9th July 2005, 01:11 | #282 | Link | |||
I would suggest an extra window for that. There should be a box to put in the percentage for the comptest. A box for the desired filesize and for the bitrate (radio button style, so that only one can be selected). A config button to choose the x264 settings. Then you would take the input avs add a line to it (selectevery(300,15) for example, depending on the given percentage) and start the test. Quote:
I'd love to see a on click version for that. Taking a .ts file running it through ProjectX, then making a d2v file, then creating an avs with desired resolution and encoding it to .mp4. But maybe there isn't much demand for that? |
9th July 2005, 01:22 | #283 | Link | |
Sorry for bringing this up in this thread. It only has slightly to do with MeGUI. |
9th July 2005, 01:28 | #284 | Link | |
clueless n00b
Don't you have a whole bunch of other things that need to be done with digital TV streams? Like cutting. That's definitely no job for MeGUI.. it's a video and audio encoding application.
9th July 2005, 02:14 | #285 | Link |
I posted a screenshot. It shows different settings when selecting turbo in the commandline. Notice the subme=1 part. In the GUI there is number of reference frames = 3 selected.
9th July 2005, 02:18 | #286 | Link | |
clueless n00b
9th July 2005, 03:28 | #287 | Link | |
Public Shared Function IsValidFileSystemName(ByVal name As String) As Boolean For i As Integer = 0 To name.Length - 1 Dim charValue As Char = name.Chars(i) Select Case charValue Case """"c, "*"c, "/"c, ":"c, "<"c, ">"c, "?"c, "\"c, "|"c Return False End Select If AscW(charValue) < 32 Then Return False End If Next Return True End Function Code:
public static bool IsValidFileSystemName(string name) { int num2 = name.Length - 1; for (int num1 = 0; num1 <= num2; num1++) { char ch1 = name[num1]; char ch2 = ch1; if (((((ch2 == '"') || (ch2 == '*')) || (ch2 == '/')) || ((ch2 == ':') || (ch2 == '<'))) || (((ch2 == '>') || (ch2 == '?')) || ((ch2 == '\\') || (ch2 == '|')))) { return false; } if (ch1 < ' ') { return false; } } return true; } Code:
GetType(System.IO.Path).InvokeMember("CheckInvalidPathChars", _ Reflection.BindingFlags.InvokeMethod Or _ Reflection.BindingFlags.NonPublic Or _ Reflection.BindingFlags.Static, _ Nothing, Nothing, New String() {"filename"})
9th July 2005, 05:16 | #288 | Link | |
9th July 2005, 08:21 | #290 | Link |
Help please - sometimes I need to recode very quickly, certainly I use mencoder for this purpose, prompt me, what options are desirable for the maximal speed. (though on mine celeron 1.7 it likely is ridiculous)
9th July 2005, 08:52 | #291 | Link |
@ stax:
Great! One of my most important problems with new programming languages being learned is: How is that function named, which will do what I want - and does it already exist at all, or do I have to write myself? Syntax can be learned in a snap, but the "word pool / vocabulary" is often sooooo different... you are lost without well referenced help. |
9th July 2005, 11:15 | #292 | Link | |
@LigH If you learn .NET I highly recommend to use Visual Studio 2005, the Express Beta Versions are free and work very well (until May 2006) and will be very cheap (50$) after that. They are designed for beginners. I use VS 2005 Express exclusively and many new features like generics extensively, there are tons of really cool new features though a beginner much likely struggles with the basics.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 9th July 2005 at 11:52. |
9th July 2005, 11:40 | #293 | Link |
clueless n00b
Alright, so video cutting could be done easily.. and be analogue to zones. But what about audio? You cannot cut audio at an arbitrary position, it needs to be aligned with an audio frame or you'll get corrupt audio. And say we're using AC3 audio and incurr an almost 30ms delay (size of an audio frame) for each cut.. the audio would get way off base.
And I wasn't aware that besweet supported audio cutting.. I thought that was something for besplit. I wrote my own filename code similar to the above, but it returns a string with a valid filename. I replace all invalid character by _<2 letter shortcut to the invalid char>_, so for instance * turns into _st_, < turns into _lt_, etc. I think it's reasonable to assume that users will not have a profile using such convention and another one using the invalid character so that there'll be two files named the same. @lesnick: select 2 pass first pass, check turbo, check the commandline. Basically it's no MV options, subq 1, the lowest me method. But, if you use that for the second pass quality will be visibly degraded. Plus, perhaps you're using one of the other 3 codecs <hint>it is important to tell us right when asking the question exactly what it is you want</hint>
9th July 2005, 11:56 | #294 | Link | |
9th July 2005, 12:02 | #295 | Link |
meGUI 0.2.1.1 was crashed if push "config" for XVID
----------------------------------------- See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IndexOutOfRangeException: Index was outside the bounds of the array. at MeGUI.CommandLineGenerator.generateXviDCommandline(String mencoderPath, xvidSettings xs, String input, String output) at MeGUI.CommandLineGenerator.generateVideoCommandline(MeGUISettings settings, VideoCodecSettings vSettings, String input, String output) at MeGUI.xvidConfigurationDialog.showCommandLine() at MeGUI.xvidConfigurationDialog.dropDownBox_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e) at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value) at MeGUI.xvidConfigurationDialog.set_CodecSettings(xvidSettings value) at MeGUI.MeGUI.videoConfigButton_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll ---------------------------------------- MeGUI Assembly Version: 1.0.2016.3771 Win32 Version: 1.0.2016.3771 CodeBase: file:///E:/My%20things/Prog/meGUI/MeGUI.exe ---------------------------------------- System.Windows.Forms Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll ---------------------------------------- System Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- System.Drawing Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll ---------------------------------------- System.Xml Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll ---------------------------------------- bz6gxvzg Assembly Version: 0.0.0.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- ************** JIT Debugging ************** To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog. ---------------------------------------------------- |
9th July 2005, 12:21 | #296 | Link | ||
clueless n00b
9th July 2005, 15:15 | #297 | Link | |
clueless n00b
9th July 2005, 17:13 | #298 | Link | |
I get the same error,Using windows2000 |
9th July 2005, 22:59 | #299 | Link |
clueless n00b
@towerblocks: lesnick already reported that bug and I confirmed it.. on the very same page nontheless.. please take a couple minutes to read posts since the last release for any issues that might already have been reported. Thank you.
10th July 2005, 11:30 | #300 | Link | |
something i'm doing wrong here's the log. Next job job3 is a video job. encoder commandline: "C:\Megui.2.1.1\mencoder.exe" "C:\Documents and Settings\Administrator\Desktop\buf.avs" -ovc xvid -o NUL: -passlogfile "C:\Documents and Settings\Administrator\Desktop\Megui.2.1.1\logs\2pass.log" -xvidencopts pass=1:bitrate=963:max_key_interval=250:vhq=4:chroma_me:trellis:min_iquant=1:max_iquant=2:min_pquant=1:max_pquant=2:min_bquant=1:max_bquant=2:keyframe_boost=100:kfthreshold=1:kfreduction=20:chroma_opt:zones=1,q,1/60631,q,20 successfully set up video encoder and callbacks for job job3 ---------------------------------------------------------------------------------------------------------- Log for job job3 Option xvidencopts: Unknown suboption zones |
