Old 15th December 2012, 22:45   #41  |  Link
jkauff
Originally Posted by soneca View Post
I can not convert any wav file to other formats, and the log is not clear on this issue.
When the TAC does not finish the task, the log is not saved in text format.
Copied and sent to you.
I can reproduce this on both 24 bit and 16 bit WAV files. Odd considering that TAC correctly converted my 24 96 FLAC to WAV and then to 24 48 FLAC according to the log. For my WAV test I converted from FLAC to WAV using dbPoweramp, in case that has a bearing on the problem.
Old 16th December 2012, 03:43   #42  |  Link
jkauff
Update: I tried the same test decoding with foobar2000, with the same result.
Old 16th December 2012, 14:21   #43  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
Log is saved as log.txt in application folder after TAC is closed and overwritten all the time.
When you select that wav file in the list, what do you see in "Audio Track" list over file list? Is first number -1?
ozok is offline   Reply With Quote
Old 16th December 2012, 14:36   #44  |  Link
soneca
That's right,
-1, PCM, 1411.2 Kbps, 2 channels, 44.1Khz, unknown
soneca is offline   Reply With Quote
Old 16th December 2012, 14:40   #45  |  Link
ozok
ozok's Avatar
Same here too. Looks like there is a problem with stream indexes.
Old 16th December 2012, 15:02   #46  |  Link
ozok
ozok's Avatar
Please try that exe.
Old 16th December 2012, 15:26   #47  |  Link
soneca
Yes, apparently is working properly.
Ozok,
I think those bars indicating the use of memory and cpu could have a name in front of each, so that the indication it easier to visualize. It's just an opinion.
Old 16th December 2012, 16:25   #48  |  Link
jkauff
Both 16 bit and 24 bit WAVs convert perfectly with the new .exe,
with one slight exception--setting bit depth to "Original" does not work on the 24 bit, it converts it to 16 bit. Setting bit depth explicitly to 24 bit works fine.
Old 16th December 2012, 18:43   #49  |  Link
soneca
Confirmed.
To keep the bit depth in the wav files you must specify.
The same happens with flac files. In auto mode the bit depth is changed to 16 bits.
Old 17th December 2012, 15:51   #50  |  Link
ozok
ozok's Avatar
Ok, I will look into that problem.
Old 18th December 2012, 05:58   #51  |  Link
bilditup1
bilditup1's Avatar
Quits with a meaningless log when I try to feed an 8ch, 24-bit wav (decoded from 6.1 DTSHD with Arcsoft/eac3to) for use with qaac. Use of the same file with qaac directly is just fine.
bilditup1 is offline   Reply With Quote
Old 18th December 2012, 13:24   #52  |  Link
jkauff
Did you specify 24 bit on the UI? We've already established that the "Same as source" setting doesn't work properly.
Old 18th December 2012, 16:18   #53  |  Link
ozok
ozok's Avatar
Update:
-Added: Files without an audio stream will not be added to list
-Added: Summary will be added to log
-Removed: "Custom Options" tab
-Removed: enc_fhgaac.dll, libmp4v2.dll and nsutil.dll (Please see \Tools\fhgaacenc\Readme.txt)
-Fixed: Selecting "Bit Depth" as "Original" did not have any effect
-Fixed: If encoding stopped and re-started progress window shows wrong info
-Fixed: Some audio only files could not be encoded (thx to jkauff and soneca)
-Fixed: If output folder does not exist, it will be created (thx to Meeko)
-Fixed: Some VOB files caused "x not integer" error (thx to Rollin)
-Updated: QAAC to 2.09
-Updated: OpusEnc to build using libopus 1.0.2
Old 19th December 2012, 04:44   #54  |  Link
bilditup1
bilditup1's Avatar
No, I specifically changed that setting to 16-bit. No joy.
Old 19th December 2012, 09:51   #55  |  Link
ozok
ozok's Avatar
What settings are you using? Can you send log.txt?
Old 21st December 2012, 01:11   #56  |  Link
ozok
ozok's Avatar
Update:
-Added: Support for 3gp files (thx to Rollin)
-Fixed: "m4a" will be used instead of "aac" when extracting streams (thx to Rollin)
-Fixed: Copied streams will be extracted to their own folders
-Fixed: Created temp. wav files will be always little-endian (thx to Rollin)
Old 23rd December 2012, 19:17   #57  |  Link
bilditup1
bilditup1's Avatar
LOL, works now on version 0.6.1. I didn't try it on 0.6 but I'm assuming the changes were made for that. This'll be much more convenient than piping from eac3to to qaac, though I suppose I'll have to keep doing that until your program can decode TrueHD and DTS-MA.
I love the polish of this program though. Nice updating, pretty straightfwd UI...good stuff man.
Old 26th December 2012, 14:41   #58  |  Link
ozok
ozok's Avatar
Update:
-Added: Support for Monkey's Audio and TTA codecs
-Added: Support for 3ga files (thx to botface)
-Added: More tag fields for Opus
-Added: Option to reset number of process to ideal value
-Fixed: Wma and 3gp files could not be drag&dropped
-Fixed: Problems while extracting FLAC and AMR streams from videos (thx to Rollin)
-Fixed: MPC quality value was not saved
-Fixed: "Year" tag converted to "Date" for FLAC files
-Fixed: Wrong "Year" tag was passed to Lame.exe
-Updated: AlphaControls to 8.13
-Updated: QAAC to 2.10
Old 26th December 2012, 22:12   #59  |  Link
soneca
New version, cool!
Old 27th December 2012, 23:38   #60  |  Link
soneca
Some problems with the percentage bar(converting large files) and distortion gui after conversion finished.
I'll do some more tests, no time.
