24th December 2007, 12:46 | #161 | Link |
@gp2221,
There is an open source decrypter since a while: http://forum.doom9.org/showthread.ph...08#post1027108 |
24th December 2007, 17:12 | #162 | Link | |
Have you used this tool? After spending the $6.50 or so for the rights to download the archive, I can't get it to work on my system. There aren't any instructions other than a sample command line. Or, I might be using the wrong tool. I have the Barenaked Ladies 'Everything to Everyone' CD/DVD combo. The DVD "Everything else" has both the VIDEO_TS and AUDIO_TS folders. The audio includes both 24/96 surround and 24/96 stereo files. I would like to convert/decrypt to multichannel and stereo wav files and then I can encode to FLAC or WMA lossless to play from my computer. At least the other tool, PPCMRipper, helps you generate to wav, but I couldn't get that to work either. I don't know what dvdcpxm.exe is suppose to create. When I run it - C:\Rip\dvdcpxm.exe g:\audio_ts\ATS_01_1.AOB d:\barenaked I get the following prompts: Simple DVD-Audio AOB/VOB Decrypter Processing media key block... Unprotected media is loaded in drive g: Nothing to do, exit! This is after inserting the DVD in my DVD drive (G. |
24th December 2007, 17:33 | #163 | Link | |||
Just copy the AOB files to your hdd, and use DVDAExplorer_a7.exe to demux the audio streams. I wrote a guide on this stuff a while ago: http://avisynth.org/mediawiki/DVDAGuide |
28th December 2007, 00:32 | #164 | Link | |
1.The Sonic filters "Sonic HD Demuxer" and "Sonic Cinemaster@Audio Decoder 4.3.0" 2.Surcode MLP I can't find the Sonic filters and can't afford the Surcode MLP encoder. There is a Surcode MLP demo version that does not encode. Will this version generate WAVs? |
28th December 2007, 09:21 | #165 | Link | |
http://forum.doom9.org/showthread.php?t=125966 |
28th December 2007, 16:36 | #166 | Link |
There is an open source MLP decoder since a short while which can be used within AviSynth:
http://forum.doom9.org/showthread.ph...19#post1064419 (read also the posts after this for how you should use this in AviSynth) Note that your audio will be downsampled to 16 bit (which is a restriction of ffmpeg) when using this decoder. Yes, that guide is a bit outdated, but i would like to wait with updating until this MLP decoder is integrated in ffmpeg (they are still fixing bugs ...). |
28th December 2007, 17:34 | #167 | Link | |
"The format of the source file could not be detected." This is when I try using an mlp file that was created by an extraction from DVD-Audio Explorer. It might have something to do with the channel order. It looks like my mlp file is using this channel order: ID 20: Group 1 (Lf, Rf, Ls, Rs), Group 2 (C, LFE) and I'm not sure if eac3to can work with this. I also don't know if I need to install a bunch of new decoders or if they are included with the zip file. Anyhow, it looks like I've got a lot of reading to do. Thanks for the link. Any advice for making this work is much appreciated. |
28th December 2007, 17:37 | #168 | Link | |
28th December 2007, 17:43 | #169 | Link | |
6th January 2008, 01:20 | #170 | Link | |
I got 3 wavfiles now. test_clfe.wav test_lfrf.wav test_lsrs.wav Is it possible to extract those 3 files, so that I get in the end 5 high quality mono wav files? |
6th January 2008, 13:30 | #171 | Link | |
v = Blankclip() a = WavSource("D:\test_clfe.wav") AudioDub(v,a).GetChannel(1) # first channel (c) |
6th January 2008, 14:54 | #172 | Link |
Got now 6 mono waves. Made from that a mlp with surcode, and again with disk welder a dvd-audio. But on a standaloneplayer again after 10 sec finished. I don't understand that powerdvd is playing the dvd-audio without any problem. Even the HQ part. Is there perhaps a way to stream the output from powerdvd? |
6th January 2008, 15:42 | #173 | Link | ||
