Old 16th March 2009, 01:24   #1561  |  Link
DLynch
Hi Dean,
This is a pretty minor thing but somewhere between build 460 and 462 the centring of the footer got messed up. It appears right justified now. You can see it in preview also.
DLynch is offline   Reply With Quote
Old 16th March 2009, 09:00   #1562  |  Link
spudman
Hi Deank, I am new to using your program but think it is great. i use it on my home pc but i also access a server and do alot of work on there and i am trying to use your program on there but i am having a bit of trouble. When i click the .exe file to start the program, instead of it starting up properly i get a small box usually what is the log box but with just a text in there saying "= cDragDrop: DragAcceptFiles: (RT) Access violation at address 00EADF60. Write of address 00EADF60 - Line 11"
Any ideas ????
spudman is offline   Reply With Quote
Old 16th March 2009, 09:47   #1563  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Originally Posted by DLynch View Post
Hi Dean,
I moved it to the left intentionally, as there is no way to center it when using bottom offset. I fixed it in build 463. If for some reason footer doesn't look centered - use leading or trailing spaces.
Check the first post of this thread or visit this post.
Old 16th March 2009, 15:01   #1564  |  Link
drelin
Hello,
Iv'e made some tests with the last updates and I've find a minor problem.
Test with 3 short trailers with xmb menus.
With external files (audio tracks, subtitles and chapter).
the files are :
movie1.mkv
movie1.fra.ac3
movie1.eng.ac3
movie1.srt (undetermined for make a forced subtitle track)
movie1.fra.srt
(same for movie2 and movie 3)
1) After compilation, the order track for audio and subtitles are
determined by alphabetique ordrer name of file
ex: movie1.eng.ac3 is the 1st track audio and movie.fra.srt 1st subtitle track.
=> Can you make a option to force the order when multiavchd detect and import the external files
Like add number support track with the file, ex :
movie1.1.fra.ac3 and
movie1.2.eng.ac3
Same thing for subtitle files :
movie1.1.srt and
movie1.2.fra.srt
2) During playback, the language code for audio track are not displayed correctly (no indication) but for the subtitles tracks, it's works fine.
I've checked the m2ts files created and the code language are correct. Same thing for the mpl files.
But the CPLI file are not correct.
With CPLIINF Editor I've correted the tag information and fix the CLPI files.
The result playback works fine and language audio track are correctly dispayed.
3) At last, for the chaptern with external file, the chapter point work fine but in xmb menu only the first chapter point (00:00:00) is created as thumbail not the others ?
For detail informations, see the log file and the chapter file txt.
I've a mistake ?
File Type: txt chapter sample.txt (35 Bytes, 20 views)
drelin is offline   Reply With Quote
Old 16th March 2009, 15:27   #1565  |  Link
deank
deank's Avatar
Chapter makrs are not used in XMB but 5min intervals. You're not doing anything wrong.
I'll see about audio lang codes and order.
Build 465:
* Changed option in Audio/Subtitles:
[x] Add embeded ASS/SRT subtitles
Now it affects SRT, too (not just ASS). I did some tests and it happens that some MKV files have SRT subtitles that tsmuxer fails to process at some point, returning error "Can't convert source text to UTF-16. Invalid chars sequence. " and multiAVCHD will say "Important files missing clpi/mpls...".
This option (if unchecked) will help avoiding such errors.
* Added support for external DTS audio tracks (it seems I've missed this in previous builds)
* Added support for language codes for external audio tracks (the same way as for subtitles): movie-name.eng.ac3 / movie-name.fre.dts....
Old 16th March 2009, 15:54   #1566  |  Link
deank
deank's Avatar
Originally Posted by drelin View Post
Hello,
movie1.2.eng.ac3
It works exactly as you wish - you just needed to test first Name your files with .1. .2. and they will be ordered.
Update to 465 and test for yourself. It should all work.
[16:52:06] Converting mkv file to AVCHD (d:\downloads\__test\the matrix 480p.mkv).
[16:52:06] Detected video: ID#1:V_MPEG4/ISO/AVC:720x480 23.976fps (AR:1.5)
[16:52:06] AR of 16:9 will be set for this title.
[16:52:06] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: eng
[16:52:06] Generating meta file for tsMuxer...
[16:52:06] M2TS stream split set at 4000MiB...
[16:52:06] Adding audiofile (The Matrix 480p.1.fre.dts)
[16:52:06] Adding audiofile (The Matrix 480p.2.eng.dts)
[16:52:06] Adding subtitles (The Matrix 480p.bul.srt) (bul)
[16:52:06] Adding subtitles (The Matrix 480p.eng.sup) (eng)
[16:52:06] Checking for external chapters (d:\downloads\__test\the matrix 480p.txt)...
[16:52:06] Using external chapters...
Old 16th March 2009, 17:10   #1567  |  Link
drelin
I've just test v.465.
It works fine for audio/sub code language display and for the order of track.
Thank for this update.
I've just a strange windows error message during the last steps of compilation.
After "Populating menu structure" -> during "creating menu backgrounds" step this message error apears :
"No Disc in the reader. Insert disc in D reader" with restart / cancel / ignore option. (this is a approximative translation my OS is in french)
Original message in french " Il n'y a pas de disque dans le lecteur. Insérer un disque dans le lecteur D" Recommancer / Annuler / Ignorer.
(D is the Hdd partition where video/audio/subs files sources are stocked).
If I check ignore option (the message appears 3 time one each title ) the compilation finish without error in the log and the result AVCHD is played fine.
Old 16th March 2009, 17:14   #1568  |  Link
deank
deank's Avatar
This is because multiAVCHD is searching drives to find X:\.multiTH folder where mplayer created thumbnails. There is no workaround. Are you sure that D: is HDD but not a DVD-Drive?
Old 16th March 2009, 17:26   #1569  |  Link
drelin
Yes I've make mistake, you're allright D: is DVD-Drive (not HDD).
It's strange with prior version I've never seen this error message ?
Have you a issu for correct this ?
And a question, what is the version used for tsmuxer with multiavchd (in tools folder) ?
I'ts just for know if the Forward/rewind bug correction is integrated (between 1.8.24 or after)
Thank.
Old 16th March 2009, 17:52   #1570  |  Link
deank
deank's Avatar
I'm not sure - you can check yourself in tools folder. The last full-package contains version 26 but if you did exe-updates only, then it is an older one.
About the DVD drive... if you had a disk in the drive, or mplayer created thumbnails in drive C:\ you wouldn't see the error but it is this way for 10 builds now. No - no workaround yet.
Download links are now updated to Build 465 and tsmuxer31 is included in tools.
Old 16th March 2009, 19:25   #1571  |  Link
deank
deank's Avatar
Version log
Here is a complete version history:
[25/12/2008] build  27 - Added mkv support. Major update. Fixed STOP button.
[26/12/2008] build  30 - Proper handling of already multiAVCHD folders
[26/12/2008] build  31 - DVD/BD folder type compatibility fixed! (thanks to zoner)
[27/12/2008] build  41 - tsMuxer options, INI file and MOVE option added!
[27/12/2008] build  44 - Autoupdate added!
[27/12/2008] build  46 - Added tsmuxer font option BOLD
[28/12/2008] build  50 - 20 titles in top menu.
[28/12/2008] build  52 - Destination folder added!
[29/12/2008] build  67 - Progress bar and bugfixes!
[29/12/2008] build  68 - Consistency check!
[29/12/2008] build  74 - Sequental playback and skip top menu selection in SETTINGS TAB.
[31/12/2008] build  77 - Cut start/end (seconds) and Force High@4.1 level added in tsMuxer tab.
[01/01/2009] build  82 - Serious bugfixes. UPDATE!
[02/01/2009] build  84 - Support for multiple SRT subtitles.
[02/01/2009] build  86 - Interface update.
[03/01/2009] build  92 - Buffered copy/progress indicator. Error reporting.
[04/01/2009] build  99 - Added *TS files import and drag/drop to media tab.
[04/01/2009] build 101 - Added drag&drop to program window.
[05/01/2009] build 104 - Lite version / static menu options.
[06/01/2009] build 116 - Custom color/family option in tsMuxer.
[07/01/2009] build 120 - Multiple audiotracks in tsMuxer tab.
[08/01/2009] build 126 - Chapters in tsMuxer tab.
[08/01/2009] build 129 - Setting compliant vertical resolution in tsMuxer tab.
[09/01/2009] build 144 - 40 titles. 20 from top menu and 20 selectable, windows positions save.
[09/01/2009] build 146 - Multiple playlist entries fixed with compliant resolution (not 1st only). Bugfix.
[09/01/2009] build 148 - Fixed audio for titles 6-40.
[09/01/2009] build 159 - Major version. No green bar for PS3. 40 compliant or non-compliant MKVs supported now!
[10/01/2009] build 166 - Fixed broken motion menu. Bugfixes. No-menu scenario fixed.
[10/01/2009] build 171 - Bugfixes. TEMP cannot be ROOT anymore.
[10/01/2009] build 173 - Reset to default added in Settings tab.
[12/01/2009] build 176 - Reference count check for MKV files in Authoring tab.
[12/01/2009] build 179 - Added SSA/ASS support.
[13/01/2009] build 181 - Unique TEMP folder naming.
[13/01/2009] build 182 - Fixed refcount search for non x264 encoded AVCs.
[14/01/2009] build 187 - Fixed MTS/M2TS/TS file processing. Added credits to kaid for the general idea.
[14/01/2009] build 189 - SRT Subtitle support for MTS/M2TS/TS files.
[15/01/2009] build 192 - Fixed playback when no menu is chosen.
[15/01/2009] build 197 - First menu page reflects actual title count if less than six. Bugfixes for NTSC menu.
[16/01/2009] build 201 - Show non-existent titles Option in authoring tab added. It will generate old lite first menu page for titles 1-5
[19/01/2009] build 207 - ImgBurn support. Fixed menu for titles 1-5 when played from DVD/BD.
[19/01/2009] build 212 - Tutorial: http://multiavchd.deanbg.com/tutorial.php
[20/01/2009] build 215 - No restart needed to start another compilation. Files with no audio will be processed.
[21/01/2009] build 218 - Pre-release. Menu structure for next version will be commenced.
[22/01/2009] build 227 - Custom titles (working) and custom background image.
[23/01/2009] build 239 - Fixed start time for first line in SRT subtitles. Bugfixes.
[23/01/2009] build 243 - Custom welcome screen available if custom folder name is used in Settings.
[24/01/2009] build 251 - Fade in-out transitions option in authoring.
[25/01/2009] build 255 - Proper offset for NC movie heights.
[25/01/2009] build 258 - Support for MPEG2 video files added. eac3to option in Settings tab. MP3 to AC3 conversion added for all input file audio tracks.
[25/01/2009] build 266 - Force subtitles option in tsMuxer tab. Support for AVCHDManager.
[26/01/2009] build 267 - Fixed: audio missing if ts/mpg files contain multiple audio tracks. Multiple audio/subtitles supported in mts/ts/mpg.
[27/01/2009] build 269 - Language ID detection for srt files added - if named moviename.ENG.srt
[27/01/2009] build 277 - Progress in title. Abort option in settings. More warning for compilation errors.
[29/01/2009] build 279 - Option to convert TrueHD and DTS-MA/HRA to AC3 if in m2ts/ts/mpeg.
[29/01/2009] build 284 - Custom color for menu titles in Authoring. Custom bitrate for HD audio conversions.
[29/01/2009] build 287 - multiAVCHD will now create only needed AVCHD folders. Should improve SAP compatibility.
[30/01/2009] build 294 - HD audio to LPCM option in Settings.
[30/01/2009] build 298 - Update changed. Bugfixes for HD audio conversions.
[01/02/2009] build 302 - Fixed playlist bug when importing multiple AVCHD folders.
[02/02/2009] build 306 - Slim changes in custom menu. Please REPORT if they work for you!
[04/02/2009] build 313 - Custom menu working (PS3). Please REPORT if they work for you!
[05/02/2009] build 319 - Navigational arrows behaviour fixed!
[05/02/2009] build 322 - Fixed aspect ratio in playlists and clip info files for non 4/3 16/9 input files!
[06/02/2009] build 323 - Interface update.
[06/02/2009] build 325 - Version 2.2. No animated menu. Single download for PAL/NTSC.
[06/02/2009] build 326 - Color and opacity for navigation graphics added.
[07/02/2009] build 330 - Encoding of navigational pages fixed! Option in Authoring.
[07/02/2009] build 330 - Fixed mediainfo not working properly.
[08/02/2009] build 342 - Title editing in MEDIA and MENU tabs.
[08/02/2009] build 344 - Files in input AVCHD will not be moved.
[09/02/2009] build 355 - multiAVCHD.dat update is required!
[09/02/2009] build 356 - Outline color for menu added in Authoring.
[10/02/2009] build 359 - Quit after last title option. Verbose log option. Charset option in tsMuxer tab. MOV support for HDV3+PCM.
[11/02/2009] build 362 - More options in Authoring tab. Bugfixes.
[12/02/2009] build 370 - External audio tracks option. Bugfixes.
[12/02/2009] build 372 - Preview button in Authoring.
[13/02/2009] build 375 - Title font option in Authoring.
[13/02/2009] build 378 - Multiple playlist support and importing multiAVCHD compilations.
[14/02/2009] build 380 - Bugfix for multiple playlists (thanks to FSNAVI). Move files will work for input multiAVCHD folders.
[15/02/2009] build 385 - AVCHD contents will be checked for NC content and fixed.
[17/02/2009] build 391 - Video thumbnails option in Authoring (static). multiAVCHD.dat update is required!
[19/02/2009] build 395 - Fixed navigational arrows for thumbnail menu! Preview for thumbnail menu.
[22/02/2009] build 408 - Drag/drop functionality is restored.
[22/02/2009] build 409 - Fixed title#13 in list menu. DAT update is required.
[23/02/2009] build 410 - Title/credits editable and saved to ini.
[02/03/2009] build 421 - Players will show proper title count.
[05/03/2009] build 430 - XMB style menu. Major version 2.5. DAT update required.
[06/03/2009] build 437 - Bugfixes for XMB style menu and other problems.
[07/03/2009] build 439 - Support for external SUP subtitles.
[08/03/2009] build 440 - Support for PCM audio in MKV.
[09/03/2009] build 444 - AVCHD edit on load option.
[09/03/2009] build 448 - UP/DOWN chapter selection. UP/DOWN AVCHD reorder on load. Classic menu page 2 fixed. Thumnails fixed.
[13/03/2009] build 457 - External chapters are supported if .txt file is named after movie.
[13/03/2009] build 460 - multiAVCHD.dat update required. No support for predefined menu.
[15/03/2009] build 461 - Headline/credits offset fixed.
[15/03/2009] build 462 - PowerDVD playback compatibility fix.
Old 16th March 2009, 22:48   #1572  |  Link
deank
deank's Avatar
It's really pissing me off to receive emails, that I can't reply to, and even more, emails like this one:
От: heimkinofreak....@.....gmx.info
До: dean[aatt]deanbg.com
Дата: 16.03.2009 23:30
Тема: Fw: multi AVCHD Bug
Hey Dean,
the headline in the Menu Properties were never shown since the last updates! Is this a new bug?
I think from Update to Update the Program works badlier.
Its pity.
Greetings
Dieter
And about his problem: USE PROPER OFFSET FOR HEADLINE in Author menu. The value is in PIXELS and is for font baseline, so a value of 0-10 will make headline not visible.
I replied to the email and I always get: <heimkinofreak@gmx.info> (mx0.gmx.de: 550-5.1.1 {mx012} <heimkinofreak... @ ...gmx.info>... Sorry, your envelope sender has been denied: The recipient 550 5.1.1 does not want to receive mail from your address.)
Old 16th March 2009, 22:57   #1573  |  Link
gevmack23
ok i had success on a lot of files to play, but lately i had sound but no video, i made sure resolution was 4.1 compliant, what could i have done wrong?
gevmack23 is offline   Reply With Quote
Old 16th March 2009, 22:59   #1574  |  Link
deank
deank's Avatar
Lately? With ALL FILES? With what player?
Do old files get processed wrong now?
There are millions of reasons... as many MKV files are out there.
Old 16th March 2009, 23:18   #1575  |  Link
gevmack23
they were two new mkv files i got. I also put a mkv file that i had success with on the same project and that one worked. All the thumbnails showed a picture at the corresponding times on the menu screen, but when i click on the new ones no video. Alone they play on vlc media player, but slightly choppy; it seems all my m2ts and mkv files play choppy on vlc. Right now im using ts muxer to see if they will play individually through blu-ray folders
Old 17th March 2009, 00:00   #1576  |  Link
gevmack23
i used tsmuxer and the m2ts file did the same as multiavchd, no video, but sound. it must be a bad file or something
Old 17th March 2009, 20:46   #1577  |  Link
jayman
I keep getting "mplayer stopped working correctly" in a box that pops up then Windows is checking for a solution anytime I try multiple titles. Anyone else see this? I was able to continue making the multibd after hitting cancel on the box. There was however a large BD with 20 titles that the program just paused at around 70% making the menu and wouldn't continue.
jayman is offline   Reply With Quote
Old 17th March 2009, 21:27   #1578  |  Link
deank
deank's Avatar
I get this error, too. With 24 titles I'll get at least 4 or 5 errors and sometimes when the error doesn't appear I need to END mplayer.exe TASK in task manager.
It is a known problem with mplayer and I'm still trying to find a workaround.
So, if multiAVCHD gets to the point of creating title/chapters thumbnails and it takes more than 5 seconds to move to the next chapter (% update) it means that mplayer needs forced close with end task. multiAVCHD tries other ways to generate thumbnails and will continue - so your compilation won't suffer when such errors occur.
Old 18th March 2009, 10:47   #1579  |  Link
deank
deank's Avatar
Build 467:
[x] Use Directshow (XMB)
option is added in Author tab.
If checked, multiAVCHD will try to create thumbnails using directshow first. You will need decoders/splitter installed to use this option. If used - thumnails will be properly generated and no mplayer errors will occur. It is a bit slower than mplayer but works 100%. On my machine it takes about 15 minutes to create XMB menu with 24 titles. After all we're talking about extracting over 240 thumnails/frames from these m2ts files.
If Directshow fails, multiAVCHD will try with mplayer - as before.
Dean
Old 18th March 2009, 13:49   #1580  |  Link
jayman
great thanks.
