23rd April 2008, 10:59 | #1121 | Link |
I'm having a problem getting TSMuxer to recognise a standard DTS track, it says "Can't detect stream type: I:\potc.dts"
The DTS file is created by eac3to 2.41, converted from the Pirates Of The Caribbean PCM track. The DTS file plays fine in Media Player Classic. I've uploaded the first 50MB of it here. |
23rd April 2008, 11:38 | #1123 | Link | ||
Caped Crusader
VC1/PCM 5.1 Surround (48kHz/24-Bit/6.9mpbs) Mpeg2/DD 5.1 I've only tried 3 so far. One thing I've noticed is sometimes there is a slight pause, in playback, at the transition to next chunk of m2ts. But I'm using an old hard drive hooked up via an ide to usb convertor, and I think this might be causing this. Quote:
Cheers. |
23rd April 2008, 13:04 | #1124 | Link | |
23rd April 2008, 13:13 | #1125 | Link |
Can't add EyeTV-Export: "Can't detect stream type"
While trying to add an mp4-file which has been exported from EyeTV (Mac TV-Software) tsMuxeR 1.7.6 states "Can't detect stream type".
Playback in VLC is ok. It's Info-Window says it's an avc1 encoded video stream with 1920*1080@25fps and 2 Channel mp4a Audio, 48khz, 16 bit, 1536 kb/s. I could upload the file (21 MB) somewhere so the/a developer might check it out. campari |
23rd April 2008, 13:30 | #1126 | Link | |
New version 1.8.0 is ready:
http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.0(b).zip - Conversion from SRT to PGS added. Source SRT text file can be in any unicode format: UTF-8, UTF-16 or UTF-32. Also, SRT tracks from MKV container can be imported. Please, do not public link to version 1.8.0 in other sites now (today and tomorrow), before I need to make sure that version works stable. campari212 Quote:
23rd April 2008, 13:44 | #1127 | Link | |
Caped Crusader
I found this post and app that corrects the black level for SkyHD DVB TS captures, and was wondering if it could be added to your app ? http://www.hdd-player.de/phpBB2/inde...8&topic=2779.0 |
23rd April 2008, 13:57 | #1128 | Link | |
many thanks for that works a treat although I did manage to combine with TSsplitter to but is not as quick to mikegee2 I just ignore the errors muxed the video , AC3 and english PGS on each or the 2 movie streams 0000.m2ts and 00001.m2ts and then added the first , appended the second now have one complete movie stream of 27.5GB ish plays in nero and on my media tank no problem |
23rd April 2008, 14:43 | #1130 | Link |
23rd April 2008, 14:45 | #1131 | Link | |
dd if=input_file of=output_1k_file bs=1k count=1 "of" means output file "bs" means block size, which can use k, m, g suffixes "count" means how many blocks of the above size (also may use suffixes) |
23rd April 2008, 15:18 | #1132 | Link | |
Can't convert UTF-8 to UTF-16. Invalid source text http://www.mediafire.com/?dxnlnqf8xym
23rd April 2008, 16:12 | #1134 | Link | |
Atak_Snajpera
23rd April 2008, 16:38 | #1136 | Link | |
23rd April 2008, 17:10 | #1137 | Link |
Atak_snajpera
Open a file in notepad. When select menu item "Save as". File subtitles.8.srt had encoding type UTF-8, file subtitles.9.srt had encoding type "ANSI". Current version can open only UTF-8/16/32 files, but not ANSI. Last edited by roman76r; 23rd April 2008 at 17:12. |
23rd April 2008, 17:44 | #1138 | Link | |
23rd April 2008, 18:26 | #1140 | Link |
srt PGS does not work with my box
@roman
The conversion with .srt is ok but it does not work with my box (freebox, french adsl box) because it does not support PGS. On the other hand, it supports the dvdsub. Do you plan to support this format ? Last thing, a big about your tool ! it is THE tool for me ! Musidora |
tsmuxer |
