2nd August 2006, 19:12 | #41 | Link |
Concerning the audio delay issue, I noticed improvement in lots of sources that were troublesome before (specially in Higurashi), but I still notice it in Major 34 and 37 for example... I haven't had time to test with lots of sources though
3rd August 2006, 00:20 | #42 | Link |
retired developer
Continu on error done.
Detritus Software |
3rd August 2006, 01:55 | #43 | Link |
retired developer
I think I forgot a feature someone asked... d*mn
[edit] found it! remove "encoded frames: " from the logs
Detritus Software Last edited by Sirber; 3rd August 2006 at 12:49. |
3rd August 2006, 15:25 | #44 | Link |
Sohn des Infernos
and just a real big thing again. we need a bitrate calculator aswell. (just saw it when I compared 5.0.0a1 with 4.2.0)
hope you can add this feature aswell in RealAnime 5.0.0.a2 EDIT: A Screenshot of how I mean it to add Last edited by YouDontKnowMe; 3rd August 2006 at 15:32. |
3rd August 2006, 15:34 | #45 | Link |
retired developer
alright.
gonna add the one from RA4 with some modifs to calculate the oversize of MP4.
Detritus Software |
3rd August 2006, 15:48 | #47 | Link |
retired developer
no problem. do you know what is the oversize for MP4?
later on, I could use MB instead of KBPS to have constant filesize. but I need to know MP4 oversize, source length, bitrates. the only thing missing is MP4 info. [edit] the right term is "overhead"
Detritus Software Last edited by Sirber; 3rd August 2006 at 15:51. |
3rd August 2006, 16:06 | #49 | Link |
retired developer
I've put the blog back on.
it's indeed more pretty
Detritus Software |
3rd August 2006, 16:13 | #51 | Link | |
retired developer
Detritus Software |
3rd August 2006, 16:31 | #53 | Link | |
retired developer
Detritus Software |
3rd August 2006, 18:33 | #54 | Link |
Sohn des Infernos
I really looking on to the alpha 2
here is the proof of that big deals always begins with small ideas; Sirber just wanted to encode his Naruto eps to get them smaller and coded RealAnime and now he is the inventor of one of the best x264 gui's on the web ;-) the best would be when you would let us the opinion to chose between filesize and bitrate you just need some overhead infos the mathematics you should easily solve - when not just ask me as I'm a maths prof ;-)
"Bencos... and you know you're alive..." |
3rd August 2006, 18:36 | #55 | Link | |
3rd August 2006, 18:51 | #56 | Link | ||
retired developer
RA's main goal is not to encode naruto these days... to much crap fillers
Detritus Software Last edited by Sirber; 3rd August 2006 at 18:53. |
4th August 2006, 02:53 | #58 | Link | |
RealAnime dev
Currently looking for fixing the output in same folder (rename the source with another name before the muxing ... in case that it's the same filename)
よろしく。 <- if you see "???" you need japanese fonts ;) |
4th August 2006, 02:55 | #59 | Link |
retired developer
good
keep the work... good or worst [edit] for rename, how about renaming the conflicting file <name>.<ext>.old ?
Detritus Software |
4th August 2006, 02:58 | #60 | Link | |
RealAnime dev
