Old 15th February 2017, 22:06   #1081  |  Link
GMJCZP
GMJCZP's Avatar
In simple x264 I put directly (withouth avisynth) the source and the custom parameter --input-depth 12.
With both avisynth and avisynth+ I get the same results, opening the script with VirtualDub:
FFVideoSource("video.mp4") # source is x265 12 bit
AssumeFPS("ntsc_film")
f3kdb(0,0,0,0,0,0, keep_tv_range=true, dither_algo=2, input_mode=2, input_depth=12, output_mode=0, output_depth=8)
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 15th February 2017, 22:21   #1082  |  Link
sneaker_ger
At least for AviSynth FFVideoSource() will already dither to 8 bit. For AviSynth+ it may output native 12 bit but then again f3kdb() does not support anything high-bitdepth natively in AviSynth+. It may depend on the exact ffms2 and AviSynth+ version but I believe your script never makes sense. You could try LWLibavvideosource() (L-Smash Works) with stacked=true and e.g. format="YUV420P16" (*) parameters, then input_mode=1 for f3kdb().
(*) format="YUV420P16" for 4:2:0 sub-sampling. Change accordingly if required.
Old 15th February 2017, 22:49   #1083  |  Link
GMJCZP
GMJCZP's Avatar
Could you please put the new script? My head is spinning.
EDIT: It works with Avisynth+:
LWLibavvideosource("C21 jap.mp4" )
Now, is the script correct to go from 12 bit to 8 bit?
EDIT2: the outpu in Simplex264 is with garbage, lol.
By law and justice!
GMJCZP's Arsenal
Old 15th February 2017, 23:22   #1084  |  Link
sneaker_ger
Yes, should be correct. It should also work like that in normal AviSynth.
Old 15th February 2017, 23:29   #1085  |  Link
GMJCZP
GMJCZP's Avatar
Ok, but and the output with garbage with simplex264? Should I define the format with LWLibavvideosource?
By law and justice!
GMJCZP's Arsenal
Old 15th February 2017, 23:30   #1086  |  Link
sneaker_ger
I cannot comprehend that sentence.
Old 15th February 2017, 23:32   #1087  |  Link
GMJCZP
GMJCZP's Avatar
The output with x264 presents garbage, is it not that I need to define the format with LWLibavvideosource to prevent encoding errors?
EDIT: placing LWLibavvideosource ("video.mp4", format = "YUV420P12") causes VirtualDub to display the same garbage as when encoding with Simplex264.
By law and justice!
GMJCZP's Arsenal
Old 15th February 2017, 23:39   #1088  |  Link
sneaker_ger
You already had the correct script in #1085. Don't change it. The script outputs 8 bit so you must not set any bitdepth parameters in x264/Simplex264.
Old 15th February 2017, 23:46   #1089  |  Link
GMJCZP
GMJCZP's Avatar
Okay, but with that script the video looks like garbage after coding without set the bitdepth.
By law and justice!
GMJCZP's Arsenal
Old 15th February 2017, 23:53   #1090  |  Link
sneaker_ger
(Simple)x264 command/log?
Old 16th February 2017, 00:04   #1091  |  Link
GMJCZP
GMJCZP's Avatar
In these last tests with LWLibavvideosource coding errors have been my fault.
I added the Stab() function in the script and when removing everything was solved, thanks Sneaker_Ger and all for your patience.
Now the question remains: Do DePan/Repair have any incompatibility with 12 bit?
By law and justice!
GMJCZP's Arsenal
Old 16th February 2017, 13:21   #1092  |  Link
real.finder
the old avs don't support anything more than 8 bit, there are some hack way in some old filter like f3kdb and dither, any new filter that support anything more than 8 bit will need avs+, in old avs will work in 8 bit only cuz no one care about old hacks if there are native support
See My Avisynth Stuff
Old 26th February 2017, 11:42   #1093  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by cretindesalpes View Post
Could you give it a bump to adapt to latest AVS+ with high bit support too?
@turment on Telegram
Old 29th November 2017, 02:04   #1094  |  Link
felicityb
Hello!! So I've recently gotten into making animated gifs using VirtualDub's gif creator and Avisynth (I don't got Photoshop monies). A major problem I'm running into is that it creates horrible banding, and I was wondering if Dither's color conversion scripts could help me out. Anyway, long story short - I keep getting this lovely message anytime I tried to call any Dither functions into my script.
"Avisynth Read Error: CAVIStreamSynth: System exception - Illegal Instruction at 0x5ab57ea0"
The script will open, but I get a gray box and anytime I try to scroll through the video, I get that message. I have the latest version of Dither and the 16bit mod of MaskTools, and I'm running the latest stable avs+.
This is my script -
ffvideosource(source="C:\Users\The Boys\Desktop\Dance.avi")
Dither_convert_yuv_to_rgb(matrix="601", interlaced=false,
tv_range=false, cplace="MPEG2", lsb_in=false,
chromak="spline64", mode=0, ampo=1, ampn=1,
staticnoise=false, slice=false, output="rgb24", noring=true)
And this does this with videos encoded with any codec. My initial test was with a video encoded with Lagarith, but then I tried one encoded in h.264 (it was a YT rip), and boop - same result.
felicityb is offline   Reply With Quote
Old 29th November 2017, 02:20   #1095  |  Link
Create a report with Groucho2004 AvsMeter, just so we know what you are using (versions etc).
Run command prompt,
then eg CD C:\Z (or change directory to some other known directory, I have a C:\Z folder)
AvsMeter -AvsInfo -log # will create log in Z directory. # Edit with AvsMeter in Z directory, or somewhere in your PATH.
Post it here.
Also, if possible, use AviSource, rather than FFMpegSource, just to remove it from the problem space.
also, does problem disappear if you change the arguments to Dither_convert_yuv_to_rgb ?
EDIT: Latest version Dither Tools is 1.27.2:- http://avisynth.nl/index.php/Dither_tools
EDIT: My log was 42KB (D9 post limit is 16KB in Usage forum), if you cut out the Internal(builtin) and External function/filter
names it should be cut down some (mine went down to 15KB), so you can post in thread.
Old 29th November 2017, 03:07   #1096  |  Link
felicityb
Run command prompt,
eg CD C:\Z (or change to some known directory, I have a C:\Z folder)
Post it here.
Sorry for the wait, it's been quite a while since I've used CLI. Anyway, here's the relevant bits of the log file.
[OS/Hardware info]
Operating system: Windows 7 (x86) Service Pack 1.0 (Build 7601)
CPU brand string: Intel(R) Pentium(R) M processor 1.60GHz
CPU features: MMX, SSE, SSE2
[Avisynth info]
VersionString: AviSynth+ 0.1 (r1576, x86)
VersionNumber: 2.60
File / Product version: 2.6.0.5 / 2.6.0.5
Interface Version: 5
Multi-threading support: No
Avisynth.dll location: C:\Windows\system32\avisynth.dll
Avisynth.dll time stamp: 2014-01-03, 00:14:26 (UTC)
PluginDir2_5 (HKLM, x86): C:\Program Files\AviSynth\plugins
PluginDir+ (HKLM, x86): C:\Program Files\AviSynth+\plugins+
[CPP 2.5 / 32 Bit Plugins]
C:\Program Files\AviSynth\plugins\AddGrainC.dll [1.7.1.0]
C:\Program Files\AviSynth\plugins\dfttest.dll [1.9.4.0]
C:\Program Files\AviSynth\plugins\dither.dll
C:\Program Files\AviSynth\plugins\eedi3.dll [0.9.2.0]
C:\Program Files\AviSynth\plugins\FFT3DFilter.dll [2.1.1.0]
C:\Program Files\AviSynth\plugins\gradfun2db.dll
C:\Program Files\AviSynth\plugins\mvtools2.dll [2.6.0.5]
C:\Program Files\AviSynth\plugins\SmoothUV.dll [1.4.0.0]
C:\Program Files\AviSynth\plugins\SSE2Tools.dll
C:\Program Files\AviSynth\plugins\TBilateral.dll [0.9.11.0]
C:\Program Files\AviSynth\plugins\TUnsharp.dll [0.9.3.0]
[CPP 2.6 / 32 Bit Plugins]
C:\Program Files\AviSynth+\plugins+\DirectShowSource.dll
C:\Program Files\AviSynth+\plugins+\ImageSeq.dll
C:\Program Files\AviSynth+\plugins+\Shibatch.dll
C:\Program Files\AviSynth+\plugins+\TimeStretch.dll
C:\Program Files\AviSynth+\plugins+\VDubFilter.dll
C:\Program Files\AviSynth\plugins\DePan.dll [2.13.1.3]
C:\Program Files\AviSynth\plugins\DePanEstimate.dll [2.10.0.2]
C:\Program Files\AviSynth\plugins\DirectShowSource.dll [2.6.0.3]
C:\Program Files\AviSynth\plugins\ffms2.dll
C:\Program Files\AviSynth\plugins\masktools2.dll [2.1.0.0]
C:\Program Files\AviSynth\plugins\MedianBlur2.dll
C:\Program Files\AviSynth\plugins\RgTools.dll
C:\Program Files\AviSynth\plugins\TCPDeliver.dll [2.6.0.7]
[Scripts / AVSI]
C:\Program Files\AviSynth+\plugins+\colors_rgb.avsi
C:\Program Files\AviSynth\plugins\colors_rgb.avsi
C:\Program Files\AviSynth\plugins\Dehalo_alpha_MT2.avsi
C:\Program Files\AviSynth\plugins\dither.avsi
C:\Program Files\AviSynth\plugins\FFMS2.avsi
C:\Program Files\AviSynth\plugins\FineDehalo.avsi
C:\Program Files\AviSynth\plugins\LRemoveDust.avsi
C:\Program Files\AviSynth\plugins\mt_xxpand_multi.avsi
C:\Program Files\AviSynth\plugins\RemoveDustHD.avsi
C:\Program Files\AviSynth\plugins\tA7aHtYP.avsi
[Uncategorized / 32 Bit DLLs]
C:\Program Files\AviSynth\plugins\libfftw3f-3.dll
[Uncategorized / Other]
C:\Program Files\AviSynth+\plugins+\colors_rgb.txt
C:\Program Files\AviSynth\plugins\ffms2.lib
C:\Program Files\AviSynth\plugins\ffmsindex.exe
I changed FFMPEGSource to AVISource and I get the same message. I also ran the avs script through AVS Meter and it gives me the same error. And I've tweaked nearly every argument in the script, left some on default, etc etc. Gives me the same message.
Old 29th November 2017, 14:28   #1097  |  Link
[Avisynth info]
VersionNumber: 2.60
Avisynth.dll time stamp: 2014-01-03, 00:14:26 (UTC)         # Old ver$, Update to current Pinterf Avisynth+ r2542 (20171114)
[Scripts / AVSI]
C:\Program Files\AviSynth\plugins\tA7aHtYP.avsi             # Dont like, looks like typical malware name. No hits on Google. What is it ?
C:\Program Files\AviSynth\plugins\libfftw3f-3.dll           # Should be in System32 EDIT: Think for dfttest and/or others.
C:\Program Files\AviSynth\plugins\ffms2.lib                 # Maybe Delete (not intended to be here)
Update to Avisynth+ r2542 (20171114), (Not MT Version, unless required) here:- https://github.com/pinterf/AviSynthPlus/releases
Many updates since your version AVS+, maybe problem fixed already.
EDIT: OK, Google'ed tA7aHtYP without the 'avsi' and its, DeHaloHmod 11 11 2016 http://pastebin.com/tA7aHtYP
Suggest rename to something more descriptive.
Old 29th November 2017, 20:21   #1098  |  Link
felicityb
I upgraded everything and I'm still getting the same error. AVSMeter says the error is coming directly from Dither.dll.
AVSMeter 2.6.8 (x86) - Copyright (c) 2012-2017, Groucho2004
AviSynth+ 0.1 (r2544, MT, i386) (0.1.0.0)
Exception 0xC000001D [STATUS_ILLEGAL_INSTRUCTION]
Module:   C:\Program Files\AviSynth\plugins\dither.dll
Address:  0x60457EA0
I also couldn't find a version of avs+ r2544 without MT
Old 29th November 2017, 21:57   #1099  |  Link
Groucho2004
Address:  0x60457EA0
I suggest starting from scratch. Remove all plugins (make a backup, just in case) and add plugins as needed.
There is no such thing. AVS+ has been multi-threaded since r16xx.
Groucho's Avisynth Stuff
Old 30th November 2017, 12:11   #1100  |  Link
OK, but whats difference in the '-MT' postfixed versions then ???
Latest release
r2544-MT
53b8d15
Avisynth+ r2544-MT
@pinterf pinterf released this 15 days ago · 2 commits to MT since this release
Avisynth+ r2544 (20171115)
20171115 r2544
Fixes
Expr: fix "scalef" for 10-16 bits
modification, additions
Expr optimization: eliminate ^1 +0 -0 *1 /1
Fixes
Fix: RGB (full scale) conversion: 10-16 bits to 8 bits rounding issue; pic got darker in repeated 16<->8 bit conversion chain
Fix: ConvertToY: remove unnecessary clamp for Planar RGB 32 bit float
Fix: RGB ConvertToY when rec601, rec709 (limited range) matrix. Regression since r2266
EDIT: Arh, the one in red is not post fixed, perhaps pinterf adds -MT or not, depending upon mood
EDIT: Nah, my mistake, all are postfixed now in actual file name.
EDIT: Guess that I should not skim read.
EDIT: Think I'm finally gonna try avs+ (long-long time since done that), and in x64 I think.
color banding, deblocking, noise reduction
