Old 6th August 2014, 08:01   #1  |  Link
Stephe
Stephe's Avatar
PgcEdit errors saving menu buttons created with Windows DVD Maker
Hello,
I had a 996MB AVI file with a running time of 1:46:25 that I wanted to
put on DVD, but I didn't know how.
I used Wonderfox DVD Video Converter to convert it to NTSC DVD format,
which yielded a 4.29 GB VOB file with a running time of 1:46:25.
I then learned that my new Windows 7 machine had something called
Windows DVD Maker. (According to Wikipedia, "Windows DVD Maker is available
on Home Premium and Ultimate editions of Windows Vista and on Home Premium,
Professional and Ultimate editions of Windows 7.") I loaded the AVI file
into it, and created menus.
The resultant DVD had no sound.
I went online and found that the solution was to convert the AVI file to
VOB. Since I already had a converted VOB file, I opened Windows DVD Maker,
clicked on Add items, and changed the filetype from Media Files to All
Files, just like I do whenever I play a VCD on my PC, and the VOB file
appeared. Windows DVD Maker accepted the file, and the resultant DVD had
both menu buttons and sound.
Yay.
In order to revert the DVD to folders, I ripped the DVD with DVDFab DVD
Copy, made a backup copy of the folders, then opened the first set of folders
with PgcEdit.
A popup appeared that said:
(1)
Verify number of streams (in whole DVD)
There are 1 audio streams defined for the Menu domain
in the VMGM_MAT table of VMGM.
0 audion stream are really used by the PGCs.
Fix the number of audio streams in VMGM_MAT to 0?
I clicked on Yes.
I ran Remove Useless Stuff, then burned to disc.
The resultant DVD did not have working scene menu buttons, only a working
startup screen menu.
I then performed some detective work to see what happened the first time
I used PgcEdit for leaving at least 32K of space between IFO and BUP.
I re-opened the folders in PgcEdit and found that the 2 startup screen
menu buttons from VTSM 1, LU 1 (en), 3 (0:20) 2b. were present, whereas
the 8 scene menu buttons that had been in VTSM 1, LU 1 (en), 4 (0:15) 8b.
and in VTSM 1, LU 1 (en), 5 (0:15) 8b. were not.
I then made a second backup of the DVDFab DVD Copy folders, then took the
contents of the first backup of the DVDFab DVD Copy folders and opened it with
PgcEdit, but this time, I didn't run Remove Useless Stuff. The resultant
ISO and DVD had working buttons and sound!
Yay again.
So, I re-opened the folders in PgcEdit again to see what might have caused
the error the first time.
When I ran Remove Useless Stuff, I encountered the following probably-relevant
popup, so I copied it down. It said:
(2)
PgcEdit: Save Buttons
There are modified buttons in file "VTS_01_0.VOB" (0.03 GB).
This VOB file will be updated now.
There is still no backup of this file in the PgcEdit_backup folder.
Do you want to backup the original file now?
I clicked on Yes and the buttons vanished from VTSM 1, LU 1 (en), 4
and from VTSM 1, LU 1 (en), 5.
I re-opened PgcEdit and there were question marks to the left of the b.s
like so: VTSM 1, LU 1 (en), 4 (0:15) ?b. and VTSM 1, LU 1 (en), 5 (0:15) ?b.
A popup message said:
(3)
PgcEdit
There is a "menubuttons.but" file in the root folder of your DVD.
Do you want to import it?
WARNING: This will overwrite all menu button and BOV information!
Your buttons edits will be saved in that menubuttons.but file too!
You should answer Yes only if you don't have the VOB files.
Note: If you answer Yes, PgcEdit will not ask this question again and
will assume Yes each time for the current DVD and session.
I had answered No originally, but this time I clicked Yes.
It restored the 8 buttons in VTSM 1, LU 1 (en), 4 (0:15) 8b. and in
I then ran Remove Useless Stuff again, whereupon the 8 buttons corresponding
to VTSM 1, LU 1 (en), 4 (0:15) 8b. and in VTSM 1, LU 1 (en), 5 (0:15) 8b
disappeared again and I got the following popup:
(4)
PgcEdit: Save Buttons/BOV
Errors saving menu buttons!
Affected domain:
VTSM 1
As there is a "menubuttons.but" file in your DVD root folder, and
the buttons were loaded from that file when the DVD was opened,
PgcEdit has successfully saved the menu buttons in that file.
Do not forget that the buttons had NOT been saved in the VOBs!
NOTE: This warning is shown only once per Pgcedit session.
What's the story here? I can't run Remove Useless Stuff if and when I
convert from AVI to VOB and make a DVD with Windows DVD Maker?
Stephe is offline   Reply With Quote
Old 6th August 2014, 22:16   #2  |  Link
Stephe
Stephe's Avatar
My guess is that I *can* run Remove Useless Stuff if and when I convert
from AVI to VOB and make a DVD containing menus with Windows DVD Maker,
as long as I untick the box in Remove Useless Stuff that says:
Delete all useless Dead Buttons and BOVs.
(Dead button cannot easily be activated by the user.)
I'm just curious about the nature of the glitch.
Old 6th August 2014, 23:42   #3  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
I can't tell you what's going wrong without the IFO and menu VOBs, but I guess PgcEdit recognises the menu buttons as useless because the duration of the menu is too short and there is no cell still time to wait for the user to select a button. In other words, I suppose that the menu is made of still frames, that require an infinite (or at least long) still time, but the still time is not defined.
Can you verify in the menu PGC the duration of the menu? (If I'm right, it should be less than 1 second.) Then, double-click the menu PGC and look at the cell still time of the cells with the buttons. The value should be 255 (for an infinite pause). If it is 0, then indeed it is impossible to select a button because the playback is way too short, and it's a severe authoring error. And PgcEdit is right! ;-)
I don't know the Windows DVD Maker, but I would not be surprised if it is the culprit.
r0lZ
Old 7th August 2014, 02:38   #4  |  Link
Stephe
Stephe's Avatar
has two buttons: Play Movie and Scene Menu
Nothing on the page moves except the button highlight
has six animated menu cells, an up arrow, and a right arrow
has six animated menu cells, an up arrow, and a left arrow
The menu cells move; they are not still frames.
I opened PgcEdit.
If I double-click on VTSM 1, LU 1 (en), 3 (0:20) 2b. I see:
Num Buttons | Prog. | Cell | Type Flags | seamless Joint | A. | Cell Still Time | Cell Cmd # | Playback Time | .End Time
.....0..........1......1........3..0.........[blank].......-...........0..............0.........00:00:05.00....00:00:05.00
.....2.......[blank]...2........9..0........[checked]......-...........0..............1.........00:00:15.00....00:00:20.00
If I double-click on VTSM 1, LU 1 (en), 4 (0:15) 8b. I see:
.....0..........1......1........2..0.........[blank].......-...........0..............0.........00:00:00.12....00:00:00.12
.....8.......[blank]...2........9..0........[checked]......-...........0..............1.........00:00:15.00....00:00:15.12
If I double-click on VTSM 1, LU 1 (en), 5 (0:15) 8b. I see:
.....0..........1......1........3..0.........[blank].......-...........0..............0.........00:00:00.15....00:00:00.15
.....8.......[blank]...2........9..0........[checked]......-...........0..............1.........00:00:15.00....00:00:15.15
I don't really understand how to use the above.
Old 7th August 2014, 09:56   #5  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Hum, it seems that your menus are not still frames, since their duration is 15 seconds. (The still time is 0 in all cases, but it's normal for animated menus.) Thanks for your post BTW; it's exactly what I needed to know.
Apparently, PgcEdit has a bug somewhere. I will have a look...
r0lZ
Old 7th August 2014, 18:18   #6  |  Link
Stephe
Stephe's Avatar
Glad to be of help.
I tried running Remove Useless Stuff for the folder containing the
AVI-to-VOB conversion that I processed with Windows DVD Maker again,
but this time unticked the box that says "Delete all useless Dead
Buttons and BOVs. (Dead button cannot easily be activated by the
user.)" and it worked: the menu buttons were not changed.
I thought you'd want to know.
converter, dvd, maker, windows, wonderfox
