
Bernardd
You don't have any refinement defined in second case. I repeat: default refinement will be with "refine: [ {} ]" string.
Old 2nd May 2012, 16:49   #69  |  Link
Bernardd
Thank Chainik,
I apologize, I have not understand fast. Now it is OK.
Second question, when i restore old Super 8 movies to return Framerate from 16.667 fps to 25, i have tried "plevel = 10" with algo 23 for minimize blend.
What it is the max plevel value usable ?
Bernard
Old 3rd May 2012, 09:15   #70  |  Link
chainik_svp
Bernardd
I've got no idea
But this extremely high "plevel" value means almost zero lambda penalty on all levels except smallest one which leads to less coherent vectors field.
Old 3rd May 2012, 11:12   #71  |  Link
chainik_svp
Version 1.0.5
= added compatibility with GTX680 (and may be with all other Kepler GPUs) - thanks to flagger
Old 3rd May 2012, 21:00   #72  |  Link
Bernardd
Thank Chainik,
I understand now why high plevel is able to minimize blend in some case. With less motion coherence, blend is no more necessary to build the best coherent frame.
Bernard
Old 8th May 2012, 17:42   #73  |  Link
Boulder
Pig on the wing
Boulder's Avatar
-Vit-
Ver. 1.0.4
So can we now simply use three SVAnalyse calls with various delta and then SVConvert to get the MVTools-format vectors out? It seems that SVAnalyse produces a lot more stable vector field than MAnalyse so I'd very much like to incorporate it into my own functions as an alternative
And thanks for all your hard work, there is never too much development these days
Old 8th May 2012, 21:14   #74  |  Link
chainik_svp
That's the plan But someone obviously should try it and report
thanks!
Old 11th May 2012, 03:30   #75  |  Link
Mounir
I haven't tried svp yet but i'd be intereted as it us the gpu; basically i want to replace the mvtools part in my script how would i code that ?
my script:
SeparateFields()
a=last
mot=removegrain(11,0).removegrain(20,0).DepanEstimate(range=2)
take2=a.depaninterleave(mot,prev=2,next=2,subpixel=2)
clean1=take2.TMedian2().selectevery(5,2)
sup1 = clean1.minblur(1).removegrain(11,0).removegrain(11,0)
\ .mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2)
\ .msuper(pel=2,sharp=0)
sup2 = a.msuper(pel=2,levels=1,sharp=2)
bv22=sup1.manalyse(isb=true, truemotion=true,global=true,delta=2,blksize=8,overlap=4,search=5,searchparam=3,DCT=2)
bv21=sup1.manalyse(isb=true, truemotion=true,global=true,delta=1,blksize=8,overlap=4,search=5,searchparam=3,DCT=2)
fv21=sup1.manalyse(isb=false,truemotion=true,global=true,delta=1,blksize=8,overlap=4,search=5,searchparam=1,DCT=2)
fv22=sup1.manalyse(isb=false,truemotion=true,global=true,delta=2,blksize=8,overlap=4,search=5,searchparam=1,DCT=2)
interleave(a.mcompensate(sup2,fv22),a.mcompensate(sup2,fv21),a,a.mcompensate(sup2,bv21),a.mcompensate(sup2,bv22))
selectevery(5,2)
sup3 = last.msuper(pel=2,sharp=2)
bv33=sup3.manalyse(isb=true, truemotion=true,global=true,delta=3,blksize=8,overlap=4,search=5,searchparam=3,DCT=2)
bv32=sup3.manalyse(isb=true, truemotion=true,global=true,delta=2,blksize=8,overlap=4,search=5,searchparam=3,DCT=2)
bv31=sup3.manalyse(isb=true, truemotion=true,global=true,delta=1,blksize=8,overlap=4,search=5,searchparam=3,DCT=2)
fv31=sup3.manalyse(isb=false,truemotion=true,global=true,delta=1,blksize=8,overlap=4,search=5,searchparam=1,DCT=2)
fv32=sup3.manalyse(isb=false,truemotion=true,global=true,delta=2,blksize=8,overlap=4,search=5,searchparam=1,DCT=2)
fv33=sup3.manalyse(isb=false,truemotion=true,global=true,delta=3,blksize=8,overlap=4,search=5,searchparam=1,DCT=2)
last.mdegrain3(sup3,bv31,fv31,bv32,fv32,bv33,fv33,thSAD=499)
Interleave()
weave()
Mounir is offline   Reply With Quote
Old 11th May 2012, 13:50   #76  |  Link
chainik_svp
Mounir
You script won't use any GPU with SVPflow.
Old 11th May 2012, 14:03   #77  |  Link
Bloax
The speed of stupid
Bloax's Avatar
SVP Is still faster though.
Bloax is offline   Reply With Quote
Old 11th May 2012, 16:58   #78  |  Link
chainik_svp
Compared with what? With the original Fizick's 2.5.11.3 - yes, with the version from SVP 3.0.6 - not really (except SVPflow has "adaptive search radius" feature of cause).
Mounir
Do you really need "dct=2" and different search options for forward and backward MVs?
If not then central part of the script could be something like this:
\ .SVSuper("pel:2, scale:{up:0}")
search_params="block:{w:8,overlap:3}" #or whatever
v21=sup1.SVAnalyse("{"+search_params+"}")
v22=sup1.SVAnalyse("{"+search_params+",special:{delta:2}}")
bv22=v22.SVConvert(isb=true)
bv21=v21.SVConvert(isb=true)
fv21=v21.SVConvert(isb=false)
fv22=v22.SVConvert(isb=false)
selectevery(5,2)
sup3 = last.msuper(pel=2,sharp=2,hpad=0,vpad=0)
# SVAnalyse accepts MSuper with zero padding!
v31=sup3.SVAnalyse("{"+search_params+"}")
v32=sup3.SVAnalyse("{"+search_params+",special:{delta:2}}")
v33=sup3.SVAnalyse("{"+search_params+",special:{delta:3}}")
bv33=v33.SVConvert(isb=true)
bv32=v32.SVConvert(isb=true)
bv31=v31.SVConvert(isb=true)
fv31=v31.SVConvert(isb=false)
fv32=v32.SVConvert(isb=false)
fv33=v33.SVConvert(isb=false)
Old 11th May 2012, 18:33   #79  |  Link
Mounir
@ chainik_svp
Your code return an error for \ .SVSuper("pel:2, scale:{up:0}")
error: i don't know what "clean1" means
Old 11th May 2012, 20:15   #80  |  Link
chainik_svp
o_O I thought it's your script.
Or you've just taken it from somewhere and you've got no idea how it works?
In the last case I suggest to ask -Vit- for assistance with all this stuff like "delta" and mdegrain.
frame doubling, frame rate conversion, mvtools, opencl
