Old 15th May 2008, 21:44   #1  |  Link
SPiKA
How to denoise this?
I'm currently using trim + dfttest(sigma=5) to denoise just the heavily noised scenes... but it kills way to many detail.
Any suggestions?
Don't worry about the "clean" scenes... since I'm using light filtering on them.
Source:
Chopped footage:
http://www.mediafire.com/?n06a2c1n4o3
SPiKA is offline   Reply With Quote
Old 15th May 2008, 21:50   #2  |  Link
Terranigma
*Space Reserved*
Terranigma's Avatar
tnlmeans? That would be my number 1 choice for anime, but if that's too slow, you can try mvdegrain with dct 3 and maybe a search radius of 30+.
Terranigma is offline   Reply With Quote
Old 15th May 2008, 22:10   #3  |  Link
SPiKA
Speed isn't a problem. Quality is...
Can you recommend me settings for it?
Old 15th May 2008, 22:15   #4  |  Link
martino
masktools2 (ab)user
martino's Avatar
Deen and BlindPP! No, I'm not joking.
BlindPP(14,6)
Deen()
Not tuned, etc...
It's what I used last time on similarly looking artefacts and worked for me, but there may be a better, "newer" solution.
Oh yeah... by the way, is there a technical name for that blocking and a reason why it happens since we're on this subject already?
martino is offline   Reply With Quote
Old 15th May 2008, 22:25   #5  |  Link
Terranigma
*Space Reserved*
Terranigma's Avatar
Default settings?
By default though, there's no temporal operation going on, so if you want to do temporal filtering, then configure the AZ parameter. The higher, the better the results & slower the processing (much slower actually ). AZ=5 would be equaled to that of bt=5 in fft3dfilter. Also, since the source in question is indeed a toon/anime based source, set sse to false since sad usually works better with these types of sources. The "h" parameter would be the strength of the filtering, but you may want to start with 0.1 and adjust it as needed from there, since 0.1 in sad mode would be like, 0.45 in sse mode (which may prove to be too strong in some cases).
So all in all, try the default settings with the exception of configuring the "AZ" parameter and using SAD instead of SSE.
Old 15th May 2008, 23:55   #6  |  Link
SPiKA
Something like this?
tnlmeans(ax=3,ay=3,az=5,sx=2,sy=2,bx=1,by=1,sse=false)
Old 16th May 2008, 00:00   #7  |  Link
Terranigma
*Space Reserved*
Terranigma's Avatar
Yes. Now tune the strength (h) parameter to your liking
(az=5 wouldn't probably help that much unless you plan on using tnlmeans as a prefilter, or with 5 frames compensated, so you're probably better off using az=1.)
Old 16th May 2008, 00:06   #8  |  Link
SPiKA
I though that MVDegrain3 was already ubber slow... but this (especially with az=5) is SLOOOW in a whole new dimension!
Old 16th May 2008, 05:05   #9  |  Link
cestfait
cestfait's Avatar
first diagnose the problem. this doesn't need more denoising that mvdegrain3. what that needs is deblocking. try "aaa," my preferred anti aliaser, which has always served me better than a deblocker:
function AAA(clip clp, int "Xres", int "Yres", int "Xshrp", int "Yshrp",
 \ 	 int "US", int "DS", bool "chroma")
         clp = clp.isYV12() ? clp : clp.ConvertToYV12()
         ox = clp.width
         oy = clp.height
         Xres  = default(Xres,  ox)
         Yres  = default(Yres,  oy)
         us  = default(us, 1)
	 ds = default(ds, 2)
         Xshrp = default(Xshrp, 0)
         Yshrp = default(Yshrp, 0)
	 chroma = default(chroma, false)
         us==0 ? clp.PointResize(ox*2,oy*2) : clp.LanczosResize(ox*2,oy*2)
         TurnLeft()
         SangNom()
         TurnRight()
         SangNom()
         ds==0 ? BilinearResize(Xres,Yres) :
 \	 ds==1 ? BicubicResize(Xres,Yres) :
 \	 LanczosResize(Xres,Yres)
         Unfilter(Xshrp,Yshrp)
         chroma ? MergeChroma(clp.Lanczosresize(Xres,Yres)) : last
I've modified the defaults a bit, so just aaa() should work fine. you'll need sangnom and unfilter.
i'm sure I can trust you to sharpen up afterwards!
cestfait is offline   Reply With Quote
Old 16th May 2008, 06:17   #10  |  Link
Manao
You can try somthing like at_denoise(sstep = 0.4, edge = 3.0, iterations = 10, center = 1, tstep = 0) - it's in anisotools, in my signature.
Manao is offline   Reply With Quote
Old 16th May 2008, 22:19   #11  |  Link
SPiKA
tnlmeans(ax=3,ay=3,az=5,sx=2,sy=2,bx=1,by=1,h=2,sse=false)
aaa()
dfttest(sigma=5)
Old 18th May 2008, 06:20   #12  |  Link
cestfait
cestfait's Avatar
pick the one you think looks best MOVING. You could also just try normal x264 deblocking settings.
Old 19th May 2008, 03:14   #13  |  Link
SPiKA
TNLMeans worked the best... thanks to everybody for your help.
Old 19th May 2008, 03:38   #14  |  Link
thetoof
Sleepy overworked fellow
To my eyes, what gives the best result on your clip is aaa() + some light denoiser (like dfttest with a low sigma), because the main problem seems to be, as cestfait said, blocking.
However, "The best is what works best for you!".
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline   Reply With Quote
Old 19th May 2008, 16:22   #15  |  Link
SPiKA
In fact, I ended up using TNLMeans (with lower strength) + aaa().
Old 19th May 2008, 23:33   #16  |  Link
cestfait
cestfait's Avatar
good! It's always satisfying to be decisive. I do, however agree with thetoof. your tnlmeans in a scene like that is not going to help compressibility much (still high contrast edges shifting every frame), and x264's deblocker/quantization in general should smooth away the worst of the artifacts left over.
there can be no TRUE perfectionism here-- don't waste your time filtering every blocky scene to kingdom come-- you are starting with a flawed source.
Old 19th May 2008, 23:37   #17  |  Link
cestfait
cestfait's Avatar
on one other note: another sort of cheater's solution to blocking is just spline resizing the frame to double-size and then back down again. it takes advantage of spline-interpolation's idea of what the frame is supposed to look like. a sort of crude method of supersampling.
doesn't always work perfectly, of course!
anime, denoise
