Old 26th February 2013, 19:07   #61  |  Link
Daemon404
Originally Posted by paradoxical View Post
So this is odd. The fix I made works for certain clips to get all frames whereas others crash when reading the last frame. Continuing to debug it.
Welcome to the wonderful world of libavcodec. \o/
Daemon404 is offline   Reply With Quote
Old 26th February 2013, 19:19   #62  |  Link
paradoxical
Posts: n/a
Actually the issue wasn't on libavcodec. The decoding code was getting caught in an infinite loop for some of the streams on the last frame. Why some did and some didn't is weird, but once I changed the logic the decoding worked on all streams. Diff file for the changes is here. It's actually a pretty small change.
Old 26th February 2013, 19:30   #63  |  Link
Daemon404
I'll poke it a bit tonight or tomorrow morn.
Thanks!
Do you have a name/email I can put in the git history as the author?
Old 26th February 2013, 19:31   #64  |  Link
paradoxical
Posts: n/a
If you want I can send you an actual pull request through github.
Old 26th February 2013, 19:33   #65  |  Link
Daemon404
Sweet. Go for it.
Old 26th February 2013, 19:39   #66  |  Link
paradoxical
Posts: n/a
Done.
Old 26th February 2013, 20:05   #67  |  Link
Daemon404
Done.
Merged. It'll be in beta6 (or v0.1... bugs are getting low now). Whenever that is.
Old 26th February 2013, 21:58   #68  |  Link
paradoxical
Posts: n/a
Cool. Glad to have helped that get solved.
Old 13th March 2013, 03:17   #69  |  Link
Daemon404
So I've written a working prototype of a D2V creation utility in Perl, and it seems to work cross-platform. I'll have to get off my ass and write it properly in C so I can release it soon...
Old 13th March 2013, 15:17   #70  |  Link
Revgen
Good news. Glad to hear.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 21st May 2013, 11:10   #71  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
I'm trying to hold myself, but looks like I can't do it anymore. So I have to ask, was there any progress on that?
Just want to mention that if people don't post much, doesn't means they don't need it
Old 22nd May 2013, 22:05   #72  |  Link
Daemon404
Mostly just laziness and busyness are holding it up. Moving between continents and hectic work schedule. But mostly, I need to get up the motivation to write the large amount of boilerplate code that the libavformat and libavcodec cumbersome APIs require to do anything. I'll set a tentative date of "before June 1st^H^H^H^H^H^H^H^Hmid june.".
For now, here's my horrible hacky perl script: https://gist.github.com/dwbuiten/5630882
It's pretty broken, hacky, inefficient, and is missing several features, but the basic idea is there.
Thanks for the wake up call!
Old 21st August 2013, 11:25   #73  |  Link
opteronup
Please help me to compile this package on Arch linux.
When I try to compile this package, I receive this error:
==> Starting pkgver()...
==> Updated version: vapoursynth-plugin-d2vsource-git 20130428.a6741ad-1
==> Starting build()...
CXXFLAGS/LDFLAGS checking...
checking for libavformat...
checking for libavcodec...
settings...
CXX = g++
LD = g++
STRIP = strip
CXXFLAGS = -Os -ffast-math -Wall -D__STDC_CONSTANT_MACROS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I. -I./vs -I./core -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -fPIC -fexcess-precision=fast -DQT_SHARED -I/usr/include/vapoursynth -I/usr/include/qt4 -I/usr/include/qt4/QtCore
LDFLAGS = -shared -Wl,-Bsymbolic -fPIC
LIBS = -lavformat -lavcodec -lvapoursynth
LIBNAME = libd2vsource.so
install path = /home/user/Downloads/vapoursynth-plugin-d2vsource-git/pkg/vapoursynth-plugin-d2vsource-git/usr/lib/vapoursynth
configure finished.
g++ -Os -ffast-math -Wall -D__STDC_CONSTANT_MACROS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I. -I./vs -I./core -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -fPIC -fexcess-precision=fast -DQT_SHARED -I/usr/include/vapoursynth -I/usr/include/qt4 -I/usr/include/qt4/QtCore -c vs/applyrff.cpp -o vs/applyrff.o
g++ -Os -ffast-math -Wall -D__STDC_CONSTANT_MACROS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I. -I./vs -I./core -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -fPIC -fexcess-precision=fast -DQT_SHARED -I/usr/include/vapoursynth -I/usr/include/qt4 -I/usr/include/qt4/QtCore -c vs/d2vsource.cpp -o vs/d2vsource.o
vs/d2vsource.cpp: In function ‘const VSFrameRef* d2vGetFrame(int, int, void**, void**, VSFrameContext*, VSCore*, const VSAPI*)’:
vs/d2vsource.cpp:51:28: error: ‘av_frame_unref’ was not declared in this scope
av_frame_unref(d->frame);
vs/d2vsource.cpp: In function ‘void d2vFree(void*, VSCore*, const VSAPI*)’:
vs/d2vsource.cpp:86:28: error: ‘av_frame_unref’ was not declared in this scope
vs/d2vsource.cpp: In function ‘void d2vCreate(const VSMap*, VSMap*, void*, VSCore*, const VSAPI*)’:
vs/d2vsource.cpp:122:23: error: ‘AVCodecContext’ has no member named ‘get_buffer2’
data->dec->avctx->get_buffer2 = VSGetBuffer;
make: *** [vs/d2vsource.o] Error 1
==> ERROR: A failure occurred in build().
Aborting...
I think the reason is incompatibility with newer versions of ffmpeg, but I'm not sure. I tried with these versions of ffmpeg - 1.1.5, 1.2.2 and 2.0.
Please help!
Thanks in advance.
opteronup is offline   Reply With Quote
Old 21st August 2013, 12:14   #74  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Your ffmpeg is probably not new enough rather than too new (though I thought 2.0 was pretty new...? With ffmpeg releases, who knows.)
I recommend you build the latest ffmpeg from git somewhere (~/, or /opt/) with --enable-static --disable-shared, and make d2vsource use that.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 21st August 2013, 18:29   #75  |  Link
opteronup
Thanks, jackoneill.
I tried with git version of ffmpeg. Now I receive this error:
error: libavformat checking failed.
error: libavformat/avformat.h might not be installed or some libs missing.
Aborting...
I have used --disable-shared --enable-static, as you said. I only did not change the directory, I removed my ffmpeg and installed git version of ffmpeg.
Old 21st August 2013, 20:16   #76  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by opteronup View Post
Thanks, jackoneill.
Uh... run it like this:
PKG_CONFIG_PATH=$ffmpeg_prefix/lib/pkgconfig/ ./configure
where $ffmpeg_prefix is whatever prefix you passed to ffmpeg's configure (the default is probably /usr/local).
Old 21st August 2013, 23:01   #77  |  Link
opteronup
Absolutely the same error.
Do you have a compiled d2vsource package? I do not know which distribution you use but I think I can convert it.
Old 22nd August 2013, 11:21   #78  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Okay... tell me exactly what commands you used to download, compile and install ffmpeg. If you used a PKGBUILD just paste that. Also the config.log from d2vsource.
Old 22nd August 2013, 15:00   #79  |  Link
opteronup
I have used this PKGBUILD for d2vsource
# Maintainer: Gustavo Alvarez <sl1pkn07@gmail.com>
_plug=d2vsource
pkgname=vapoursynth-plugin-${_plug}-git
pkgver=20130226.1dd663c
pkgrel=1
pkgdesc="Plugin for Vapoursynth: ${_plug} (GIT version)"
arch=('i686' 'x86_64')
url="https://github.com/dwbuiten/${_plug}"
license=('GPL')
depends=('vapoursynth')
provides=("vapoursynth-plugin-${_plug}")
conflicts=("vapoursynth-plugin-${_plug}")
makedepends=('git')
source=("git://github.com/dwbuiten/${_plug}.git")
md5sums=('SKIP')
_gitname="${_plug}"
pkgver() {
cd "${_gitname}"
echo "$(git log -1 --format="%cd" --date=short | tr -d '-').$(git log -1 --format="%h")"
build() {
cd "${srcdir}/${_gitname}"
./configure --install="${pkgdir}/usr/lib/vapoursynth" --extra-cxxflags="$CXXFLAGS"
make
package(){
make install
install -Dm644 README "${pkgdir}/usr/share/doc/vapoursynth/plugins/${_plug}/README"
this for ffmpeg 1.1.5, 1.2.2 and 2.0:
# $Id$
# Maintainer: Gerad Munsch <gmunsch@unforgivendevelopment.com>
# Previous maintainer: Rudolf Polzer <divVerent[at]xonotic[dot]org>
# Original maintainer: Ionut Biru <ibiru@archlinux.org>
# Contributor: Tom Newsom <Jeepster@gmx.co.uk>
# Contributor: Paul Mattal <paul@archlinux.org>
# NOTE: This package was derived from 'ffmpeg-full', with some additional codecs
# enabled, and brought up to date to extra/ffmpeg.
# NOTE before flagging this out of date: this PKGBUILD is supposed to have the
# same ffmpeg version as extra/ffmpeg. Once that one got updated, this one
# needs too.
pkgname=ffmpeg-full-extra
pkgver=2.0
pkgrel=1
epoch=1
pkgdesc="Record, convert, and stream audio and video (all codecs; compatible to extra/ffmpeg)"
url="http://ffmpeg.org/"
license=('GPL' 'custom:UNREDISTRIBUTABLE')
depends=('alsa-lib' 'bzip2' 'fontconfig' 'faac' 'lame' 'libtheora' 'libva' 'sdl' 'x264' 'libass' 'libbluray' 'libcaca' 'libiec61883' 'openal' 'twolame' 'libavc1394' 'xvidcore' 'schroedinger' 'v4l-utils' 'speex' 'opus' 'libvpx' 'jack' 'opencore-amr' 'rtmpdump' 'openjpeg' 'libmodplug' 'gsm' 'libpulse' 'vo-aacenc' 'vo-amrwbenc' 'celt' 'gnutls' 'libdc1394' 'libfdk-aac' 'libcdio-paranoia' 'libaacplus' 'libvorbis' 'zlib')
makedepends=('libvdpau' 'yasm' 'pkg-config')
conflicts=('ffmpeg' 'ffmpeg-full' 'ffmpeg-git' 'ffmpeg-full-git')
provides=('ffmpeg' 'qt-faststart')
source=(http://ffmpeg.org/releases/ffmpeg-$pkgver.tar.bz2 'UNREDISTRIBUTABLE.txt')
sha256sums=('940e1bc4f3e185364099b4ba60d4b952615a4232c5641baa3e9f45d4d748130c'
'e0c1b126862072a71e18b9580a6b01afc76a54aa6e642d2c413ba0ac9d3010c4')
[[ "$CARCH" == i686 ]] && _asm='--disable-asm'
build() {
cd ffmpeg-$pkgver
msg "Starting configure..."
./configure \
--enable-shared \
--disable-debug \
--disable-static \
--prefix=/usr \
$_asm \
--enable-avresample \
--enable-bzlib \
--enable-dxva2 \
--enable-fontconfig \
--enable-gnutls \
--enable-gpl \
--enable-iconv \
--enable-libass \
--enable-libbluray \
--enable-libcaca \
--enable-libcdio \
--enable-libcelt \
--enable-libdc1394 \
--enable-libfaac \
--enable-libfdk-aac \
--enable-libfreetype \
--enable-libgsm \
--enable-libiec61883 \
--enable-libmodplug \
--enable-libmp3lame \
--enable-libopencore-amrnb \
--enable-libopencore-amrwb \
--enable-libopenjpeg \
--enable-libopus \
--enable-libpulse \
--enable-librtmp \
--enable-libschroedinger \
--enable-libspeex \
--enable-libtheora \
--enable-libtwolame \
--enable-libv4l2 \
--enable-libvo-aacenc \
--enable-libvo-amrwbenc \
--enable-libvorbis \
--enable-libvpx \
--enable-libx264 \
--enable-libxvid \
--enable-nonfree \
--enable-openal \
--enable-openssl \
--enable-postproc\
--enable-runtime-cpudetect \
--enable-vaapi \
--enable-vda \
--enable-vdpau \
--enable-version3 \
--enable-x11grab \
--enable-zlib \
msg "Starting make"
make
make tools/qt-faststart
make doc/ff{mpeg,play,server}.1
package() {
cd ffmpeg-$pkgver
make DESTDIR="$pkgdir" install install-man
install -D -m755 tools/qt-faststart "$pkgdir/usr/bin/qt-faststart"
install -D -m644 "$srcdir"/UNREDISTRIBUTABLE.txt "$pkgdir/usr/share/licenses/$pkgname/UNREDISTRIBUTABLE.txt"
# How to audit the ./configure flags:
# cut -c 3- <<'# EOF' | sh
# cd src/ffmpeg-1.2
# export DISABLED='
# # debugging flags follow:
# --enable-coverage
# --enable-extra-warnings
# --enable-ftrapv
# --enable-memalign-hack
# --enable-memory-poisoning
# --enable-random
# --enable-xmm-clobber-test
# # we do not want this:
# --enable-cross-compile # not cross building
# --enable-gray # slow
# --enable-hardcoded-tables # no advantage
# --enable-lto # slow build
# --enable-pic # not our job to decide this
# --enable-shared # handled by options before --prefix
# --enable-small # we want SPEED instead
# # this stuff does not build:
# --enable-frei0r # circular dependency
# --enable-libaacplus # does not build from AUR: configure.ac:8: error: "AM_CONFIG_HEADER": this macro is obsolete.
# --enable-libflite # configure fail: /usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.2/../../../../lib/libflite.a(au_alsa.o): In function "audio_open_alsa": (.text+0x20): undefined reference to "snd_pcm_hw_params_sizeof"
# --enable-libilbc # configure fail: /tmp/ffconf.lccg5Ux6.c:1:18: fatal error: ilbc.h: No such file or directory
# --enable-libnut # link fail: /usr/bin/ld: /usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.2/../../../../lib/libnut.a(muxer.o): relocation R_X86_64_32S against ".rodata" can not be used when making a shared object; recompile with -fPIC
# --enable-libsoxr # only as -git in AUR
# --enable-libstagefright-h264 # not in AUR
# --enable-libopencv # circular dependency
# --enable-libutvideo # compile fail: libavcodec/libutvideodec.cpp:64:18: error: "UTVF_RGB24_WIN" was not declared in this scope
# --enable-libxavs # does not build from AUR: /usr/bin/ld: common/i386/deblock.o: relocation R_X86_64_32 against ".rodata" can not be used when making a shared object; recompile with -fPIC
# # this stuff is not for linux/x86:
# --enable-avisynth # windows only
# --enable-sram # not x86
# --enable-thumb # not x86
# ./configure --help | perl -ne 'for(/--enable-([0-9a-z-]+)\s/) { if($ENV{DISABLED} !~ /^--enable-$_\b/m) { print " --enable-$_ \\\n"; } }' | sort -u
# EOF
# vim:set ts=2 sw=2 et:
and this one for ffmpeg git:
# Maintainer: Rudolf Polzer <divVerent[at]xonotic[dot]org>
# Original maintainer: DrZaius <lou[at]fakeoutdoorsman[dot]com>
pkgname=ffmpeg-full-git
pkgver=0.51608.495ed19
pkgrel=1
pkgdesc="Record, convert, and stream audio and video (all codecs; git version)"
depends=('faac' 'lame' 'libtheora' 'libva' 'sdl' 'x264' 'libass' 'libbluray' 'libcaca' 'libiec61883' 'openal' 'twolame' 'libavc1394' 'xvidcore' 'schroedinger' 'v4l-utils' 'speex' 'opus' 'libvpx' 'jack' 'opencore-amr' 'rtmpdump' 'openjpeg' 'libmodplug' 'gsm' 'libpulse' 'vo-aacenc' 'vo-amrwbenc' 'libsoxr-git' 'celt' 'gnutls' 'libdc1394' 'libfdk-aac' 'libcdio-paranoia')
makedepends=('git' 'yasm' 'libnut-git' 'utvideo' 'pkg-config')
conflicts=('ffmpeg' 'ffmpeg-git' 'ffmpeg-full')
provides=('ffmpeg' 'ffmpeg-git' 'qt-faststart')
source=('git://git.videolan.org/ffmpeg#branch=master'
sha256sums=('SKIP'
_gitname="ffmpeg"
pkgver() {
cd "$srcdir/$_gitname"
microver="$(git log -1 --pretty=format:%h )"
minorver="$(git rev-list --count HEAD)"
echo "0.$minorver.$microver"
build() {
./configure \
--disable-shared \
--enable-debug \
--enable-static \
--prefix=/usr \
--enable-bzlib \
--enable-gnutls \
--enable-gpl \
--enable-libass \
--enable-libcaca \
--enable-libcdio \
--enable-libcelt \
--enable-libfaac \
--enable-libgsm \
--enable-libnut \
--enable-libopus \
--enable-libpulse \
--enable-librtmp \
--enable-libsoxr \
--enable-libspeex \
--enable-libutvideo \
--enable-libv4l2 \
--enable-libvpx \
--enable-libx264 \
--enable-libxvid \
--enable-nonfree \
--enable-openal \
--enable-openssl \
--enable-vaapi \
--enable-vda \
--enable-vdpau \
--enable-version3 \
--enable-x11grab \
--enable-zlib \
msg "Starting make"
make
make doc
package() {
# cd src/ffmpeg
# export DISABLED='
# --enable-coverage
# --enable-ftrapv
# --enable-random
# --enable-dxva2 # windows only
# EOF
And this is config.log when I build with ffmpeg 1.2.2:
all command lines:
--install=/home/user/Downloads/vapoursynth-plugin-d2vsource-git/pkg/vapoursynth-plugin-d2vsource-git/usr/lib/vapoursynth --extra-cxxflags=-march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4
int main(void){ return 0;}
g++ conftest.cpp -o conftest -Wall -D__STDC_CONSTANT_MACROS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I. -I./vs -I./core -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -fPIC
0
g++ conftest.cpp -o conftest -Os -ffast-math -Wall -D__STDC_CONSTANT_MACROS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I. -I./vs -I./core -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -fPIC
0
g++ conftest.cpp -o conftest -Os -ffast-math -Wall -D__STDC_CONSTANT_MACROS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I. -I./vs -I./core -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -fPIC -fexcess-precision=fast
0
#include <libavformat/avformat.h>
int main(void){avformat_find_stream_info(0,0); return 0;}
g++ conftest.cpp -o conftest -Os -ffast-math -Wall -D__STDC_CONSTANT_MACROS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -I. -I./vs -I./core -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -fPIC -fexcess-precision=fast -DQT_SHARED -I/usr/include/vapoursynth -I/usr/include/qt4 -I/usr/include/qt4/QtCore -lavformat -lavcodec -lvapoursynth
0
#include <libavcodec/avcodec.h>
int main(void){avcodec_find_decoder(AV_CODEC_ID_NONE); return 0;}
0
setting
CXX = g++
LD = g++
STRIP = strip
SRCDIR = .
libdir = /home/user/Downloads/vapoursynth-plugin-d2vsource-git/pkg/vapoursynth-plugin-d2vsource-git/usr/lib/vapoursynth
I think there is a problem with libdir. I also noted that in file "configure" from d2vsource on line 74 the libdir is "/usr/local/lib/vapoursynth" but on my Arch linux vapoursynth libs are in "/usr/lib/vapoursynth". I changed that from "/usr/local/lib/vapoursynth" to "/usr/lib/vapoursynth", but something modifies it during compilation. After compilation libdir is again "/usr/local/lib/vapoursynth".
Old 22nd August 2013, 16:14   #80  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Uh, according to the config.log you pasted, the libavformat and libavcodec checks succeeded.
d2v, dgindex, vapoursynth
