19th August 2009, 18:35 | #2181 | Link |
Wewkiee
Attached is hrd 16. it will patch to 1217. There is also a workaround for an inconsistency (not a bug) in x264. i_fps_den is sometimes the value passed from the frame server but other times its LCD to i_fps_num. so i just commented out the line. considering it only does anything when the den/num can be reduced, other times having no effect.
- x264_reduce_fraction( &h->param.i_fps_num, &h->param.i_fps_den ); + //x264_reduce_fraction( &h->param.i_fps_num, &h->param.i_fps_den ); the framerate section of the sps of a PAL movie will take as many bits now as the sps of a NTSC movie. (negligible) this should end the assert errors seen sometimes on PAL.
...yeah...but...why on earth would I compare apples with apples? Last edited by Trahald; 19th August 2009 at 21:29. |
19th August 2009, 20:09 | #2183 | Link |
x264 core:72 r1217M 32-bit
Download Built by rack04 on August 19, 2009, 2:05:45 PM CST
19th August 2009, 22:20 | #2184 | Link |
もこたんインしたお!
x264 r1217 64bit unpatched:
download ; hash
x264 r1217 32bit download ; release notes
x264 r1217 64bit download ; release notes
patched with:
Changing dates is what I get from building stuff near midnight.
[I'm human, no debug]
20th August 2009, 21:54 | #2185 | Link |
もこたんインしたお!
x264 r1222 64bit unpatched:
download ; hash
x264 r1222 32bit download ; release notes
x264 r1222 64bit download ; release notes
patched with:
Guess what is down again, m'kay~ and back up.
21st August 2009, 08:52 | #2186 | Link |
Strictly Rhythm
x264_x64_r1222_unpatched | MD5
GCC 4.4.1 20090803 (x64.core2.Komisar), unpatched, generic, fprofiled ________________________________________________________________________________ x264_x86_r1222_techouse | INFO GCC 4.4.1 20090803 (x86.core2.Komisar), fprofiled, -march=core2 x264_x64_r1222_techouse | INFO GCC 4.4.1 20090803 (x86_64.core2.Komisar), fprofiled, -march=core2 Patches used: x264_hrd_pd_interlace.16.diff x264_win_zone_parse_fix_06.diff
21st August 2009, 09:12 | #2187 | Link |
|ン、)
r1222M built with ICC.
Windows: x264-r1222M-imk-win.7z win_build_info.txt Mac OS X: x264-r1222M-imk-osx.7z osx_build_info.txt On a side note, I started updating my benchmark spreadsheet with r1217. x264 Benchmarks There's still some I need to finish up with the placebo test, but you can get an idea from all the other results. If you don't understand what all of the numbers or headers mean, click on the "Information" label at the top. |
21st August 2009, 10:56 | #2188 | Link |
My 1222 versions of x264:
http://komisar.gin.by/ In addition I published a gdb-6.8.50.20090821-cvs (32/64-bit) (need more testing) |
21st August 2009, 14:05 | #2189 | Link |
@imk:
Your x86 32Bit build doesn't work at all on system. If i want to start an encoding nothing happens, but the process keeps running with 25% cputime (single threaded) like in an infinite loop. I have a C2Q Q9550 E0 on Win 7 x64 RC. The 64Bit build works fine though, so it is nothing dramatic to me. Edit: r1163 is the latest that works with me, but auto thread detection and the progress indicator do not work. I hope that helps in some way... Last edited by alwa; 21st August 2009 at 14:31. |
21st August 2009, 14:40 | #2190 | Link | |
|ン、)
If you have time, come find me on Freenode in #x264. I use the nick Dopefish there. |
22nd August 2009, 07:18 | #2191 | Link |
A deadly Taru!
x264 r1222 built with gcc 4.4.0
Compiler options:
Patches:
22nd August 2009, 13:01 | #2192 | Link |
Silent Reader
Tried encoding some PSP videos with imk build 1222 in MeGUI (manually copied x264 into folder).
x264 crashed each time. Tried same with Techouse build 1222, no crashes... On the other hand, imk 64bit in Ripbot264 works great, so problem seems to be in 32bit build. Last edited by Wishbringer; 22nd August 2009 at 13:03. |
22nd August 2009, 13:25 | #2193 | Link |
|ン、)
Yeah, all of the problems seem related specifically to the 32-bit build. It all started happening around the time MBTree got committed. You should be using the 64-bit build if you have a 64-bit OS anyway.
When I get some time I'll try and make some debug builds so I can narrow down what's going on. The 32-bit build works fine during profiling and benchmarking, but aside from that, I haven't actually used the 32-bit build to encode anything. |
24th August 2009, 09:06 | #2194 | Link | |
LE : techouse and imk crash jeebs work i will make a debug build tomorrow.
25th August 2009, 10:11 | #2195 | Link |
x264_r1232_juGGaKNot
GCC 4.4.1, fprofiled, patched Code:
Source: GIT Applied patches : x264_win_zone_parse_fix_06.diff Please check Doom9.org patches thread, and GIT shortlog for more info. Compiled by juGGaKNot with GCC 4.4.1 on Windows XP SP-2 32-bit. Platform: X86 System: MINGW asm: yes avis input: yes mp4 output: yes pthread: yes debug: no gprof: no PIC: no shared: no visualize: no |
25th August 2009, 12:26 | #2197 | Link |
|ン、)
r1232M built with ICC.
Windows: x264-r1232M-imk-win.7z win_build_info.txt Mac OS X: x264-r1232M-imk-osx.7z osx_build_info.txt |
25th August 2009, 12:34 | #2198 | Link | |
25th August 2009, 12:39 | #2199 | Link |
Strictly Rhythm
x264_x64_r1232_unpatched | MD5
GCC 4.4.1 20090803 (x64.core2.Komisar), unpatched, generic, fprofiled ________________________________________________________________________________ x264_x86_r1232_techouse | INFO GCC 4.4.1 20090803 (x86.core2.Komisar), fprofiled, -march=core2 x264_x64_r1232_techouse | INFO GCC 4.4.1 20090803 (x86_64.core2.Komisar), fprofiled, -march=core2 Patches used: x264_hrd_pd_interlace.16.fix.1232.diff x264_win_zone_parse_fix_06.diff
25th August 2009, 13:07 | #2200 | Link |
もこたんインしたお!
x264 r1232 64bit unpatched:
download ; hash
x264 r1232 32bit download ; release notes
x264 r1232 64bit download ; release notes
patched with: I will upload release notes with the changelogs later on as I will have time :3 Nothing really has changed on that side, for the exception of the nal_hrd patch version of course, so I guess it's alright.
Last edited by JEEB; 27th August 2009 at 08:49. Reason: removing links since the next build contains the changelogs |
h.264, x264, x264 builds, x264 patches, x264 unofficial builds |
