7th January 2014, 04:08 | #21 | Link | |
Thank you, r0lZ, that is very helpful. And the job doesn't sound too difficult.
7th January 2014, 04:36 | #22 | Link |
PgcEdit daemon
In 2D blu-ray discs, the MPLS references one or several M2TS files. For compatibility reasons, the same thing is true for 3D BDs. But a 3D player "knows" that it must replace the M2TS file(s) (from the BDMV/STREAM directory) with the file(s) with the same base name(s) but with the extension .ssif, from the BDMV/STREAM/SSIF directory. Only the 3D movies have one (or several) SSIF files in that directory. So, for example, 00001.mpls can reference, say, 00010.m2ts, and a 2D-only player will read that M2TS, but a 3D player will read 00010.ssif instead.
The 3D files are in fact made of 2 MPLS files for each "part". (In my previous example, the 2 mpls files can be 00010.m2ts and 00011.m2ts.) The first M2TS contains the AVC video stream and the audio and subtitle streams, exactly like on a 2D BD. The second M2TS contain usually only the MVC stream (but it can also contain subtitle streams, for a reason that I have never understood), and of course, it cannot be decoded by a 2D player, or without the AVC stream from the other file. That second M2TS file is ignored by the 2D players, and is not used when the 3D movie is watched in 2D on a 3D player. The SSIF file contains the two M2TS files interleaved at the file system level. In other words, the data on disc contained in the SSIF file is the data of the two M2TS file, arranged in such a way that it is possible to read the two files without having to seek continually to different places on the disc. The SSIF file is therefore used when the 3D player must play the movie in 3D, and provides a fast access to the 2 M2TS files. I don't know how your MPLS parser works, but of course, to decode a 3D movie, it must be able to read the corresponding SSIF file instead of the M2TS, to retrieve also the MVC stream. Or, if you prefer, it should read the two M2TS files at the same time, but I don't know if the second M2TS file is explicitly referenced in the MPLS. Anyway, if it is referenced, it's not in the normal way, as it must not be visible to the 2D-only players. Sorry if I can't be more technical and explain exactly the differences in the MPLS file format. I have only written a GUI using other tools, and the decoding part is not my speciality.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 7th January 2014 at 04:44. |
7th January 2014, 08:31 | #24 | Link | ||
Thanks r0lZ for all your explanation
Here are some informations about Intel Media SDK (from Intel website or Intel forum) : - Download Intel Media SDK - Download Intel Media SDK tutorial Informations about mvc_dec_filter.dll (a DirectShow sample MVC decoder include in Intel Media SDK and open source) : Quote:
7th January 2014, 19:41 | #27 | Link |
"Intel Quick Sync Video is Intel's hardware video encoding and decoding technology, which is integrated into some Intel CPUs."
http://en.wikipedia.org/wiki/Intel_Quick_Sync_Video It would obviate the need for a supported nVidia graphics adapter for DG tools. |
9th January 2014, 19:55 | #28 | Link |
Bringing up my new machine now...
Oy, Windows 8! Gnyah. Gonna take me a little while to make it usable, create recovery disks, then update to 8.1, and then finally get going on development. Any recommendations for Windows 7-like shell, etc.? I grant myself this little OT as it will facilitate our goal here. EDIT: For the curious, this is the first PC I have not built myself. It is an ASUS M51AC-US004S. Not bad for $870. The only sucky thing is the keyboard letters are in light gray -- almost invisible! It's OK I have a spare illuminated keyboard in the closet. Last edited by Guest; 9th January 2014 at 20:00. |
9th January 2014, 20:13 | #29 | Link |
PgcEdit daemon
I use Classic Shell to bring the start menu back in Win8, and to boot directly in desktop mode. It is very good and stable, and highly customizable. It has also other features that I have not enabled.
Thanks to Classic Shell, I have almost totally forgiven the start screen and the M$ apps. They are useless anyway.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 9th January 2014 at 20:28. |
9th January 2014, 22:05 | #31 | Link |
With Windows 8 or 8.1, you must think to use Windows key on your keyboard and shortcuts, like Windows + X to access a menu with main functionnalities, Windows + R to run a command, etc...
Like r0lZ, I use a little soft to add start menu, it's Start8. There are several others softs like that Windows 8.1 add a very "useless" button, with it you can switch between Modern UI and desktop, and you boot directly to desktop |
9th January 2014, 22:37 | #32 | Link |
PgcEdit daemon
No, not yet. But I think 8.1 is slightly better than 8.0.
10th January 2014, 01:26 | #33 | Link | |
I too believe 8.1 to be a welcome if minor upgrade from 8.0. |
10th January 2014, 03:35 | #36 | Link | |
And on another matter I already get boot to desktop from Classic Shell. I may upgrade at some point but I am itching to get the project going, as Nico8583 has set a Sunday deadline. Last edited by Guest; 10th January 2014 at 04:12. |
10th January 2014, 08:33 | #37 | Link | |
When I have tried to compile, I have used Visual Studio 2010 but I think 2005 and 2008 works also because when you open a Intel Media SDK project to VS 2010, it asks you to convert it because project files where created in an older version of VS. It needs Windows SDK 7.0 or above also, and that's all if I don't forget anything |
