27th June 2015, 10:50 | #3001 | Link |
@wanezhiling
mkvmerge not like these subtitles. many warnings.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
27th June 2015, 12:19 | #3003 | Link | |
I look this subtitle file - and don't see any such colors inside ...
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
27th June 2015, 12:49 | #3005 | Link |
Cut small part (e.g. 0:0:15 - 0:0:25) of mkv file using mkvmerge split parts feature so we get the fonts plus the dropped lines (hopefully). Your sample may be bad, we don't have what you have. And watch out for mkvmerge error messages, as I said: your ASS file is broken.
Or maybe even make binary sample (using e.g. DGSplit). Last edited by sneaker_ger; 27th June 2015 at 12:55. |
27th June 2015, 13:07 | #3006 | Link |
I think i know what's wrong. Ignore or broken handle command:
Clip (vector drawing) \clip(<drawing commands>) \clip(<scale>,<drawing commands>) \iclip(<drawing commands>) \iclip(<scale>,<drawing commands>)
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 27th June 2015 at 13:11. |
27th June 2015, 13:16 | #3007 | Link |
MPC-HC 1.7.6.235 (0a52e4b) - with color
MPC-HC 1.7.6.250 (8ae02c6) - without color Aegisub (CSRI/xy-vsfilter_aegisub) - with color Aegisub (libass) - many colors
27th June 2015, 14:13 | #3008 | Link |
Bug in Transform_SSE2() function.
28th June 2015, 07:16 | #3009 | Link |
@wanezhiling
I removed the limitations appeared then - https://github.com/mpc-hc/mpc-hc/com...0c7271c9651b06 Perhaps these limitations are useful in some cases. But I think they are not implemented correctly. We need more samples for clarity.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 4th July 2015 at 11:33. |
29th June 2015, 18:18 | #3011 | Link |
As I promised, this is a version with untouched code, just the new OSD Controls, icon and toolbar. I'll be touching the code in the next few weeks to see what I can do with the actual GUI and the playlist part of it.
MPC-BE "GUiMAGiNATiON MOD" PRE-ALPHA 1 - build 534 - X64 What's in it: - New OSD Controls - New Controls Toolbar - New EXE Icon What's coming: - New unique file icons for every single extension supported [PRE-ALPHA 2 to PRE-ALPHA 3] - Modernized native GUI (main, backgrounds, playlists) [ALPHA 1 to FINAL] DOWNLOAD |
30th June 2015, 13:11 | #3012 | Link |
Thanks, nice to see this finally being looked at. Love the icon and it's taskbar status display.
The OSD controls looks nice but I feel some icons are a bit thin, perhaps thicken them up a bit to look similar to the cog, the i and the x. The controls toolbar I think would look better if it was the same shade of grey as the GPU icon or there abouts with the GPU icon also being the same color. |
30th June 2015, 19:40 | #3013 | Link | |
I will re-do the controls toolbar to be flat dark-grey, kind of just exactly as you want it. You might expect it soon. The icons on the toolbar will also change it from Win8 standard to Win10 as soon as I get my hands on proper assets for those controls. Guess I'll have to wait for Visual Studio 2015 on July 20th |
2nd July 2015, 19:35 | #3014 | Link |
Saw this version has different set of bug fixes.
does this handle HTTP RTMP streams better than MPC-HC. When I watch an RTMP stream on Kodi (XBMC) it works really well (at least doesn't crash often), on MPC-HC the stream doesn't buffer well and is prone to crashing. Curious if that was fixed/enhanced in this version. |
4th July 2015, 17:17 | #3015 | Link |
https://www.sendspace.com/file/iowzfu
Audio needs a long time to catch the video after seeking... Wmp12 performs flawlessly. |
4th July 2015, 18:52 | #3016 | Link |
Where can I get an updated mingw toolchain which supports MPC-BE, the 64bit libgcc.a / libmingwex.a lib's I have which work are now almost 2 years old, all the new ones seem to result in a failed compile.
Thanks
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
4th July 2015, 19:24 | #3017 | Link |
@VipZ
Actual link in Compilation.txt.
4th July 2015, 20:10 | #3018 | Link | |
4th July 2015, 20:59 | #3019 | Link | |
MPC-HC Helper xD
4th July 2015, 21:52 | #3020 | Link | |
