#601 | Link |
Running Avsmeter with prefetch enabled causes the benchmark to slow down considerably.
[General info] Log file created with: AVSMeter 1.7.6 (AVS 2.6, x86) Avisynth version: AviSynth+ 0.1 (r1689, x86) [Clip info] Number of frames: 1726 Length (hhh:mm:ss.ms): 000:01:11.989 Frame width: 704 Frame height: 480 Framerate: 23.976 (2500000/104271) Interlaced: No Colorspace: YV12 Audio channels: 2 Audio bits/sample: 16 Audio samples/sec: 48000 Audio samples: 3454656 [Runtime info] Frames processed: 8 (0 - 7) FPS (min | max | average): 0.017 | 237169 | 0.044 CPU usage (average): 6% Thread count: 27 Physical Memory usage (peak): 90 MB Virtual Memory usage (peak): 173 MB Time (elapsed): 000:03:00.148 [Script] SetFilterMTMode("", 2) SetFilterMTMode("Directshowsource", 3) Directshowsource("c:\1.mkv") Deblock(20) VagueDenoiser(threshold=1.0, nsteps=8, chromaT=0) Hysteria(strength=0.2, highthresh=200) Prefetch(4) [Performance data] Frame Frames/sec Time/frame(ms) CPU(%) Threads PhysMEM(MB) VirtMEM(MB) 0 0.017 60057.016993 0 32 82 168 1 0.017 60014.952892 0 28 88 171 2 171.206 5.840931 0 28 88 171 3 8.837 113.165406 12 28 90 173 4 33203.609 0.030117 12 28 90 173 5 237168.577 0.004216 12 28 90 173 6 83.888 11.920692 12 28 90 173 7 0.017 59944.863827 0 27 90 173 This script using Avisynth 2.6MT finishes in 33 seconds, avs+ without the prefetch call finishes it in 40 seconds. |
#602 | Link | |
Looks like it breaks because of the SetFilterMTMode("", 2) line. SetFilterMTMode("audiodub",3) should fix it. Apparently AudioDub (called by dss internally) has issues with MT mode 2 which you try to apply to it by default.
And I still believe this way of setting the default MT mode should be removed. Brings nothings but problems. Quote:
The most optimal way from performance point of view would be providing a wrapper function around the plugin which would set number of threads to 1 and pass all other parameters unchanged right to the plugin. Something like: Code:
function awesome_filter(clip c, int "thresh") { awesome_filter(c, thresh, threads=1) } Last edited by TurboPascal7; 13th February 2014 at 12:03. Reason: rewriting the history |
#604 | Link |
I'm getting a few instances whereby my script just stops suddenly. It doesn't crash, the encoding process just stops. Perhaps signs of a deadlock?
Here's my script: Code:
SetFilterMTMode("QTGMC",2) SetFilterMTMode("FFVideoSource",2) LoadPlugin("C:\Program Files (x86)\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("I:\Temp\Test.mkv", fpsnum=24000, fpsden=1001, threads=1) Dither_convert_8_to_16() Dither_y_gamma_to_linear() Dither_resize16(1280,720) Dither_y_linear_to_gamma() DitherPost() QTGMC(Preset="Slow",InputType=1) InterFrame(Cores=1,GPU=True) PreFetch(3) Last edited by aegisofrime; 13th February 2014 at 16:01. |
#605 | Link | |
Cantankerous Fossil
FFVideoSource should have Mode 3. I also doubt that you can set a mode for an entire script that uses a whole bunch of filters (QTGMC) which might each need to be treated differently. |
#606 | Link | |
#609 | Link |
AVS+ Dev
You cannot set the MT mode on script function calls, only on binary filters. So to make QTGMC work, all filters that it uses internally need their MT mode set. I did a basic test though when the the current test build was published, and QTGMC worked fine with a single SetFilterMTMode("", 2) call at the beginning and default arguments, so that is a start. But keep in mind that non-default arguments can easily require more complex MT-mode settings.
Anyway, thanks for all the testing. A few more days and I will begin hacking around it at large again. I am also thinking it might be very useful to have a logging framework in place (and maybe start with that), it could provide useful information about MT mode settings or other warnings to script writers. There is definetely a place to improve on the performance of the current version, and be assured that I will look at that in detail, as well as the issues that have been posted.
AviSynth+ |
#610 | Link | |
#613 | Link |
SetFilterMTMode("MPEG2Source",3) MPEG2Source("sample.d2v", cpu=0) Code:
AVSMeter 1.7.6 (AVS 2.6, x86) by Groucho2004 AviSynth+ 0.1 (r1689, x86) Number of frames: 36853 Length (hhh:mm:ss.ms): 000:20:29.662 Frame width: 720 Frame height: 480 Framerate: 29.970 (30000/1001) Interlaced: No Colorspace: YV12 Frames processed: 6180 (0 - 6179) FPS (min | max | average): 248.7 | 340.6 | 295.5 CPU usage (average): 12% Thread count: 13 Physical Memory usage (peak): 35 MB Virtual Memory usage (peak): 69 MB Time (elapsed): 000:00:20.915 Press any key to exit... |
#614 | Link |
The fact that you see more threads doesn't mean it's running MT. It's a minor implementation detail which might change in the future or it might not.
You can see that your CPU load is still locked at 12% which means one running thread on a 8-threads system. |
#615 | Link |
No, it's running at 12% cpu because that's the max speed mpeg2source can run in my machine on multithread. If I ran the same vob file with ffvideosource, it would clearly show that mt is on because it would be a lot faster.
ffvideosource("sample.vob", fpsnum=30000, fpsden=1001) Code:
AVSMeter 1.7.6 (AVS 2.6, x86) by Groucho2004 AviSynth+ 0.1 (r1689, x86) Number of frames: 36849 Length (hhh:mm:ss.ms): 000:20:29.528 Frame width: 720 Frame height: 480 Framerate: 29.970 (30000/1001) Interlaced: No Colorspace: YV12 Frames processed: 36849 (0 - 36848) FPS (min | max | average): 1242 | 1818 | 1660 CPU usage (average): 65% Thread count: 30 Physical Memory usage (peak): 52 MB Virtual Memory usage (peak): 68 MB Time (elapsed): 000:00:22.202 |
