Old 12th December 2012, 05:53   #21  |  Link
S_Prince
Looking really nice!!!
I'll try It right away.
S_Prince is offline   Reply With Quote
Old 13th December 2012, 13:57   #22  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
Thanks for your comment.
Originally Posted by jkauff View Post
Ozok,
Just tried your program tonight--very nice indeed, especially the SoX and Mediainfo integration (this coming from a dbPoweramp user).
One request: Can you change the behavior of the warning message about the number of processes setting? I have a quad core (non-hyperthreading) CPU, but I get the warning if I specify more than 3 processes. Your program doesn't max out my cores using 4 processes.
One question: What criteria did you use to determine the initial settings of the various codecs? I'll do some research over at Hydrogenaudio for the ones I'm not familiar with, but I'm curious how you decided on your initial settings.
Thanks for a great program.
1) I'll turn it to a message in log. I get annoyed by it too.
2) Most of the initial values are defaults I got from backend's help. But bitrates and other quality related values are mostly random. If you find an error or have any suggestions, please feel free to contribute anytime.
ozok is offline   Reply With Quote
Old 13th December 2012, 16:29   #23  |  Link
jkauff
I downsampled some FLAC files from 24/96 to 24/48 the other night, and the converted files play at half-speed. Do you think I set something wrong, is this a SoX bug, or is there something in your default command line that caused the speed change? I'll play around with it again when I get home tonight.
Old 13th December 2012, 19:21   #24  |  Link
ozok
ozok's Avatar
I can be more help if you can provide log of that encode.
Old 14th December 2012, 00:56   #25  |  Link
jkauff
Don't have the original log, but here's the one from the latest attempt. I noticed the resulting file is 16/48, not 24/48.
File Type: txt log.txt (610 Bytes, 10 views)
Old 14th December 2012, 01:26   #26  |  Link
soneca
Ozok,
Really, any conversion where an downsampling the result is a file with double the time and bit depth is also changed to 16 bits
The conversion(Sox) of this type of file to wav hangs halfway.
And, even if Sox is not used for the conversion files with the bit depth is above 16 the bit depth lowered to 16 bits.
soneca is offline   Reply With Quote
Old 14th December 2012, 13:50   #27  |  Link
jkauff
I was able to successfully downsample the files by using dbPoweramp to convert to WAV, using R8Brain to downsample, and re-encoding to FLAC with dbP. foobar2000 (using SoX plugin), also does the conversion successfully, so it seems to be a problem with the TAC version of SoX or the command line being passed to SoX.
I guess another possibility is that TAC is not decoding FLAC to WAV correctly for 24/96 files.
Old 14th December 2012, 15:49   #28  |  Link
ozok
ozok's Avatar
@soneca and @jkauff I've fixed sampling rate problem. TAC was passing wrong commands to backends. Can you please confirm it by using that TAC.exe?
I will look into bit depth problem and hopefully release a new version tonight.
PS. I liked the sound of TAC jkauff
Old 14th December 2012, 16:41   #29  |  Link
soneca
Confirmed.
The sampling rate is fixed and the conversion to wav is working well.
Old 14th December 2012, 16:46   #30  |  Link
ozok
ozok's Avatar
Originally Posted by soneca View Post
Confirmed.
Thanks, I will release an update tonight.
Could you guys send me a 24bit FLAC sample, all my FLAC files are 16bit.
Old 14th December 2012, 17:44   #31  |  Link
jkauff
I'll send you a sample in a few hours when I get home.
Old 14th December 2012, 19:53   #32  |  Link
Brazil2
http://www.2l.no/hires/index.html
Brazil2 is offline   Reply With Quote
Old 15th December 2012, 00:02   #33  |  Link
ozok
ozok's Avatar
Originally Posted by Brazil2 View Post
Epic, thanks very much.
Old 15th December 2012, 01:42   #34  |  Link
jkauff
https://dl.dropbox.com/u/29526622/ND%20Clip.zip
Here's a clip from one of the files I was converting.
Old 15th December 2012, 01:47   #35  |  Link
ozok
ozok's Avatar
Update:
-Added: Support for .wma files
-Added: Option to specify bit depth (thx to jkauff and soneca)
-Improved: Deleting files from file list is now faster
-Improved: Process count warning is now added to log (thx to jkauff)
-Fixed: Changing sampling rate caused problems
-Fixed: Memory bar now shows memory used (thx to soneca)
-Fixed: Some UI problems occuring after encoding is done
-Fixed: Tags with '"' in them caused problems
-Updated: QAAC to 2.07
-Updated: OpusEnc to build using libopus 1.0.1
Old 15th December 2012, 05:01   #36  |  Link
soneca
Thank you!
Old 15th December 2012, 16:37   #37  |  Link
soneca
Ozok,
Some problem in converting wav files.
Old 15th December 2012, 17:40   #38  |  Link
ozok
ozok's Avatar
Ozok,
Can you be more specific?
Old 15th December 2012, 18:57   #39  |  Link
jkauff
My 24/96 FLAC files converted perfectly to 24/48 FLAC. Thanks for the quick fix!
Old 15th December 2012, 20:10   #40  |  Link
soneca
I can not convert any wav file to other formats, and the log is not clear on this issue.
When the TAC does not finish the task, the log is not saved in text format.
Copied and sent to you.
