Old 25th January 2010, 01:36   #1  |  Link
Jeremy Duncan
Didée Fan
Jeremy Duncan's Avatar
Here is how I use mvtools 2 for frame doubling
This is in ffdshow video codec
Last=ffdshow_source()
setmemorymax(550)
MT("""
LimitedSharpenFaster_JD(strength=11)
super = MSuper(pel=2,hpad=4,vpad=4)
backward_vec = MAnalyse(super,chroma=false, blksize=16, isb = true, search=5, searchparam=1)
forward_vec = MAnalyse(super, chroma=false, blksize=16, search=5, searchparam=2)
backward_re= MRecalculate(super, backward_vec, chroma=false, blksize=8, blksizev=8, overlap=0, overlapv=0, thSAD=100, search=5, searchparam=1)
forward_re= MRecalculate(super,forward_vec, chroma=false, blksize=8, blksizev=8, overlap=0, overlapv=0, thSAD=100, search=5, searchparam=2)
MBlockFps(super, backward_re, forward_re, num=FramerateNumerator(last)*2, den=FramerateDenominator(last)*1, mode=1)
""",2)
lsf plugins, seesaw optionally used instead of lsf These plugins were custom calibrated by me, so they are different than the regular ones.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity.
Last edited by Jeremy Duncan; 27th January 2010 at 16:11. Reason: added custom seesaw
Jeremy Duncan is offline   Reply With Quote
Old 27th January 2010, 13:48   #2  |  Link
Jeremy Duncan
Didée Fan
I updated the first post.
Old 27th January 2010, 14:38   #3  |  Link
Didée
For the *** of *** and *** !!!
If you think you need to make changes to those functions, then change also the name of the function!
Turn your brain on! Countless users are downloading your scripts with those random-by-the-day changes, and some days/weeks/months later, when a user says "I have just used default LSF()", then nobody knows if he has an original function or one by you, so that nobody can know what "default settings" actually do mean.
Is it so hard to add a "_JD" to the name of a function? No. It is baby-easy.
You are causing much more confusion than anything good with your short-sighted behaviour. Really!
Old 27th January 2010, 16:12   #4  |  Link
Jeremy Duncan
Didée Fan
I'm sorry. I have fixed the plugins as you instructed.
frame doubling
