8th October 2005, 19:59 | #681 | Link |
Doom9,
I'm having an issue with encoding my HD caputres to Xvid using MeGui... First, here's my log: Code:
Generating jobs. Desired size: 2398131200 bytes Encoded audio file is present: D:\capture.ac3 It has a size of 116818944 bytes. No audio encoding. Calculating desired video bitrate directly. Setting video bitrate for the video jobs to 7498 kbit/s Setting desired size of video to -2013655040 bytes Next job job1-1 is a video job. encoder commandline: "C:\MP4 Encoding\Mplayer\mencoder.exe" "D:\1.avs" -ovc xvid -o NUL: -passlogfile "2pass.log" -xvidencopts pass=1:bitrate=7498:max_key_interval=300:vhq=4:qpel:chroma_me:quant_type=mpeg:par=ntsc169:trellis:keyframe_boost=100:kfthreshold=1:kfreduction=20:overflow_control_strength=20:max_overflow_improvement=20:max_overflow_degradation=20 successfully set up video encoder and callbacks for job job1-1 ---------------------------------------------------------------------------------------------------------- Log for job job1-1 xvid: bitrate setting is ignored during first pass ---------------------------------------------------------------------------------------------------------- job job1-1 has been processed. This job is linked to the next job: job1-2 Next job job1-2 is a video job. encoder commandline: "C:\MP4 Encoding\Mplayer\mencoder.exe" "D:\1.avs" -ovc xvid -passlogfile "2pass.log" -xvidencopts pass=2:bitrate=7498:max_key_interval=300:vhq=4:qpel:chroma_me:quant_type=mpeg:par=ntsc169:trellis:keyframe_boost=100:kfthreshold=1:kfreduction=20:overflow_control_strength=20:max_overflow_improvement=20:max_overflow_degradation=20 -o "D:\1.avi" -of avi -ffourcc XVID successfully set up video encoder and callbacks for job job1-2 ---------------------------------------------------------------------------------------------------------- Log for job job1-2 desired video bitrate of this job: 7498 kbit/s - obtained video bitrate: 6251.28895217316 kbit/s ---------------------------------------------------------------------------------------------------------- job job1-2 has been processed. This job is linked to the next job: job1-3 Next job job1-3 is a mux job. mp4box commandline: "C:\MP4 Encoding\Mplayer\mencoder.exe" "D:\1.avi" -ovc copy -oac copy -audiofile "D:\capture.ac3" -mc 0 -noskip -o "D:\\1-muxed.avi" successfully set up muxer and callbacks for job job1-3 ---------------------------------------------------------------------------------------------------------- Log for job job1-3 MEncoder dev-CVS-050813-01:18-3.4.4 (C) 2000-2005 MPlayer Team CPU: Advanced Micro Devices Athlon MP/XP/XP-M Barton (Family: 6, Stepping: 0) Detected cache-line size is 64 bytes CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 0 SSE2: 0 Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE 86 audio & 201 video codecs success: format: 0 data: 0x0 - 0x715a4032 AVI file format detected. AVI: ODML: Building odml index (1 superindexchunks) AVI_NI: No audio stream found -> no sound. VIDEO: [XVID] 1280x720 12bpp 23.976 fps 6246.5 kbps (762.5 kbyte/s) VIDEO: [XVID] 1280x720 12bpp 23.976 fps 6246.5 kbps (762.5 kbyte/s) libavformat file format detected. [V] filefmt:65536 fourcc:0x44495658 size:1280x720 fps:23.98 ftime:=0.0417 videocodec: framecopy (1280x720 12bpp fourcc=44495658) Building audio filter chain for 0Hz/0ch/s16le -> 0Hz/0ch/??... audiocodec: framecopy (format=2000 chans=0 rate=0 bits=0 bps=0 sample-0) Writing AVI header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. File not found: 'frameno.avi' Failed to open frameno.avi ---------------------------------------------------------------------------------------------------------- 1. Capture .ts stream using MyHD. 2. Cut commercials using HDTV2MPEG2 and save back to .ts. 3. Demux .ts through Projectx. 4. Index using DGIndex 1.21. 5. Create Avisynth Script using MeGui... Script below mpeg2source("D:\1.d2v") SelectEven() Decimate(cycle=5) 6. Load avs into MeGui for Automated 2pass with Turbo Checked, 2 bframes, Qpel, Overflows set to 20, VHQ 4, VHQ for B Checked, Chroma Motion, Closed GOP. 7. Hit Auto Encode, setting my desired bitrate manually. Check add audio stream and then add the ac3 that ProjectX created. 8. Go to Jobs and Start. Now the 1st and 2nd Pass seem to go fine. But it crashes at the mux stage. When I open up the resulting .avi that MeGui had created in VirtualdubMod, I get Video Read Errors and no frames are displayed. I've done dvd encodes using Xvid in MeGui with no problem. But I've tried two HD encodes with the same result. Is there a flaw in my procedure or did I uncover a bug? Thanks for any help. btw... using MeGui 0.2.2.4... haven't gotten around to upgrading yet but it doesn't seem as if you've changed anything that would affect my problem. |
9th October 2005, 00:08 | #682 | Link | |
-override the output MeGUI suggests when you press AutoEncode, or -don't encode in a root directory. The bug should hopefully be fixed next version. |
9th October 2005, 00:18 | #683 | Link | |
The main reason I ask is because, I'll run my encode again, but like I said its an HD file and I don't want to occupy my computer for 18hours if I don't have to |
9th October 2005, 00:46 | #684 | Link | |
9th October 2005, 01:34 | #686 | Link |
Just wanted to report back on some further testing.
I ran ProjectX on the source again, but only processed 17 second of the file. Created my .d2v on the file and set up the same script as outline above. Added my audio stream also as outlined above and started my queue. I followed Berrinam's advice and saved the output to a different directory. This time the video output came out clean so Berrinam's quick workaround seems to have solved that problem. However, the muxing stage still did not work. Here's the log for that part of the job. Code:
---------------------------------------------------------------------------------------------------------- job job1-2 has been processed. This job is linked to the next job: job1-3 Next job job1-3 is a mux job. mp4box commandline: "C:\MP4 Encoding\Mplayer\mencoder.exe" "D:\Test\video.avi" -ovc copy -oac copy -audiofile "D:\capture.ac3" -mc 0 -noskip -o "D:\debug.avi" successfully set up muxer and callbacks for job job1-3 ---------------------------------------------------------------------------------------------------------- Log for job job1-3 MEncoder dev-CVS-050813-01:18-3.4.4 (C) 2000-2005 MPlayer Team CPU: Advanced Micro Devices Athlon MP/XP/XP-M Barton (Family: 6, Stepping: 0) Detected cache-line size is 64 bytes CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 0 SSE2: 0 Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE 86 audio & 201 video codecs success: format: 0 data: 0x0 - 0xfa078a AVI file format detected. AVI_NI: No audio stream found -> no sound. VIDEO: [XVID] 1280x720 12bpp 23.976 fps 7476.6 kbps (912.7 kbyte/s) VIDEO: [XVID] 1280x720 12bpp 23.976 fps 7476.6 kbps (912.7 kbyte/s) libavformat file format detected. libavformat file format detected. [V] filefmt:3 fourcc:0x44495658 size:1280x720 fps:23.98 ftime:=0.0417 videocodec: framecopy (1280x720 12bpp fourcc=44495658) Writing AVI header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Writing AVI index... Fixing AVI header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Video stream: 7476.642 kbit/s (934580 bps) size: 16371526 bytes 17.518 secs 420 frames ---------------------------------------------------------------------------------------------------------- |
9th October 2005, 01:44 | #687 | Link |
Just noticed something while looking for something else on the forums.
Could this be my problem on the video end? http://forum.doom9.org/showthread.php?t=101079 Is that a known issue? My resulting file from my first encode was 1.78 gb. |
10th October 2005, 02:07 | #688 | Link |
Hates all his encodes
Hmm... Is there a registry setting that .NET is not installing perhaps? When I uninstalled the package, nothing actually changed; same error as before. Could this mean the .NET package isn't even being recognized?
http://thevideophile.blogspot.com/ Watch and be amazed by my frustration over the video world! |
10th October 2005, 10:22 | #689 | Link | |
BeHappy/MeGUI developer
2) I have enought HDD space for it
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
11th October 2005, 05:23 | #690 | Link | |
As a request from this post:
http://forum.doom9.org/showthread.ph...438#post722438 Quote:
12th October 2005, 02:26 | #692 | Link |
So when using the MP4MUX and besweet (to make AAC+AVC) the DELAY -922 SHOULD work - right??? That means it will make the audio start sooner?
This is wrong on my HDTV OTA transport streams. Can I just adjust this by renaming the AAC/MP4 audio file to -0ms??? |
12th October 2005, 07:52 | #693 | Link |
@sjchmura: Please be more clear. You haven't said what is wrong with the delay (whether it is changing at all, being removed, overcompensated, etc), and more importantly, you haven't said what you did which resulted in it not working
As a side note, MeGUI handles delays by fixing them upon encoding the audio. If you didn't set the delay when you encoded the audio, then I believe it won't work. |
12th October 2005, 17:07 | #694 | Link | |
14th October 2005, 16:36 | #696 | Link |
I have an issue using AutoEncode button since version 0.2.2.6
Generating jobs. Desired size: 1433600 bytes The second pass job has a desired final output size of 1433600 bytes and video bitrate of 1637 kbit/s The size of the first audio track is 135051582 bytes Desired video size after substracting audio size is -132172 Setting the desired bitrate of the subsequent video jobs to -163 kbit/s Next job job1-2 is a video job. encoder commandline: "C:\Programmi\x264\x264.exe" --pass 1 --bitrate -163 --stats "C:\Scambio\Elaborazione Video\Febbre\Febbre_movie.stats" --ref 5 --mixed-refs --bframes 3 --subme 6 --weightb --analyse all --8x8dct --me umh --threads 2 --cqmfile "C:\Programmi\x264\eqm_avc_hr.cfg" --progress --no-psnr --output NUL "C:\Scambio\Elaborazione Video\Febbre\Febbre_movie.avs" successfully set up video encoder and callbacks for job job1-2 |
15th October 2005, 13:26 | #698 | Link |
Perhaps I have founded another bug; in the audio encoder configuration it seems to be impossible setting a negative value in the delay correction textbox. I suppose that this textbox has a pattern that accept only numeric values but in this case is not possible to digit the sign minus.
15th October 2005, 18:25 | #699 | Link |
Am I missing something or it's just MeGUI's rendered H264 files that are NOT COMPATIBLE with QuickTime7 ? I simply can't play any of the rendered MP4[H.264,AAC] on QuickTime. Please try to give me some hints, thxs a lot. |
15th October 2005, 18:38 | #700 | Link |
Mr. Sandman
It's not megui and neither x264/h.264 etc...
It's QuickTime fault, coz it doesnt follow the standards.
