Old 6th September 2015, 15:41   #2821  |  Link
manolito
manolito's Avatar
Hi Nordo,
to be able to help you, please post your AVStoDVD log file and make a screen shot of the filter graph and also post it here...
Using the latest AVStoDVD version is also a good idea.
Cheers
manolito
Old 7th September 2015, 02:11   #2822  |  Link
Nordo
Hi Manolito
Filter graph and file log below:-
http://s276.photobucket.com/user/Aus...tml?sort=3&o=1
http://s276.photobucket.com/user/Aus...tml?sort=3&o=0
Hope I've added them correctly.
Nordo is offline   Reply With Quote
Old 7th September 2015, 03:25   #2823  |  Link
manolito
manolito's Avatar
Your filter graph is correct, but the log file is a little short. The whole AVStoDVD log file is needed.
You should update AVStoDVD to the latest version. Also AviSynth should be updated to version 2.60 and LAV Filters to version 0.65. And generally you cannot discuss torrent downloads at Doom9.
Cheers
manolito
Old 7th September 2015, 08:29   #2824  |  Link
Nordo
Thanks Manolito
I was trying not to be too explicite with what I was doing.
Regarding the log file, how and where do I capture the whole file?
I tried searching through this thread and other places but could find any instructions.
Cheers
Old 7th September 2015, 12:19   #2825  |  Link
manolito
manolito's Avatar
After a conversion the log file will be in your output folder. If the DVD title is "DVD" (the default) then the log file will have the name "DVD.log".
This is a regular text file. Open it with Notepad, copy and paste the whole content into your post. For better readability you can "quote" the log content. Or you can upload the log file to a file hoster like SendSpace or Zippyshare and post just the link.
Cheers
manolito
Old 8th September 2015, 03:26   #2826  |  Link
Nordo
Thanks Manolito
File log below.
<6/09/2015 2:24:51 AM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: H:\Main Movie\Self Less
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Close all applications and shutdown system
PREFERENCES
MultiThread: 1
AVS Video Source Filter: FFMpegSource
AVS Audio Source Filter: FFMpegSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 0
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 3
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 16pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: G: ATAPI iHAS324 B AL1B
DVD Burning Speed: 8x
Auto Erase DVD RW: 1
Unload ActiveMovie library: 1
Adjust DirectShow Filters at runtime: 1
Save General Settings: 1
SYSTEM INFO
Processor Name: AMD Phenom(tm) II X4 965 Processor
Operating System: Windows 7 Service Pack 1 (64 bit)
Current user is Admin: NO
Available Output Disc Space: 0 GB
AviSynth is installed: YES (release 2.5.8)
LAV Filters is installed: YES (release 0.64.0)
ffdshow is installed: NO
TITLE 1 SOURCE FILES
Video: H:\My Downloads\TORRENTS\Self Less\Self.less.2015.BRRip.XviD-ETRG\Self.less.2015.BRRip.XviD-ETRG.avi
Info: XviD - 751 kbps - 640x352 - DAR 1.818 - 25 fps - Progressive - 1:52:12 hours - 168301 frames
Audio 1: H:\My Downloads\TORRENTS\Self Less\Self.less.2015.BRRip.XviD-ETRG\Self.less.2015.BRRip.XviD-ETRG.avi
Info: MPEG-1 Audio layer 3 - 112 kbps - CBR - 2 ch - 44100 Hz - 1:52:12 hours (0 ms delay)
[MediaInfoLib - v0.7.69]
AVISYNTH SCRIPT
LoadPlugin("H:\Program Files (x86)\AVStoDVD\Lib\ffms2.dll")
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = FFAudioSource("H:\My Downloads\TORRENTS\Self Less\Self.less.2015.BRRip.XviD-ETRG\Self.less.2015.BRRip.XviD-ETRG.avi", track=1)
Video = FFVideoSource("H:\My Downloads\TORRENTS\Self Less\Self.less.2015.BRRip.XviD-ETRG\Self.less.2015.BRRip.XviD-ETRG.avi", track=-1, seekmode=0)
Video = Video.ConvertToYV12()
Video = Video.AddBorders(0,4,0,4)
Video = Video.Lanczos4Resize(720,576)
Audio = Audio.SSRC(48000)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 4189.9 MB
Encoding Parameters: -ini "C:\Users\John\AppData\Local\Temp\DVD_Self.less.2015.BRRip.XviD-ETRG.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\John\AppData\Local\Temp\DVD_Self.less.2015.BRRip.XviD-ETRG_1.avs
*AVSRELOAD
*OUTFILE H:\Main Movie\DVD_Self.less.2015.BRRip.XviD-ETRG.m2v
*LOGFILE C:\Users\John\AppData\Local\Temp\DVD_Self.less.2015.BRRip.XviD-ETRG.HCenc.log
*MAXBITRATE 9000
*BITRATE 5221
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY HIGH
*DBPATH C:\Users\John\AppData\Local\Temp
*WAIT 2
<6/09/2015 2:25:28 AM>
Log file created by AVStoDVD Release 2.8.1
Old 8th September 2015, 12:53   #2827  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Sorry cannot give advises about conversions of torrent files. If you still get issue with legal files, than come back here and we will be glad to help you.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 9th September 2015, 03:51   #2828  |  Link
Nordo
Bye
I fully understand.
Old 15th September 2015, 19:23   #2829  |  Link
manolito
manolito's Avatar
DVD is NOT dead
A little bit OT, but it should be a bit of additional motivation for folks like MrC and others who still engage in writing software to create and modify DVDs:
http://i.imgur.com/2ph5wgR.jpg
DVD sales are still more than twice as high as BluRay sales. The tendency on this forum to look at the DVD as an obsolete technology is not justfied...
Cheers
manolito
Old 15th September 2015, 22:11   #2830  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Very interesting! Anyway we cannot ignore the slow decline...
I am surprised about the flat trend of BD from 2013 to 2014. And what are "VoD"? Download/Streaming video?
Bye
MrC
AVStoDVD Homepage
Old 15th September 2015, 22:27   #2831  |  Link
manolito
manolito's Avatar
VoD stands for Video on Demand
Cheers
//EDIT//
Forgot to mention that the data are just for Germany, source is the GfK (Gesellschaft für Konsumforschung), a very reliable source.
Old 17th September 2015, 21:42   #2832  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 2.8.3 final is available to download.
Change log:
- Some bugs fixed
- Added 'Open Project Log file' option in main window menu 'View'/'Operations Log'
- Added 'Video FrameRated Mode' option in main window menu 'Title'/'Edit Source Title Info'
- Added 'A2D Projects Path' option in 'Preferences'/'Paths'
- Added 'Spline36Rezize' value to 'AVS Up/DownSize Filter' options in 'Preferences'/'AviSynth'
- Added 'Display Info' option in 'Edit Title'/'AviSynth'
- Added 'fpsnum' and 'fpsden' flags to FFmpegSource calls when source video is not CFR
- Added '-readtoeof 1' command to Aften CL when wave input is potentially over 4 GB
- Added '/FILESYSTEM "ISO9660 + UDF" /UDFREVISION "1.02"' switches to ImgBurn command line
- Added a warning message in 'Quick Startup Tutorial' if H.264/AVS or AAC are decoded by MS DirectShow Filters
- Added AviSynth library 'Upmix.avsi' (thanks to tebasuna51 and manolito)
- Added possibility to upmix audio sources from Stereo to pseudo-Surround (5.0 and 5.1)
- Improved audio channels downmix management ('Downmix.avsi' functions are always called when dowmnmix is required)
- Improved handling of VFR sources
- Updated A2DSource.avsi to handle FrameRateNum and FrameRateDen as input parameters to A2DVideoSource()
- Updated SRT ReSync routine to handle constant shift times (i.e. when AviSynth Trim is activated)
- Updated .style file generation routine to support MicroDVD format for hard-encoded subtitles font customization
- Updated AviSynth warning at startup if currently installed release is below 2.6.0
- AVSMeter updated to release 2.0.6 (changed ConUseSTDOUT=1 in AVSMeter.ini)
- Improved log activity
Bye
MrC
AVStoDVD Homepage
Old 18th September 2015, 00:03   #2833  |  Link
manolito
manolito's Avatar
Thanks a lot for the new version, works like a charm...
This new feature
requires an update of my Wavi_Mod plugin. Here it is:
http://www39.zippyshare.com/v/ojgGwzb1/file.html
Main changes:
The SoX based upmix routines now integrate into AVStoDVD in a fully transparent way
BS1770Gain updated to the current version 0.47
Several bug fixes
Cheers
manolito
Old 18th September 2015, 00:40   #2834  |  Link
manolito
manolito's Avatar
FFMpegSource and HEVC (H.265) source files
ffms2 v. 2.17 which comes with AVStoDVD cannot decode HEVC source files. To handle these sources you have to update ffms2.
You can either use the official Myrsloik builds at GitHub, or the C-plugin builds by qyot27.
The official builds should work right out of the box (I could not test them because they won't run on my old CPU). The C-plugin builds can also be used transparently by AVStoDVD, but it requires a little tweaking. BTW you find the latest build here:
http://forum.doom9.org/showthread.ph...37#post1739037
If anyone is interested in using a qyot27 build, let me know...
Cheers
manolito
Old 18th September 2015, 08:11   #2835  |  Link
SuLyMaN
Yay. Thanks man. What about the feature of autoloading of subs? I read that this functionality is now possible. Has it been integrated in avstodvd yet?
Thanks!
SuLyMaN is offline   Reply With Quote
Old 18th September 2015, 08:53   #2836  |  Link
Przemek_Sperling
Thank you. Truly great software.
Przemek_Sperling is offline   Reply With Quote
Old 18th September 2015, 09:22   #2837  |  Link
Sir Didymus
@SuLyMaN
Please be patient... This subs autoloading feature still needs some refinements (and further testing from the side of the BatchMux middleware) before its introduction into one alpha or beta release of AVS2DVD...
I am working on this - as reported in the thread freshly created on the restart of the BatchMux development. In the next hours there will be a consolidation of the BM test cases... And some other news... Even if the subject addresses mostly MrC, I will keep all users and interested people well informed and updated on the matter...
Cheers
SD
Sir Didymus is offline   Reply With Quote
Old 18th September 2015, 16:07   #2838  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@SuLyMaN
as SD said, I still have to test the new BM feats. Of course it is one of the top priorities, but release 2.8.3 release was actually ready since some days.
Stay tuned
Bye
MrC
AVStoDVD Homepage
Old 20th September 2015, 15:42   #2839  |  Link
snarfies
Will HCenc ever be updated? .28 has been out for some time now...
snarfies is offline   Reply With Quote
Old 20th September 2015, 15:50   #2840  |  Link
Groucho2004
What? The last update was August 16th, 2015.
[IMG] code is Off
