Old 7th May 2020, 18:50   #1  |  Link
Georgiana
Effects added to images
Hi All,
I attached 2 examples of effects added to images.
The links for images are:
https://postimg.cc/SYCPPPvb
https://postimg.cc/rR1hjrD8
(thank you very much StainlessS for the suggestion!)
Have anyone an idea about how can I get those effects on a png image? What filter/function/plugin should I use in order to get a similar effect?
Thank you!
Last edited by Georgiana; 8th May 2020 at 16:42. Reason: suggestion for upload of images
Georgiana is offline   Reply With Quote
Old 7th May 2020, 18:53   #2  |  Link
You can post images on PostImage.org [without an account - does not expire] and they are available immediately.
[Use either Thumbnail for forum, or Image for forum]:- https://postimages.org/
Just paste the link in your post. [attached images require moderator approval and can take some time].
Old 8th May 2020, 16:43   #3  |  Link
Georgiana
Thank you very much, StainlessS, for the suggestion!
avisynth, effects, filters, functions, plugin
