Old 12th October 2019, 18:03   #17501  |  Link
mparade
All jobs will use the same server configuration.
So now you know what to do BTW. Overclocking AMD cpus do not make sense these days.
There should be something else here...After switching back to auto mode in amd ryzen master, Windows still keeps resetting very frequently right in the middle of encoding...temperature is below 68 degrees so that shouldn't be the problem
maybe memory issue or something else
mparade is offline   Reply With Quote
Old 12th October 2019, 18:03   #17502  |  Link
mparade
thank you very much
Old 12th October 2019, 18:55   #17503  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Originally Posted by mparade View Post
thank you very much
This one is even better
https://www.youtube.com/watch?v=eVxHhSLUrxo
Old 12th October 2019, 21:49   #17504  |  Link
mparade
Without overclocking it does the same so maybe voltage drop occurs...
so maybe I need to replace the likely faulty 1200W Cooler Master PSU first.
Old 12th October 2019, 22:31   #17505  |  Link
skylinekiller
Sutbtitle Font
so is it no longer possible to change the subtitle fonts.
I am trying to edit the font when I hardcode subtitle into my encode, but it doesn't seem to be working. I edited the notepad file in Tools\AviSynth plugins\VSFilter\Default.style with the parameters below.
Style: Default,Univers CE 45 Light,41,16777215,0,16777215,0,-1,0,2,1,2,20,20,20,0,0
what it looks like with the above settings in RipBot https://ibb.co/S7xFvpn
This is what it should look like. The resolution is not as good but trusts me, the font is not accepting the settings
https://ibb.co/92VB0Xt
This is the setting from srt2ssa
Synch Point: Side 1 0m00s
Collisions: Normal
Timer: 100.0000
Why am I getting a shadow
skylinekiller is offline   Reply With Quote
Old 13th October 2019, 10:21   #17506  |  Link
mparade
Originally Posted by LigH View Post
Possibly yes. Your x264 build does not support hardware acceleration (if there is a speed-up at all), but that doesn't keep it from finishing its job correctly with usual CPU routines only.
There may be x264 builds out there which can use some OpenCL functions of a modern GPU. So you might replace xour x264 executable; but I won't guarantee that they work correctly with RipBot264, they might interfere with other filters using the GPU too, even. Test and get experienced.
Can anyone recommend a reliable site for x264 builds using OpenCL functions? I have a 2060 RTX so just want to give it a try if possible.
Thank you in advance for the help.
Old 13th October 2019, 10:25   #17507  |  Link
sneaker_ger
Try:
https://artifacts.videolan.org/x264/ (no mp4 output - is that a problem for RipBot?)
Old 13th October 2019, 11:13   #17508  |  Link
mparade
thx! sorry for the dumb question but if I have Win 64 bit and AMD CPU which version to use AMD64 or Win64 or all the same?
Old 13th October 2019, 11:20   #17509  |  Link
sneaker_ger
"release-debian-amd64" is for for the Linux distribution "Debian", not Windows. Try "release-win64" (some software may need "release-win32" for compatibility but win64 is faster and can use more RAM so try that first).
Old 13th October 2019, 12:48   #17510  |  Link
mparade
I test is very soon, thank you!
Old 13th October 2019, 13:32   #17511  |  Link
mparade
Using this version I got the same disabling message from x264:
x264 [warning]: OpenCL: not compiled with OpenCL support, disabling
Old 13th October 2019, 13:41   #17512  |  Link
sneaker_ger
I tested opencl works with https://artifacts.videolan.org/x264/...84-3759fcb.exe
So you are still using the "wrong" binary somehow.
Old 13th October 2019, 13:57   #17513  |  Link
mparade
I have double checked. Ripbot is using the same from it's temp directory. Maybe the commandline made by Ripbot is not ok for the encoder. I don't really know what is happening.
Maybe it has something to do with video decoding? I am using LSMASH.
Thanks for any kind of help.
Old 13th October 2019, 14:46   #17514  |  Link
LigH
LigH's Avatar
Based on the IA-32-x86 architecture (which was introduced with the intel 80386 CPU), AMD and intel both developed an extension to allow 64 bit addressing. intel first started with a new architecture known as IA-64 (Itanium) which is not compatible with previous software. AMD instead developed a compatible extension x86-64, and intel realized how useful it is to continue using existing 32-bit software while developing 64-bit software with mostly the same instruction set for the future, and developed AMD's x86-64 architecture further with own extensions...
So if you don't have specifically an Itanium Server software for Windows running on an Itanium CPU, which I doubt a lot, then you will have a 64-bit Windows running on a CPU compatible to the AMD64 or x86-64 instruction set architecture. But there are also other operating systems running on such processors, it doesn't have to be Windows.
Talking about a 64-bit Windows, you can see Win64 and AMD64 and x86-64 (sometimes even x64) as more or less equal. As long as it does not explicitly say IA-64 / Itanium.
New German Gleitz board
Old 13th October 2019, 16:01   #17515  |  Link
Atak_Snajpera
x264 included in ripbot264 HAS support for OpenCL. Tested on crappy Geforce GT 710 and it works fine. Problem is with your drivers.
Old 13th October 2019, 16:06   #17516  |  Link
mparade
Thank you. I am using latest NVIDIA Game Ready Driver.
Old 13th October 2019, 16:11   #17517  |  Link
sneaker_ger
@mparade
Are you using 10 bit encoding? It seems x264 doesn't support opencl+10 bit and then throws this confusing warning about "not compiled with OpenCL support".
Old 13th October 2019, 16:33   #17518  |  Link
mparade
1 minute ago I realized it too. . Thank you very much! In 8-bit it was working like a charm. I have to think over then if I really want 10bit encoding. All of my players support 10bit files, a bit slower encoding times but with a 2990WX...
Old 13th October 2019, 18:29   #17519  |  Link
mparade
Is it possible to have jobs deleted automatically after they are completed successfully? (Not in batch mode)
Thank you!
Old 13th October 2019, 18:44   #17520  |  Link
Atak_Snajpera
Sure.
