Old 23rd June 2011, 21:37   #17561  |  Link
Underground78
Underground78's Avatar
Buffer option works now. But animation option still broken.
Problem found, I was not reading the same key I was writing in the registry so the saved value was not reloaded ... I hope it is ok now : VSFilter_v3.7z !
Underground78 is offline
Old 23rd June 2011, 22:39   #17562  |  Link
Midzuki
Unavailable
Midzuki's Avatar
httpwww.mediafire.comoukb4ur3rk0fxzy cannot be OK
Midzuki is offline
Old 24th June 2011, 02:21   #17563  |  Link
namaiki
http://www.mediafire.com/?oukb4ur3rk0fxzy
Regarding the "allow animation when buffering" checkbox-
In v3: Tick means animation is disabled when buffering, unticked means buffer with animation.
So, you could either reverse the function of the checkbox or reverse the displayed name/action of the checkbox. To disable buffering, user can change 'sub pictures to buffer' to '0'.
namaiki is offline
Old 24th June 2011, 04:58   #17564  |  Link
Midzuki
Unavailable
Midzuki's Avatar
@namaiki: Thanx
Midzuki is offline
Old 24th June 2011, 06:19   #17565  |  Link
Underground78
Sorry for the link, I still don't understand how this happened ...
I have kept the same name than in MPC-HC and reversed the action of the checkbox: VSFilter_v4.7z.
Is that ok ? It was done like that in MPC-HC so I have kept it the same way.
Old 24th June 2011, 06:31   #17566  |  Link
namaiki
Everything seems to work as it should. Awesome work!
I think it should be fine as long as animation is enabled by default. Also, I might recommend buffer set to 4 subpictures by default due to flickering subtitles on 3 when there is more than a single subtitle line on the screen.
namaiki is offline
Old 24th June 2011, 10:53   #17567  |  Link
clsid
Working OK now, so time to commit.
Changing buffer size to 4 should be fine. Please change it in MPC as well. The old default in VSFilter was 10, but I don't know if a larger buffer than 4 has much real benefit.
I did notice a crash when changing the settings during playback. Perhaps that can be solved by reading the setting into two vars, one for usage during playback, and one purely for the GUI. So no real-time update of the setting.
I did some basic benchmarks to test the performance of subs. These numbers were gathered with ProcessExplorer and from just one run per test, so take results with a grain of salt.
I measured the total CPU time used by MPC while playing a 720x480 H.264 clip with subtitles that have karaoke effects. Clip duration 1m46s.
Without subs
6.74 seconds
New VSFilter, Buffer = 0
12.38
VSFilter 2.39, Buffer = 0
13.09
New VSFilter, Buffer = 4
10.54
New VSFilter, Buffer = 4, Animation on
13.81
New VSFilter, Buffer = 10
11.01
New VSFilter, Buffer = 10, Animation on
13.76
VSFilter 2.39, Buffer = 10
10.78
Conclusions:
- Heavy subtitles can have a big performance impact. Up to 50% of the total CPU usage.
- Animation with buffering uses the most CPU time. Followed by Animation without buffers. Buffering without animation uses the least CPU time.
- Animation can use up to 80% more CPU time than no animation.
- New VSFilter is not much faster than the old one. I expected a bigger difference with the recently added performance tweaks. Perhaps the VSFilterMod additions have some negative effect on performance.
I might do another test with basic SRT subs later to measure performance in case of a non-animated sub.
MPC-HC 2.1.7.2
clsid is offline
Old 24th June 2011, 14:00   #17568  |  Link
tetsuo55
MPC-HC Project Manager
That is kind of disappointing.
please do the basic SRT test.
tetsuo55 is offline
Old 24th June 2011, 14:43   #17569  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Well, unfortunately VSFilter has been and will continue to be slow. No real news there. And I kind of expected there to be not much of real performance-up, although the "multithreaded VSFilter" guy is relatively enthusiastic, which is a good thing.
Anyways, if we want real speed-ups, someone needs to make fontconfig less awful on Windows so we can use libass instead :3
[I'm human, no debug]
JEEB is offline
Old 24th June 2011, 15:03   #17570  |  Link
clsid
With a quickly manually created SRT I get results between 7,5 and 7,9 seconds. So those differences are small.
Btw, all the above tests were done with the standard EVR renderer.
EVR CP has a very nasty 'bug' that makes it consume CPU cycles even when paused or when playback has stopped. Hopefully that can be given some priority to fix.
I also tried with the internal sub renderer (and EVR CP instead of EVR), but I got weird results. Both SSA and SRT have same CPU time of 17.0s (buffer 4 + anim), no subs gave 14.4. The measurement method might be inaccurate.
MPC-HC 2.1.7.2
clsid is offline
Old 24th June 2011, 15:16   #17571  |  Link
namaiki
I believe it's because it's continually scanning the screen's refresh rate.
There is the 'Apply changes immediately' checkbox in the 'Misc' tab. I suppose that could be disabled by default. (please don't get rid of it)
namaiki is offline
Old 24th June 2011, 17:49   #17572  |  Link
Underground78
So everybody agrees with that:
If everybody does, I will commit the changes and also update default settings for MPC-HC.
Edit : Here what MPC-HC does to choose if it enables or not animation when buffering :
		bool bAllowAnimationWhenBuffering = true;
		SYSTEM_INFO SysInfo;
		GetSystemInfo(&SysInfo);
		if (SysInfo.dwNumberOfProcessors < 3) {
			bAllowAnimationWhenBuffering = false;
Maybe I should keep something like that ? Although I am not sure it is really useful to check the number of processors if VSFilter is not multithreaded ?
Old 24th June 2011, 18:14   #17573  |  Link
fastplayer
Assuming that the code is actually not multithreaded, this sure looks like a lazy man's performance categorization. It is pure nonsense IMO.
fastplayer is offline
Old 24th June 2011, 18:23   #17574  |  Link
Underground78
Yeah but I need to be sure the code is not multithreaded at all.
Old 24th June 2011, 18:27   #17575  |  Link
fastplayer
Even if it was, it wouldn't be dependent on this setting at all. There's no variable that saves the number of cores and uses it subsequently throughout the code.
We had similar nonsense in ffdshow that Stargazer removed when he cleaned up the colorspace conversion code.
Old 24th June 2011, 18:42   #17576  |  Link
Underground78
I am not sure to understand, it is just an hint for the user I guess so why would you need a variable to save the number of core ? However I am quite sure it was wrongly chosen and I will probably delete it.
Old 24th June 2011, 18:47   #17577  |  Link
fastplayer
The code basically says that anything with less than 3 cores is not suitable of running sub animations which is total nonsense of course. Especially considering that the code itself is not multithreaded at all.
My suggestion:
r.fSPCAllowAnimationWhenBuffering = !!pApp->GetProfileInt(IDS_R_SETTINGS, _T("SPCAllowAnimationWhenBuffering"), bAllowAnimationWhenBuffering);
replace with
r.fSPCAllowAnimationWhenBuffering = !!pApp->GetProfileInt(IDS_R_SETTINGS, _T("SPCAllowAnimationWhenBuffering"), true);
Old 24th June 2011, 18:50   #17578  |  Link
clsid
Disabling that option is not a good idea. It is useful for seeing effects of font and size changes.
The crash only happens with the two new settings. Just do not apply those changes directly.
The rationale behind the number of processors check is that a CPU with multiple cores is usually a reasonably fast one.
That could be made conditional based on the playback state. Maybe the scan interval can be increased as well to lower CPU usage. Isn't the refresh rate typically a constant value? Except maybe at the start if rate changing is enabled.
MPC-HC 2.1.7.2
clsid is offline
Old 24th June 2011, 20:25   #17579  |  Link
Underground78
I've changed the code so that those two settings are not applied immediately : VSFilter_v5.7z. I have also change the default to 4 and true but I can still change this.
This is how I understood it at first that's why I am not sure what to do. Even if it is a test for lazy, we may not want to always enable this setting.
Old 24th June 2011, 23:08   #17580  |  Link
clsid
Working fine now.
The core detection code is only used for the default setting. It is only used if the value was not yet set in the Registry/INI.
MPC-HC 2.1.7.2
clsid is offline
dxva, h264, home cinema, media player classic, mpc-hc
