9th October 2017, 00:34 | #46362 | Link | |
Beyond that, the "reduced random noise" and reduce compression artifacts" do wonders for some of my noisier 480p content. Last edited by cyberscott; 9th October 2017 at 00:35. Reason: spelling |
9th October 2017, 00:55 | #46364 | Link |
Hmmm...not sure how I feel about the new compression removal. If I'm watching something with lots of grain it seems to target the grain and make the image appear processed. It's a double edged sword.
I guess it's mostly for DVD sources, as it's not really needed for blu-ray or 4K. |
9th October 2017, 02:16 | #46366 | Link |
Madshi,
After upgrading to 0.92.5, mpc-hc will crash if drag another video file to the player. It never happened before. BTW, the crash will occur with or without the new reduce compression artifacts options. Edit: I should have read the new posts before posting. The hot-fix version fixed the crash problem for me. Edit2: 'automatically detect hard coded black bars' seems to cease to working with the 'reduce compression artifacts' on. Last edited by Anima123; 9th October 2017 at 02:24. |
9th October 2017, 02:35 | #46367 | Link | ||
All in all, seriously awesome job!
9th October 2017, 02:45 | #46368 | Link | |
EDIT: Obviously have now seen the 0.92.5b fix and can confirm it does fix it. Awesome!
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 9th October 2017 at 02:52. |
9th October 2017, 02:54 | #46369 | Link |
Wow if you really want to see what those options in madVR can really do, grab a copy of Remo Williams The Adventure Begins on DVD. Mine is the crappy 4:3 release and the detail is just incredible. That is a HORRIBLY bad release so the fact that there's now clear details upscaled to 1080p is freaking incredible.
9th October 2017, 03:18 | #46370 | Link |
Which among the chroma upscalers works best with "artifacts cleaning" algorithms?
I'm using NGU standard low, med & high. I'm getting a lot of dropped frames. I have GTX 960
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
9th October 2017, 05:34 | #46371 | Link |
no way "reduce compression artifacts" and "reduced random noise" make impossible result on 576 2d Anime
with long time and alot of traying difrrent denoise filters (QTGMC, hqdn3d, eDeen, FluxSmooth, TemporalCleaner, Deen, dfttest,DeGrainMedian, RemoveGrain, gradual denoise, mplayer temporal noise reducer, denoise 3d) and i tray many noise reduction highend plugins ( topaz denoise, MSU Denoiser, Neat Video, Denoiser II, Red Gian denoiser ) and also i tray many programs ( CyberLink PowerDVD Ultra, corel windvd ) every one from this has big Common defect, in low strength settings it destroy the images, While keep alot of noise and artifacts,The higher strength settings totally destroy the images and blured it much. only waifu2x do great job, in 2d Anime it can tottly clean the noise and compresing artifacts, While keep the images sharp and crisp, put to do that it take very long time (4 second for every frame ) now madvr do it again and offer the best solution ever, the new algorithm in strength settings (3 : 8) do Almost the The same efficiency Like waifu2x, it tottly clean compression artifacts and noise, While keep the images sharp, crisp and never blured or destroyed lines or details. With observation, that madvr algorithm do that in realtime, it much much faster than waifu2x and alot of highend noise reduction plugins. Comparison rca = reduce compression artifacts rnn = reduce random noise low-res artifacts Source image ngu anti alias very hight ngu sharp very hight adobe premiere pro+magic bullet denoiser iii ngu sharp very hight+sw scaler gaussian blur ngu sharp very hight+denoise3d hq ngu sharp very hight+rca8 ngu sharp very hight+rca4+rrn4 waifu2x(UpRGB)(noise_scale)(Level3)(1920x1080) more Comparison http://www.mediafire.com/file/30an3q...reenshots1.rar sd anime channels in prpgdvb now look clean and crisp like full hd channels in my opinion, no mor need to nnedi3, As long as no need to waifu2x himself NGU now Unbeatable in 2d 3d Anime, such as normal life content @madshi, no words can thank you as you should, so you are the best Last edited by ABDO; 9th October 2017 at 13:49. |
9th October 2017, 07:15 | #46373 | Link |
Some NGU sharp here a touch of reduce compression artifcats there and a sprinkle of Adaptive Sharpen and 720 never looked so good.
That exciting time when you have to revisit your profiles.. RCA at 1 works well, I wouldn't mind a setting or two below it though. Last edited by ryrynz; 9th October 2017 at 08:29. |
9th October 2017, 09:27 | #46374 | Link | ||
It's based on Kepler architecture, as my laptop card (see my signature, along with the driver version I use), and it works the same way for me as well. Quote:
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 9th October 2017 at 10:01. |
9th October 2017, 10:29 | #46375 | Link |
I have the same issue with 092.5 crashing bringing MPC-HC from fullscreen on secondary monitor to windowed on primary monitor. Going back to 092.4 fixed the issue.
update, 092.5b fixed the issue. Last edited by Razoola; 9th October 2017 at 10:32. |
9th October 2017, 13:25 | #46377 | Link |
Dolby isn't exactly open and forthcoming how their stuff should work, you know.
9th October 2017, 14:16 | #46378 | Link |
Isnt there a way to just forward the metafiles so the TV can handle it or sth.? And what if you have a file with HDR10 AND DV, is there a way to deactivate the HDR10 somehow so the TV only uses the DV layer? Just as a secondary question if you dont mind ^^
9th October 2017, 17:48 | #46379 | Link |
What Upscalling option is better for 1080p to 4k in my case
Hi Madshi, what upscalling option do you think is better for me , I playing bluray / 1080p high bitrate videos on a 4k tv lg uf8500, mpc-be ,lav filters 0.72.77 along with SvP to do 60fps, my hardware is a I7 3770k, Gtx 1070, 8gb of ram.
9th October 2017, 17:50 | #46380 | Link |
Quick thoughts about new madVR algorithms:
1) On my samples RRN often smooths severe blocking more effectively than same strength RCA. 2) GTX1060 3Gb is on the limit for 1080p60 RCA/RRN processing, I have to overclock it to minimise dropped frames. 3) RCA with strength=4..6 is very effective for reducing mosquito noise on H.264 HD videos with a lack of bitrate (like game recordings from YouTube/Twitch), sharpness loss is slight. 4) RCA with strength=1..3 is effective for reducing slight/moderate compression artifacts on various H.263/MPEG-4 ASP (XviD etc.) non-cartoon SD encodings, detail loss is visible but acceptable. 5) Unfortunately RCA/RNN is in general detail destructive for non-cartoon SD video, however other denoising filters may be even more destructive. EDIT: Conclusion: great work, as usual!
I'm infected with poor sources. Last edited by cork_OS; 9th October 2017 at 18:29. |
