Old 13th March 2008, 15:40   #201  |  Link
mommyman
Ability to run external program (flac, etc.) has been added to Alpha 11: http://www.sendspace.com/file/lfm39n
mommyman is offline   Reply With Quote
Old 13th March 2008, 21:17   #202  |  Link
ron spencer
DVD Magistrate
thanks!!!
ron spencer is offline   Reply With Quote
Old 14th March 2008, 00:34   #203  |  Link
nevragain
wow thanks
nevragain is offline   Reply With Quote
Old 14th March 2008, 11:24   #204  |  Link
mommyman
Originally Posted by frenchglen View Post
Ok, tried, and to expose my low level of knowledge here, how do you use Run program feature?
Thanks man.
Iti s in ReadMe.txt now. Print "flac -f %filepath%" in this box (flac must be added to search path before). This way you can use almost any of command line encoders, not the only one.
Dialogs are to be replaced on natives in Alpha 12. Wondering, how will they look on Mac.
Old 15th March 2008, 00:31   #205  |  Link
nevragain
oh quick q does this still need windvd?
Old 15th March 2008, 02:46   #206  |  Link
Wilbert
It never did need it (provided the AOBs were decrypted).
Old 16th March 2008, 02:06   #207  |  Link
nevragain
I'm not quite following does the program need windvd to decrypt the AOB or does it work standalone.
Old 16th March 2008, 02:26   #208  |  Link
Wilbert
Since alpha7 (from the readme): "Extraction from protected media with libdvdcpxm library." This library decrypts the encrypted media, so you don't need WinDVD anymore. (Btw, you can also find a standalone version (dvdcpxm.exe) of the libdvdcpcm in this thread.)
Old 16th March 2008, 23:25   #209  |  Link
nevragain
ok thanks I don't have the money for windvd so I am greatfull thank you for your patience in explaining this
Old 18th March 2008, 18:24   #210  |  Link
ron spencer
DVD Magistrate
are there issues with decoding?
see:
http://www.hydrogenaudio.org/forums/...howtopic=61928
Old 19th March 2008, 11:37   #211  |  Link
mommyman
Very likely so... Could somebody give a sample (suppose mlp track) of that?
Old 20th March 2008, 18:47   #212  |  Link
mommyman
I've got the sample of such track, glitches confirmed.
Old 20th March 2008, 18:54   #213  |  Link
ron spencer
DVD Magistrate
can it be fixed?
what versions are affected?
thanks!!!!
Old 20th March 2008, 19:23   #214  |  Link
mommyman
Yes, I hope... Affected versions: 9, 10 and 11
Old 20th March 2008, 21:04   #215  |  Link
gfxnow
How do the latest versions of DVDAExplorer convert MLP to Wave? just curious.
Before i had to go through a tedious process of tricking the surcode MLP encoder.
gfxnow is offline   Reply With Quote
Old 20th March 2008, 21:53   #216  |  Link
mommyman
It uses mlpdec.c module (written by Ian Caulfield) from FFmpeg project. You can use eac3to in DVDAExplorer for the same purpose without tricks: "eac3to %filepath% c:/dump/eac3to/%filebase%.wav"
Old 21st March 2008, 06:11   #217  |  Link
bigpapa4u
bigpapa4u's Avatar
thanks guy!
bigpapa4u is offline   Reply With Quote
Old 21st March 2008, 14:51   #218  |  Link
mommyman
Alpha 12: http://www.sendspace.com/file/21sd5j
The problem was in mlpdec.c itself, which was replaced to the newer one. Cannot say that "issue is fixed", you should check log file for "[24] Lossless check failed - expected XX, calculated YY" message. It's about glitches coming...
Old 21st March 2008, 16:06   #219  |  Link
gfxnow
Thanks mommyman, DVDAExplorer is turning into an all-in-one solution for DVD-A backups. Before it was a really lengthy and tedious process.
Old 22nd March 2008, 12:59   #220  |  Link
ron spencer
DVD Magistrate
seems to be working ok:
http://www.hydrogenaudio.org/forums/...ic=61928&st=25
