31st March 2010, 17:23 | #23 | Link | |
Thus the correct explanation is (assuming the parameters work as you describe, which I have NOT tested in practice): Code:
Deblocking is applied with alpha strength to blocks with less detail than the (beta) threshold. Therefore: The higher the alpha parameter, the higher the deblocking strength applied. The higher the beta parameter, the more blocks are deblocked (namely with strength alpha). PS: In order for your explanation to be more correct, you would have to replace all red words above (i.e. "less deblocking" and "more deblocking") by "deblocking with alpha strength". But then you are still contradicting yourself when saying "to more flat blocks with details present" vs. "to less flat blocks with details present". So I would stick to my shorter and correct version ;-) EDIT: having read the remainder of the thread, I add that DarkZell666 gives the same (correct) explanation. Last edited by lovelove; 31st March 2010 at 17:42. |
29th August 2014, 14:26 | #25 | Link |
Does --deblock require the existence of conventional block sizes (like 8x8) to work properly? Or does it work as effectively on upscaled material too? (with still some visible blocking, but with what would now be larger, non-standard block sizes).
Gorgeous, delicious, deculture! |
29th August 2014, 14:38 | #26 | Link | |
Registered sausage
So resolution does not matter. |
29th August 2014, 14:46 | #27 | Link | |
Or are you saying it does not look at the source per se to deblock, but just generally deblocks on what it encodes? (Which would still leave me with a deblocked movie, right?)
29th August 2014, 15:56 | #28 | Link |
X264 divides image into diferent block sizes, 16x16, 8x8, 4x4. Internal deblocking deblocks these macroblocks to prevent hard edges between those, and in general to prevent blocking as a result of encoding. It also removes a bit of details and makes picture softer when used with higher values. It does not remove blocking from source. Usd avisynth deblock or unblock plugin if you want to deblock source.
Read first post for more detailed explanation. Last edited by detmek; 29th August 2014 at 16:04. |
29th August 2014, 16:32 | #29 | Link | |
13th April 2015, 02:32 | #30 | Link |
what are the deblocking effects on encoding speed? is it logical to assume that the lowest values -3;-3 are fastest, because the least amount of deblocking is applied then?
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 13th April 2015 at 02:35. |
13th April 2015, 20:09 | #31 | Link |
Angel of Night
Depends on high low your crf and how high your rd level is. The more blocks with quants below or barely above the deblocking threshold, the less get deblocked. The higher your rd level, the more times each block is checked, so the more helpful less deblocking is. Any benchmarks will be heavily weighted toward the video and settings you use, but will be a rather small part of the overall speed.
You can actually go all the way down to -6,-6, at which point you might as well just turn deblocking off completely. |
16th January 2017, 08:05 | #32 | Link |
Deblocking vs. bitrate used...
Sort of along the topic of this thread...
If I lower the deblock settings and slightly raise the Psy Trellis, this is pretty much encoding at high bitrates with Blu-rays using a CRF around 20 and x264 settings around 'Slow', does that increase the amount of bitrate used and thus increase the file size? Say I use a setting of --deblock -3:-3 --psy-rd 1.00:0.25, will this inherently raise the amount of bitrate 'needed' while encoding and thus increase the overall resulting file size? Thanks! ***EDIT Hmmm, well, I THINK I got the answer to my question here from reading a few more threads. Apparently, YES, the bitrate will indeed go up even using --tune film according to other threads, so -3, -3 AND raising the Psy Trellis is BOUND to increase it even more, I guess... I was bloody wondering WHY my encodes were coming out so big... Last edited by Lathe; 16th January 2017 at 08:28. Reason: More stuff... |
1st January 2022, 14:56 | #33 | Link | |
