29th March 2004, 19:35 | #21 | Link |
hihi, just trying your software:
1. when press alt-f4, it does not exit but minimize to tray? could you fix that? 2. I choose english when install, but after install it becomes chinese traditional, maybe due to my chinese winxp? any possibility to change it back to english within the software? 3. also, what's startup latency? thx. |
29th March 2004, 20:07 | #22 | Link |
Very nice GUI for Producer! Even though I don't mind the command line window, it is cool to see someone take advantage of another interface to run Producer. I added a link in the RealVideo Info thread with:
Features supported: RealVideo 10, RealAudio 10. Not supported: 'Elysian' rate control and inloop filter options.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
29th March 2004, 20:07 | #23 | Link | |
retired developer
Detritus Software |
30th March 2004, 06:37 | #24 | Link | |
Nothing......
2. yes, it due to your system's language. |
30th March 2004, 11:15 | #25 | Link |
Great to see frequent updates to my favourite encoder!
Feature Request: Is it possible to seek foward (at least for a couple of seconds) in the crop preview? Many videos have a black background as the first frame and this makes it impossible to manually crop the video correctly cauz I can't tell where the video's edges are. Thank you. |
31st March 2004, 09:09 | #27 | Link | |
Nothing......
31st March 2004, 10:12 | #28 | Link | |
Nothing......
31st March 2004, 16:58 | #29 | Link |
Any mirrors available? I just can't get the full-setup from your page.
Comes about 1-2 kt/s and this is now third day I am trying to download it. How big it is? do I need to install something from helixcommunity too? I finally got it! Last edited by Valky; 31st March 2004 at 17:51. |
1st April 2004, 06:03 | #30 | Link | |
Nothing......
and the full-setup is ready for run.. |
2nd April 2004, 14:06 | #31 | Link |
hi...
is it possible to calc target size? (if so how...) what is high quality resize video and is anamorphic enc possible? also i played with dlls - switched erv4.dll with new "elsyian" and applied reg file - is this correct? thanks... |
2nd April 2004, 17:09 | #32 | Link |
ERM just keeps getting better & better
I was wondering if v1.56 uses the Elysian milestone. If it does, do you think it would be possible to include the curve compression option? Or has it been enabled by default? Please keep up the good work! |
6th April 2004, 05:01 | #33 | Link |
it would be nice if it has a log window keeping track which files have been finished... always forget which files have been converted especially when I add lots of file from different folders... ^^
btw, what's that black level correction? |
6th April 2004, 09:12 | #34 | Link | |
! - User - !
Keep your tone warm and your sigs decent! |
6th April 2004, 12:07 | #35 | Link |
retired developer
this filter controls the brightness. it can change dramaticly like if white subs appeir. You shouldn't use it.
Detritus Software |
7th April 2004, 02:19 | #37 | Link |
retired developer
hum... you should use external gain, using fixed 12 may cause clipping in your sound.
Detritus Software |
7th April 2004, 08:55 | #38 | Link |
creating mobile media
Producers Docs says, audio is only gained if this won't produce any clipping.
But, for normalized sources, +12dB is to much. For Audio Books on my mobile, I mostly stick with +6dB. But for other uses than for speakers that shouldn't be named speakers, a simple normalize via besweet (or similar) would be the best. |
21st April 2004, 12:26 | #40 | Link |
hi redcheek is it possible to get a "file size" setting in the mix to? or is there any way to get a fairly accurate filesize out of it?
i want a 1 cd copy of a movie, i want to be able to make the file to be a certian size |
