30th September 2012, 01:03 | #14287 | Link | |
Playing with MKV files...
What Start button?
I tried searching Windows Help to see where they moved those controls to and the words "Desktop Composition" do not exist together anywhere. The only result for "Aero" is about the Aero effect window themes (where I was before and changed to a high-contrast theme). MadVR does have its own "Disable Desktop Composition" option and that doesn't seem to have any effect on this. Edit: Okay! I found the setting. Control Panel\All Control Panel Items\Performance Information and Tools Left-hand sidebar -> "Adjust Visual Effects" opens a new control panel. "Adjust for Best Performance" turns off everything on the list below and disables the Aero Glass, screen font smoothing, etc. But the issue was still there when I tried it again in Zoom Player just now. I left the the "Disable Desktop Composition" function activated on MadVR and it's not checked to only use it in fullscreen mode.
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8 Last edited by nx6; 30th September 2012 at 01:12. |
30th September 2012, 02:01 | #14288 | Link | ||
FSE did stop the issue and was able to get working in Windowed Mode by changing the buffer/que settings back to defaults. Was able to get working well with 0.83.7 in Windowed Mode by changing the buffers back to default settings. CPU Que = 12 GPU Que = 8 Windowed Mode back buffers = 3 Are there any references as to what the "best" buffer/que settings should be ... ? Was something changed in the newer releases where the buffer/que settings would impact the performance differently. Will let you know some Windows 8 RTM results with AMD Radeon 6570 later. Update: There are still problems in Windowed Mode. Changing the buffer/que settings DID NOT fix the problem. Seeing the same issues as before and on another system with AMD Radeon card as noted below
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) Last edited by blackjack12; 30th September 2012 at 17:39. |
30th September 2012, 06:21 | #14289 | Link | |
Will try some of your suggested setitngs. Really desire windowed mode if possible.
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) |
30th September 2012, 07:50 | #14290 | Link |
madVR 0.83.7 – Seeking/moving around more than 3x in Windowed Mode = dropped frames
Windows 8 RTM (64) – build 9200
AMD Radeon 6570 AMD Radeon driver ver. 12.8 MPC-BE 1.0.3.1 LAV Filters 0.51.3-53 (not for VC-1, LAV filter issues with VC-1, AMD and Windows 8) madVR - Comparing 0.82.5 (with antiringing 6 updates) - 0.83.7 MKV Blu-Ray direct rip files tested - VC-1, VC-1i, H264, H264i material CPU Que = 12 GPU Que = 8 Windowed Mode back buffers = 3 Problem: With 0.83.7 files begin and play correctly, but if you jump ahead or back a number of times all of a sudden frames start dropping, stuttering and it does not stop or correct after pausing. It is consistent. Go back to 0.82.5 and there are no problems. Jump around between 3-5 times and always see the problem. The render and back buffer que appear that they are not being filled once the problem starts. Running in FSE mode is flawless. I could not get the debug log as you requested. Double clicking “activate debug mode.bat” yielded access denied and when run as administrator said file madVR.ax not found … even though it is right in the same folder …
30th September 2012, 08:17 | #14291 | Link | |
P.S. Try on this test build http://rghost.ru/40672681
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 1st October 2012 at 00:35. Reason: add test build. |
30th September 2012, 22:41 | #14292 | Link | |
what factors of graphic cards other than bandwith and memory type are decisive for speed for madvr? in recent two years, not much has changed regarding bandwith and memory type, there are still the budget and higher priced graphic cards which feature bandwith of roughly said between 20 - 200 GB/s. but for some reason when having two cards with the same value for bandwith, the newer card still seems to be a bit faster than the old one. so which other stuff comes into consideration for madvr?
30th September 2012, 23:01 | #14293 | Link |
Whether it is possible to write the filter which will smooth red sites(objects) on a pic. as are smoothed blue?
Original: With marks: Video: http://narod.ru/disk/61809639001.da8...emory.mkv.html
Win7x64 Core i7 920 3.5GHz Noctua NH-D14/ArcticCooling MX-3 6(3x2)GB Transcend 1426MHz RoyalHD (64MB)[Solo6c][JPLAY]/HD7850DC22GD5V2[EIZOT965] Seasonic X-750 VelociRaptor WD4500HLHX/16TB_STORE Last edited by secvensor; 30th September 2012 at 23:15. |
30th September 2012, 23:42 | #14294 | Link |
How to watch SopCast or any IPTV broadcasts with madVR renderer in the end ?
(without using temporarily file from mplayer http://localhost:8902/stream -dumpstream ...) Anyone knows player with madVR support that can accept pipe input (stdin) ? Last edited by zn; 1st October 2012 at 00:01. |
1st October 2012, 02:48 | #14295 | Link |
Software Developer
zn:
Zoom Player might be able to do it with LAV as the network source filter. I would need access to sample streams to verify. nx6: The best thing to debug this issue would be a desktop-capture video showing the glitch from start to finish. Secondly, I'm not sure if you tried this yet, but does this glitch appear even with FSE disabled in MadVR? |
1st October 2012, 09:17 | #14296 | Link |
契約者
secvensor
Why you asking it in this thread? I don't sense any relation to madvr. This is pretty normal aliasing effect caused by crappy bilinear scaling in editing software because Ms. Nagisa didn't cared much about that. As you can see, the texture below is just as bad as these lines. So think of it as design decision. And anyway your best solution is to redraw these lines by hand. Last edited by Keiyakusha; 1st October 2012 at 09:20. |
1st October 2012, 09:49 | #14297 | Link |
It only appears with FSE disabled. When FSE is enabled you get a flash of the beginning of the first (exiting) file before the second video starts, instead of the window frame.
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8 |
1st October 2012, 15:17 | #14298 | Link |
Keiyakusha
If madVR had the AI-filter for elimination of this effect, being based on the image. When madVR will support screenshots?
Win7x64 Core i7 920 3.5GHz Noctua NH-D14/ArcticCooling MX-3 6(3x2)GB Transcend 1426MHz RoyalHD (64MB)[Solo6c][JPLAY]/HD7850DC22GD5V2[EIZOT965] Seasonic X-750 VelociRaptor WD4500HLHX/16TB_STORE |
1st October 2012, 15:25 | #14299 | Link | |
契約者
avisynth is your friend but yes it affects the whole picture. build complicated mask that will protect parts you don't want to process. problem solved. Last edited by Keiyakusha; 1st October 2012 at 15:27. |
1st October 2012, 16:58 | #14300 | Link |
Keiyakusha
OK.
