27th June 2011, 03:50 | #17601 | Link |
@Underground78 and other developers
Then it was: - Never - Always - While Playing Now it is: - Never - Always - While Playing - While Playing Video Can do better than three lines? Еxample: - Never - Always - While Playing Video |
27th June 2011, 04:13 | #17604 | Link | |
http://mpc-hc.svn.sourceforge.net/vi...&revision=3247 It doesn't really hurt anybody to just keep it there, unless there is a better way to implement. Personally, I do use the video only on top mode. Last edited by namaiki; 27th June 2011 at 04:17. |
27th June 2011, 06:14 | #17605 | Link |
Some people might want to keep the player on top when playing audio files (for example if they want to see informations about the track) and not only for video files. I don't think having a 4 menu items really matters ...
27th June 2011, 10:52 | #17606 | Link |
Isn't native PCM support (MKV) gonna be fixed? I tried latest nightly and I still get same error as before, http://pastebin.com/WknqTs3P
Yes, it works using LAV splitter but then I can't change between subtitles (just enable/disable). I tried Haalii Media Splitter but then I get out of sync for PGS subtitles (MKV). It says in the bug report that you should change audio render, it doesn't help. It also says some sound cards don't support PCM. So what supports it then? Some $200 sound card? Why can't a MPCHC splitter be added that supports PCM and doesn't have any subtitle issues like LAV and HMS? http://sourceforge.net/apps/trac/mpc-hc/ticket/665 |
27th June 2011, 13:59 | #17608 | Link |
In general yes, but ...
PCM = "Pulse Code Modulation" means: raw, uncompressed samples. But samples may be represented in many different formats, and not all formats need to be supported by all soundcards. There are integer samples (WAV 2CC: 0x0001), where 16 bit is the most common and usual resolution, but 24 bit or 32 bit samples are possible too (let's forget about 8 bit). Video DVDs might even have 20 bit samples in a rather strange interleaving (not supported by WAV). Furthermore there are floating point samples (WAV 2CC: 0x0003) in IEEE single or double precision format (32 or 64 bit). IIRC, the "Microsoft Wave Mapper" was the special ACM "codec" of VfW to convert sample formats between WAV storage and sound card hardware support on-the-fly. DirectShow will have a similar special filter. |
27th June 2011, 14:17 | #17609 | Link | |
Videoplayer should have one additional option. The second option is excess. Now we have a bug with option Options...->Player->Other->Always in top |
27th June 2011, 14:47 | #17610 | Link |
I also suggest to associate Ctrl+A with "while playing video" instead of "always". That is more useful imho.
MPC-HC 2.2.1 |
27th June 2011, 20:06 | #17611 | Link | ||
I can do that to fix the bug: |
27th June 2011, 20:15 | #17612 | Link | |
They are even less clear when there's no tooltip or any description whatsoever... The dropdown menu makes more sense, especially if there are more than 3 choices to be made of. |
27th June 2011, 20:32 | #17613 | Link |
I would suggest to just remove it from the options page. A drop down looks ugly there. I also do not see any need to have the same option in two places. Having it in the View menu is the natural place.
MPC-HC 2.2.1 |
27th June 2011, 20:46 | #17615 | Link |
If everything remains as it is, it is necessary to correct the settings dialog. The order of options not need to change.
fixed in r3271 MPC-HomeCinema 1.5.2.3271 (x86) Last edited by v0lt; 27th June 2011 at 21:04. |
28th June 2011, 05:55 | #17618 | Link |
I will do something but let us discuss that before doing anything ... The combobox fix was already ready when I posted the screenshot but as some people seem to think there is no need to have the options twice, I will need to ask Tetsuo and/or XhmikosR opinion about that.
28th June 2011, 10:03 | #17620 | Link |
MPC-HC Project Manager
What about this
Dropdown: * Never * Always * Only during playback Checkbox: [] Do not apply "always on top" for audio files. We could change that checkbox to "always on top during playback"
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
