Old 2nd March 2016, 18:36   #861  |  Link
stax76
stax76's Avatar
@dandyclubs
nice clip , I've created a ticket and let you know when VFR-maniac replies.
Old 2nd March 2016, 19:35   #862  |  Link
cegy
Originally Posted by stax76 View Post
@dandyclubs
Here it works with a similar source, full log:
http://pastebin.com/efU7ShE0
Interesting could be this:
The exit code might be a system error code: 0xp에 있는 명령이 0xp의 메모리를 참조했습니다. 메모리는 s될 수 없습니다.
I don't know about the foreign characters, can you send me the original log file as email attachment? My mail address is in StaxRip's main menu.
@cegy
For regular audio files the old behavior is restored.
that's great news @stax76 i guess i need to wait for the next test build then ?
cegy is offline   Reply With Quote
Old 2nd March 2016, 20:00   #863  |  Link
stax76
stax76's Avatar
yes but probably won't be long
Old 2nd March 2016, 20:15   #864  |  Link
cegy
also another bug for you to sort out, its the video comparison it seems if the filter is set to something other than manual ? it will fail i only notice this myself since i like to use dgsource myself
http://gfycat.com/BrokenHoarseFruitbat
would it also be possible to show what the crop values are set to via mouse over event or something since the "preview" tab is missing
Old 2nd March 2016, 20:54   #865  |  Link
stax76
stax76's Avatar
The source filter used for the video comparison is hardcoded to ffms2 I think so it don't matter what source filter is in the main dialog, choosing DGSource triggered a bug however, it'll be fixed.
The crop values mouse over issue I don't understand yet, you mean in the video comparison?
Old 2nd March 2016, 20:57   #866  |  Link
cegy
nah as in if the user was to make the crop in there video (the video there going to encode) how can they get a preview of what values that was used ?
as in 1.1.8 you had the preview tab when you double click on crop
Old 2nd March 2016, 21:11   #867  |  Link
stax76
stax76's Avatar
You can find the crop values:
in the crop dialog in the status bar
in the options dialog under Image | Crop
double click filters to show Scripting Editor > show context menu > Script Preview
Old 2nd March 2016, 21:22   #868  |  Link
cegy
oh i would of never known that due to being hided so well away wouldn't a button make it easier for the user to find it ? (far left side from ok and cancel maybe ?)
better yet if you want to keep it clean but to the point how about ? (not sure of the name click able title?)
Old 3rd March 2016, 08:31   #869  |  Link
Magik Mark
Stax,
Are the settings for the default template been updated. For instance, in x265 the default psy rd was changed from 0.3 to 2
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 3rd March 2016, 09:05   #870  |  Link
stax76
stax76's Avatar
My code is fairly up-to-date, I'm using a diff checker tool to catch changes. I did not reset the profiles and templates though, if you want to reset there is a reset feature for both profiles and templates.
Old 3rd March 2016, 09:35   #871  |  Link
Magik Mark
Tried doing that. the psy rd remain 0.3 so I have to manually change it
stax, I'm trying to use "RemoveGrainHD" in lieu of "RemoveGrain" for HD sources. Is this possible?
Thanks
Old 3rd March 2016, 10:15   #872  |  Link
stax76
stax76's Avatar
have you seen main menu > tools > directories > plugins ?
Old 3rd March 2016, 11:20   #873  |  Link
Magik Mark
I'm getting script error - "There is no function named RemovegrainHD
This is what I did. I copied the Removegrainhd.dll to the avisynth plugin folder then I added Removegrainhd in the filter profile.
Did I missed something?
Thanjks
Old 3rd March 2016, 15:28   #874  |  Link
stax76
stax76's Avatar
Are you aware that StaxRip x64 supports only AviSynth+ x64 and AviSynth+ x64 supports only x64 plugins?
http://avisynth.nl/index.php/AviSynt...2B_x64_plugins
Old 4th March 2016, 03:19   #875  |  Link
stax76
stax76's Avatar
some fixes and a feature requested since years
### Download
https://drive.google.com/folderview?...kE&usp=sharing
http://1drv.ms/1OqPDOe
### New Features
- support for 3 or more audio tracks added to the muxing dialog
- code preview added to filters menu and script preview renamed to code preview in script editor
### Fixed Bugs
- fixed window freeze in eac3to dialog happening when eac3to fails on the input.
- fixed showing filter selection dialog even if the source is vpy or avs
- fixed StaxRip trying to auto correct the script even if the source is avs
- fixed StaxRip recalculating the video bitrate even when the fixed bitrate option is used
- avi muxer supports two audio tracks now
- in some cases the two audio output file paths were identical
- moving subtitles up and down wasn't working correctly
- the new mp4box update should fix a bug many people reported
### Tweaks
- better error handling when the source is vpy or avs
- when loading an audio file without language info the language of the audio profile/stream stays instead of being changed to undetermined
### Updated Tools
- mp4box 0.6.0
- QSVEncC 2.37
Old 4th March 2016, 15:50   #876  |  Link
TalasNetrag
Is it possible to give the infotext in the preview a black border? Sometimes it's hard to see anything.
Minor inconsistency: When opening a file normaly StaxRip asks to select a source filter and if any of the audio track should be demuxed.
When opening a file with the "open with" dialog (rightclick->open with->StaxRip) StaxRip chooses the source filter and demuxes all audio tracks.
TalasNetrag is offline   Reply With Quote
Old 4th March 2016, 16:01   #877  |  Link
stax76
stax76's Avatar
yes, good idea!
It's by design that if you use the StaxRip CLI then no dialogs are shown because CLI is often used by batch files, I could make a CLI switch to control this but I'm not sure if showing dialogs should be default in CLI mode.
Old 5th March 2016, 01:43   #878  |  Link
stax76
stax76's Avatar
  • mp4box was broke because I had compiled in in debug mode...
  • The info in the preview looks better and is readable regardless of the current background
  • added a command line switch -show-dialogs:bool and project option 'Show all dialogs when invoked from CLI', by default dialogs are not shown when StaxRip receives CLI arguments
https://github.com/stax76/staxrip/wiki/test-build
Old 5th March 2016, 09:14   #879  |  Link
RieGo
found a little bug:
trying to open a file containing the ' character with vapoursynth results in an error. didn't try avisynth.
RieGo is offline   Reply With Quote
Old 5th March 2016, 10:15   #880  |  Link
stax76
stax76's Avatar
If I remember right then Python and JavaScript allow strings defined with both ' and " and since VB.NET uses " I used ' to define all the Python code, if I change it to " then it will be fine I hope.
