30th August 2012, 03:51 | #521 | Link | |
Yes, I'm weird.
https://dl.dropbox.com/u/18695757/Test_Avisynth_2.6_MT.7z Like Boulder, I also get those plugins from this post: http://forum.doom9.org/showthread.php?p=1568142#post1568142 After I replace those plugins with their original versions, the error doesn't occur any more. But they're worked fine with previous builds. |
30th August 2012, 05:55 | #523 | Link | |
Yes, I'm weird.
About GrainFactory3.avs, I don't know. Last edited by the_weirdo; 30th August 2012 at 06:05. Reason: Additional info |
30th August 2012, 06:42 | #525 | Link | |
SEt
Thanks for the build Quote:
----- Attached DirectShowSource.dll for 2.6. |
30th August 2012, 16:00 | #526 | Link |
Plugins in that post, as forclip said, need to be recompiled for the "new-new" interface. Personally I suggest using classic interface if you don't need something from the "new-new" one.
In SeeSaw.avsi it's clearly the discussed situation of working bugged code due to ints masking as floats. The script should be changed this way: Code:
function sharpen2(clip clp, float strength, float power, float zp, float lodmp, float hidmp, int rgmode) { STR = string( strength ) PWR = string( 1.0/power ) |
30th August 2012, 16:24 | #527 | Link |
契約者
So everything that stopped working I have to modify by hands (in case of script) or get recompiled version (in case of plugin)? Why not just roll back changes that caused this?
Btw this is only MT build, or normal one affected too? |
30th August 2012, 16:59 | #528 | Link |
What "everything" is stopped working? I see only plugins built especially for that one build of Avisynth and one previously hidden bug in one script surfaced (what is a good thing).
No idea what "normal one" build you are referencing to. |
30th August 2012, 18:08 | #529 | Link |
契約者
Well this is my bad English. Perhaps "anything" suits better there? I have a bunch of scripts that stopped working in new build and that doesn't use any plugins from -Vit-. They return message that invalid arguments was passed, maybe some other messages too. But it works with previous build. I'm not going to investigate which scripts are problematic and where exactly these problems appear.
P.S. There was build (official?) without MT capabilities. This is what i called "normal" Last edited by Keiyakusha; 30th August 2012 at 18:11. |
30th August 2012, 20:09 | #530 | Link |
The int-float change just exposed the hidden problems that you can stumble upon anyway with different parameters for your scripts.
The last "official" build is from 25.05.2011 I think. You are free to use it, but personally I find nothing great there. |
30th August 2012, 20:53 | #531 | Link |
契約者
I have compiled version from 08.02.12. What I'm actually asking is if this change that "broke" some things is in the trunk or this is your custom upgrade? I said about "normal" version before because some time ago MT stuff wasn't part of the avisynth 2.6, not officially. maybe things changed I don't know. I don't follow actual avisynth development so I'm lost a bit. I don't really need MT stuff anyway. If I still can compile it without MT and this latest change - this is fine. But If everything affected by this change- it really should be rolled back.
31st August 2012, 09:35 | #535 | Link | |
契約者
Edit: What will happen if google will fix buggy behaviour in vp8 bitstream? Or any of the old bugs in vsfilter will be fixed? It will lead to lost compatibility with something but will bring... I don't know what so good it will bring. To me situation with this latest avisynth change looks very similar. And for example, I have tons of scripts and plugins that I don't even remember where I found and how many times modified. If any of these affected too, I don't see how they will be fixed unless I'll do this myself. Last edited by Keiyakusha; 31st August 2012 at 12:02. |
31st August 2012, 11:54 | #536 | Link |
Yes, I'm weird.
To be honest, I use these builds because they're up-to-date with CVS (which contain some fixes that I may encounter), not because of MT feature. I'm still using a Wolfdale desktop CPU so MT doesn't have much benefit for me. But I don't want to wait for a new official build. I wish there were someone willing to compile "nightly" builds for Avisynth 2.6.
Actually I didn't intend to complain or anything, I just want an additional option for those who cannot wait for those buggy scripts are fixed (I doubt they'll be fixed by their author), like Mosu have done with feature "header compression" of Matroska for MKVtoolnix. I don't use many function scripts and it's trivial for me to fix them (because it's just int-float misplace). P.S. My English is really poor so if there're offending words or sentences then it's not my intent. Last edited by the_weirdo; 31st August 2012 at 12:02. |
3rd September 2012, 15:57 | #538 | Link | |
Latest statistics about marketshare of different Windows versions: http://marketshare.hitslink.com/oper...11&qpcustomb=0 42.52% of all users still use XP. It would be a very bad idea to drop XP support at this time already... Cheers manolito |
4th September 2012, 21:46 | #539 | Link |
Anime addict
@Set After of updating avisynth with your current version, I got this error:
With version 2012.05.16, it didnt success. Script used: Code:
SetMemorymax(1024) SetMtMode(5,4) DGDecode_mpeg2source("D:\DBZ\DBZ1_12\071\Title_7.d2v", info=3) ColorMatrix(hints=true, threads=0) #NO deinterlace #crop&resize (0,0,-0,-0) #Opening D0=Trim(0,2615).Crop(8,0,-6,-4).Spline64Resize(720,480) #Resumen D1=trim(2616,4077).Crop(2,0,-2,-0).Spline64Resize(720,480) #Titulo D2=trim(4078,4281).Crop(2,0,-2,-0).Spline64Resize(720,480) #Capitulo - 1 parte D3=trim(4282,18303).Crop(2,0,-2,-4).Spline64Resize(720,480) #Cortinillas D4=trim(18304,18595).Crop(2,0,-2,-0).Spline64Resize(720,480) #Capitulo - 2 parte D5=trim(18596,32431).Crop(2,0,-2,-4).Spline64Resize(720,480) #Ending D6=trim(32432,34735).Crop(2,0,-2,-0).Spline64Resize(720,480) #Avance D7=trim(34736,0).Crop(4,0,-2,-6).Spline64Resize(720,480) UnalignedSplice(D0,D1,D2,D3,D4,D5,D6,D7) ################################### # FILTRADO # ################################### Setmtmode(2) original=last aa=spline64Resize(width(original)*2,height(original)*2).SangNom(aa=29).spline64Resize(width(original),height(original)).mergechroma(original) prefiltrado= dfttest(sigma=4,tbsize=1,tmode=0,lsb=true).ditherpost(mode=2) super=Msuper(prefiltrado) backward_vec3 = MAnalyse(super, isb = true, delta = 3, overlap=4,search=4) backward_vec2 = MAnalyse(super, isb = true, delta = 2, overlap=4,search=4) backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4,search=4) forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4,search=4) forward_vec2 = MAnalyse(super, isb = false, delta = 2, overlap=4,search=4) forward_vec3 = MAnalyse(super, isb = false, delta = 3, overlap=4,search=4) prefiltrado.MDegrain3(super,backward_vec1,forward_vec1,backward_vec2,forward_vec2,backward_vec3,forward_vec3, \thSAD=370,plane=4,lsb=true).ditherpost(mode=2) contrasharpening(last,aa) toon(0.10) gradfun3()
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
5th September 2012, 06:35 | #540 | Link |
Use the stable 2.5 API (i.e. mt_masktools-25.dll) if you don't want to rebuild the filters but want the latest Avisynth version.
People, these builds are not user-friendly: they are pretty stable and as bug free as possible, but API changes and breaking something old already broken are to be expected. Do not expect that everything will behave as in previous build, especially if you use 2.6 features. |
