6th April 2006, 04:19 | #361 | Link |
Megui convert file by x264.exe and Avisynth . It is good .I have a mpeg-2 which can't be transcoded by Virtualdub but Megui can do well . I'm very surprise .
Averly Lee says that Using a large buffer make VD encode while it waits for disk I/O . Oh ! all thing is theory . If increasing AVI buffer and pipeline , processing speed will increase . Have you try to do this with VD ? VD uses x264vfw.dll while Megui uses x264.exe Maybe we can't do this in MEgui because it use Avisynth . I guess that . I don't dare say because I'm a pro programmer Last edited by thuongshoo; 6th April 2006 at 04:23. |
6th April 2006, 08:22 | #363 | Link | |
Angel of Night
Heavy pipelining is only useful for huge disk operations, on the order of tens of megabytes read and written a second. Capture and direct stream processing fall into this, heavy final encoding does not. x264 already uses asynch i/o afaik, which provides a big boost, and pipelining doesn't gain much over that.
He discusses it in this entry: Quote:
6th April 2006, 12:49 | #364 | Link | |
because I'm not pro programmer To denise : thank you ! I will try To foxyshadis : I will read it .My english is n ot good so I need time to understand it . Last edited by thuongshoo; 6th April 2006 at 12:57. |
6th April 2006, 13:33 | #365 | Link |
I'd love to have vorbis sound suppont in MeGUI.
Until you resolve the avisynth sound support for Vorbis would it possible to add at least muxing of Vorbis sound with mkvmege ? Cos mkverge is perfectly capable of doing so. Thanks a lot for the BEST encoding GUI. |
8th April 2006, 02:54 | #366 | Link |
Curious Beta Tester
Just a useability suggestion on the UI - buttons could be made inactive until they can be actually used. e.g. Not having the job tab start button enabled until a job exists in the que.
Thanks to all involved in MeGUI, a great app that Im sure is setting the stage for our AVC future. |
8th April 2006, 03:46 | #367 | Link |
Banned
Hi guys, I have one reasonable suggestion for future MeGUI builds?
Instead supporting ONLY AVS input, devs should introduce direct work with AVI. MPG and other video files, without need for AVS script. That's because most people doesn't need filters in AviSynth, so direct work with MPG and AVI files would be nice. Any good thoughs, devs. I don't need AviSynth scripts very often, I just want to encode in MP4 or MKV container directly, without AVS scripts. |
9th April 2006, 22:20 | #368 | Link | |
Mr. Woof
10th April 2006, 00:49 | #370 | Link |
Angel of Night
There's nothing nice about his request, all that needs to change is the drag-drop (and file open) handlers need to be extended to accept and handle directshow types (mkv, mp4, mov, wmv, etc). And, possibly, avisynth input renamed to video input, except then we'd get the exact opposite requests from people asking for an avisynth input.
10th April 2006, 01:02 | #371 | Link |
Does it really matter?
Not to mention demultiplexing issues, Remuxing control, container capabilites(in temrs of handling audio and video streams).
There is a whole lot to consider if Megui were to start accepting all types of files. |
10th April 2006, 01:18 | #373 | Link |
Angel of Night
Well, the video just gets sent to a directshowsource call, so if that fails you just pop up a dialog saying "No system splitter or decoder available for this format! Please install [haali's and ffdshow|realplayer|WMP codecs]."
If you get beyond that into multiple streams, subtitles, chapters, etc, you're in for a world of pain for not much gain. ;_; |
10th April 2006, 13:10 | #374 | Link |
Ok, done! You can now open any video source that works with DirectShowSource in a number of ways:
At the moment, the only supported filetypes for DirectShow are *.avi, *.mp4, *.mkv, and *.rmvb. Everything else is accessible through the 'All files' filter. If someone wants to givve a me a better list of file extensions for DSS-loadable files, please go ahead. |
10th April 2006, 18:09 | #376 | Link | |
10th April 2006, 18:20 | #377 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
10th April 2006, 19:09 | #378 | Link |
true. but I think what KRP is asking for is basically virtualdub. Where the video file is handled implicitly where the end of encoding all the stuff is done already.
That would mean that megui would have to be able to differentiate between all tracks(video, audio, subs) Their given track names and other info be able to wrap that in avisynth with no user input, and then figure out how to keep them into the next container with the same attribs. Considering all the things that can go wrong in this process(audio compatibility, video changes and whatnot) there would have to be a substantial amount of time put in to get every possible situation and prereq for each container both input and output. |
10th April 2006, 19:47 | #379 | Link |
Curious BetaTester
@berrinam cheers for clear log button,
just noticed the resize disable nice touch - but maybe a idea to turn on resize automaticly if crop is used and its not a mod of 8/16(not remember which)
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
