13th January 2013, 16:16 | #12041 | Link |
If you see this grey rectangle with detected video codec then DE mode will be activated
otherwise normal mode is used from source code Code:
CodecString:=MediaInfoA_Get(Handle_, 1, 0, 'Codec/String', 1, 0); if CodecString='FRAPS' then DetectMediaCodec:='fraps' else if pos('DV',CodecString)<>0 then DetectMediaCodec:='dv' else if CodecString='JPEG' then DetectMediaCodec:='mjpeg' else if CodecString='MPEG-1 Video' then DetectMediaCodec:='mpeg1' else if CodecString='MPEG-2 Video' then DetectMediaCodec:='mpeg2' else if (CodecString='XviD') or (CodecString='DivX 5') or (CodecString='DivX 4') then DetectMediaCodec:='mpeg4' else if (CodecString='VC-1') or (CodecString='WMV3') then DetectMediaCodec:='vc1' else if pos('VP6',CodecString)<>0 then DetectMediaCodec:='vp6' else if pos('VP8',CodecString)<>0 then DetectMediaCodec:='vp8' else if pos('H263',CodecString)<>0 then DetectMediaCodec:='h263' else if pos('RealVideo 4',CodecString)<>0 then DetectMediaCodec:='rv4' else if (CodecString='H.264') or (CodecString='AVC') or (CodecString='MPEG-4 AVC') then DetectMediaCodec:='h264' else DetectMediaCodec:='unknown';
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th January 2013 at 16:21. |
13th January 2013, 16:22 | #12043 | Link |
it does not matter
13th January 2013, 17:14 | #12045 | Link |
correct
13th January 2013, 19:53 | #12048 | Link |
i do not have win 8 so i can not test.
BTW. Does it also crash when you just double click on bepipe.exe icon?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th January 2013 at 19:55. |
14th January 2013, 22:51 | #12049 | Link |
Hi i need add very small txt in my encode
and i use *.ssa & .*ass subtitles in build in picture mod But when I start stop in please wait ... i use this in other pc is ok in my Server not work Where you are might be a problem ? thanks |
16th January 2013, 05:34 | #12051 | Link |
Hi Atak,
This has probably been asked before, sorry. I have just done a fresh Windows 8 Pro set up, on an IVY 3770K, installed Ripbot, and the other things it needs, and during the 1st "test" encode, using DE, and a couple of extra servers, I keep getting this error :- "H.264 (MPEG-4 AVC) encoder has stopped working". Now I know that you aren't using Win 8 yet, but is this a separate issue ??? Do I need to install a Codec pack ??? Any suggestions Might have to go back to Win 7 (which isn't such a bad idea) Cheers EDIT:- FIXED, it appears that I had it just a little bit too much overclocked..I went to your 1st page, and there's a "note" about x264 crashes. But I did also get the latest x264.exe (that didn't make any difference) Last edited by burt123; 16th January 2013 at 06:49. Reason: Fixed |
16th January 2013, 10:21 | #12052 | Link |
Hey everybody
I have audio sync problems I have a m2ts (VC-1) file and I just want to get a mkv file with best quality. But everytime I do the preview the audio is at the beginning like 3 seconds ahead and by the time the delay gets worse and worse. Can anybody help? |
16th January 2013, 12:35 | #12053 | Link | |
- ugly theme (where is my beautiful aero glass?!) - lack of normal more useful start menu (now you have to pay for star8 or startisback) - lack of desktop gadgets! - schizophrenic interface (some apps open in desktop some in metro ui) - mess in start screen after installing many programs - switching from desktop to full screen start menu is annoying as hell (atleast for me) - no performance increase in games or programs (see tomshardware.com review) I guess I will stay with win7 for looong time.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th January 2013 at 12:40. |
17th January 2013, 00:05 | #12054 | Link |
Hi Atak,
I have to agree on nearly every point you made about Win 8. One good thing I've noticed is the start up time, so much faster than Win 7. I have been able to get a few "fixes" so I can run gadgets, and can also get a "fix" that makes it look like Win 7, with start button, "normal" start menu, but if you're going to change all that, you might as well stick with Win 7. Having no Aero Glass is sad, and as for the messed up start menu after installing stuff, takes a lot to tidy it up, but you'd get use to it. It IS very different initially, but behind all that messed up metro stuff, it's just like Win 7, only "different". Cheers |
17th January 2013, 09:49 | #12055 | Link |
Silent Reader
Ok, I know, Atak has no Win8, so he can't help,
but maybe another has found a solution. I installed RipBot264 1.17.4 Preview under Win8Pro 64bit. newest Haali, newest ffdshow (4499) and so on. Several encodes went fine. Issue with new Storage Space feature of Win8Pro (similar to Raids) still exists, but I switched back to Intel (BIOS) Raid, so it is solved. Now I tried to encode a BluRay with DTS (15xx) to an AVCHD AC3 (640), with temporary use of FLAC. When in preview, I see error that flac isn't recognized in avisynth. To resolve Issue, I tried Codec-Pack from Shark007: Now Flac is recognized, no problem. BUT Video ist topdown! After deinstalling Sharks Pack and reinstalling Haali and ffdshow video is fine, but flac isn't recognized again. Any suggestions?! With Win7 this issue doesn't appear. I have several computers to test, but I want to have at least one with Win8 to test, even when I don't like Win8. |
17th January 2013, 16:03 | #12056 | Link |
Fantastic program....just one quick question: Is there a guide to some of the settings in the second part of the "Properties" area please? I know I need to deinterlace my file. I just don't know what "TFF", "BFF", "Decimate" etc mean. Not asking for someone to hold my hand....if someone could point me to a manual I would be grateful guys! Thank you!
17th January 2013, 20:48 | #12057 | Link | |
DTS Enthusiast
Example: 1080i 29.97 / 1080i 30 Code:
--preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 30 --open-gop --slices 4 --tff --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 1 --preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 30 --open-gop --slices 4 --tff --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 2 480i 29.97 Code:
--preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 30 --open-gop --slices 4 --bff --colorprim "smpte170m" --transfer "smpte170m" --colormatrix "smpte170m" --sar 40:33 --pass 1 --preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 30 --open-gop --slices 4 --bff --colorprim "smpte170m" --transfer "smpte170m" --colormatrix "smpte170m" --sar 40:33 --pass 2 |
18th January 2013, 05:17 | #12058 | Link | |
I installed Server 2012 (windows 8 based) on my server, which also is used to encoide clips. and now bepipe won't work, but this was broken by latest .net 3.5 update, problem is windows 8 doesn't allow you to uninstall .net updates can anyone point me to who made bepipe? maybe we can fix this? |
18th January 2013, 15:30 | #12060 | Link |
Can anyone help me with the below error? I Have just started to receive these on a few Blu Rays. I have upgrade to the 1.17.4 version, upgraded my eac3to to version 3.27. I have the AcrSoft DTS thing installed per the eac3to readme. Not sure what else I can do. This has only just started on a few select discs. Any thoughts?
eac3to v3.27 command line: "C:\Users\xxx\Desktop\ripbot\Tools\eac3to\eac3to.exe" "E:\fab files\DREDD\" 1) 2: "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\audio_English.dtsma.w64" -down16 6: "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\6_subtitles_English_1080.sup" 7: "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\7_subtitles_English_1080.sup" 8: "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\8_subtitles_Spanish_1080.sup" 1: "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 3 audio tracks, 3 subtitle tracks, 1:35:52, 24p /1.001 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) 4: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz 5: AC3, Spanish, 5.1 channels, 640kbps, 48kHz 6: Subtitle (PGS), English 7: Subtitle (PGS), English 8: Subtitle (PGS), Spanish Creating file "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\chapters.txt"... [s08] Extracting subtitle track number 8... [a03] Extracting audio track number 3... [s06] Extracting subtitle track number 6... [a03] Decoding with ArcSoft DTS Decoder... [a03] Reducing depth from 24 to 16 bits... [a03] Writing W64... [v02] Extracting video track number 2... [s07] Extracting subtitle track number 7... [v02] Muxing video to Matroska... [a03] Creating file "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\audio_English.dtsma.w64"... [s07] Creating file "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\7_subtitles_English_1080.sup"... [s08] Creating file "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\8_subtitles_Spanish_1080.sup"... [s06] Creating file "C:\Users\xxx\AppData\Local\Temp\RipBot264temp\job1\6_subtitles_English_1080.sup"... [a03] The ArcSoft DTS Decoder reported an error while decoding. <ERROR> Aborted at file position 22072477696. <ERROR> |
