17th April 2009, 19:05 | #2181 | Link |
Updated 19:07 CEST to Build 529, unfortunately it didn't solve the problem.
Thanks for trying, tough. Update: I've now tested the movie again on my HTPC which has a less powerful, but more recent GPU, and now the BD works like a charm. Thanks a lot for the support. Last edited by schlaufer; 17th April 2009 at 20:38. Reason: test on different PC |
17th April 2009, 23:13 | #2183 | Link |
Aging Video Hobbyist
I see there is now a way to import a .mpls from an original disc, and thus multiAVCHD can detect/retain original chapter marks, but is there any way, if I've re-encoded the original, to have it import the 264, ac3, subtitle, and --custom-chapter list I've created? is there an option to have multiAVCHD pause at the .meta file/tsMuxeR step so I can insert new chapters into the .meta file?
18th April 2009, 06:51 | #2184 | Link |
Programmer (or just 教务长)
You can create a folder with your movie's files
movie.264 movie.ac3 movie.dts movie.srt movie.sup movie.txt (with your custom chapters) load movie.264 (with settings to add external audio-tracks) and you will get what you need. You can also take a look at the first post of the thread. Last edited by deank; 18th April 2009 at 06:53. |
18th April 2009, 14:09 | #2185 | Link |
Home Theater Freak
Wow deank, now that you have an almost perfect software to boot...should you consider getting to improve on the visual aspects of this great authoring tool? :P Say animated menu and better flavours in menu positioning? And you still remember my wishlist?
18th April 2009, 14:22 | #2186 | Link |
It's 'almost perfect' since day one... but simply put - it is not at all what I want it to be
Menu manipulation and templates are a tough thing to do. What was your wish list? *** I'm also trying to implement UMD movie (playlist.umd playlist) import (UMD video discs for PSP). CLPI files look a bit different in UMD's CLIPINF folder and STREAM folder contains MPS files (MPEG-PS) instead of M2TS (MPEG-TS) but it works. Still the problem is the audio in MPS. If anyone has any info on audio extraction (ATRACplus) from MPS - let me know. It is a nice way to backup (and play in your PS3 or BD player) these 720x480i videos. Last edited by deank; 18th April 2009 at 14:39. |
18th April 2009, 15:22 | #2187 | Link |
Home Theater Freak
Recap on wishlist...
Actually its not that hard to implement since the hardest part is over...hehehe... I looking for a way to play only CERTAIN TITLES at start-up (Autoplay) and after which resume to the menu page. For instance, I got the following clips in order... Title 1 (Movie trailer 1) Title 2 (Movie trailer 2) Title 3 (Movie trailer 3) Title 4 (Movie clip) Title 5 (Movie clip) . . Title 18 (Movie clip) If possible, I will like to have Title 1 -3 autoplay upon disc insertion. Then after playback of the 3 titles, it will resume to Menu mode so that I can choose to play which movie clips (i.e. menu 4 - 18) in order of my preference. I believed its not hard? Like I said this is just a value-added feature for me if you have the time to do it. Its not a pressing one so I leave it to you to consider when you have the bandwidth to spare. Last edited by desray; 18th April 2009 at 15:24. |
18th April 2009, 15:36 | #2188 | Link | |
18th April 2009, 15:41 | #2189 | Link | |
Take a look again. It was there for some months now. Just above the complete version log...
18th April 2009, 15:42 | #2190 | Link | |
Dean,
I'm having trouble making my anime collection from MKV with ass subs into AVCHD with subtitles. These are anime mkv with 1280*720, a compliant file with ass subs in the mkv file. The resulted AVCHD folder plaed fine but there are no subtitles. Other mkv with SRT subtitles worked fine but not this one. The log shows no error, any reason why it's so? Quote:
18th April 2009, 15:46 | #2191 | Link |
Try to use NORMAL filenames without commas and a bit shorter. Also you can use [x] Change first SRT line timing option in Audio / Subtitles tab. Also if you can extract these SSA and send me a sample to look at?
18th April 2009, 15:56 | #2192 | Link | |
Thanks for the quick reply. I've tried your suggestion but it's not still working. Anyway I have another anime with two ASS subs and it's working fine..Dopn't know why this one is giving me trouble. I've attached the subs files here. I change the extension to txt because of attachment limitation. |
18th April 2009, 16:04 | #2193 | Link |
Did you try [x] Change SRT... option?
You can send the file to my email address. It is in the ABOUT tab of multiAVCHD. It is possible that this specific SSA file has a problem that multiAVCHD cannot translate properly to SRT. You can use the SSA with SubtitleWorkshop and fix it and save it as SubRip (srt) and then use it as external - it will probably work. But still I'd like to take a look at this problematic ssa file. |
18th April 2009, 16:22 | #2194 | Link |
Hi deank,
multiAVCHD is a great Tool! I have a question about the move option. If the temp Folder and the target the same, the m2ts Files will not Move. multiAVCHD copy the m2ts Files. If you add an old AVCHD Folder created with mulltAVCHD, then the m2ts will move. Can you please, add option to move m2ts files, from an existing BDMV or AVCHD Folder. Thats created with tsmuxer? These save a lot of time on an USB Drive. |
18th April 2009, 16:24 | #2195 | Link |
I removed this MOVE option a long time ago, because some people got their ORIGINAL (and only copy) moved into multiAVCHD and it caused them troubles.
multiAVCHD moves only its own compilations. I can add another MOVE option, as many people asked about it. |
18th April 2009, 16:30 | #2197 | Link | |
Pls have a look at teh subs. Thanking you in advance |
18th April 2009, 16:35 | #2198 | Link | |
Option is (x) all - it will make ANY input files to be moved. |
