27th March 2012, 10:47 | #10121 | Link |
QuickSync Decoder author
Hi Nev,
I've release a new version that fixes playback under WMC FSE. Because I didn't want to break ffdshow's design there's one limitation - under WMC only, I will enable SW emulation to pass media type checks and also play in SW codec profiles unsupported by HW (but supported in SW). Basically the same D3D9 limitations as your DXVA implementations under FSE. If you want to make LAV perfect with respect to FSE (e.g. fix your DXVA under FSE at the same time) you should: * Perform decoder media type checks after the renderer is connected and a D3D9 device manager is retrieved. * Fallback to SW if the checks fail.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
27th March 2012, 11:28 | #10122 | Link |
Off-topic but I figured you guys would know:
What's the best program to use for sorting out installed codecs and their merits? It can kind of be done within MPC-HC but it's fiddly and I'm sure there's an easier way.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
27th March 2012, 14:38 | #10124 | Link |
n00b
I think that default is set in the MKV file, so you would have to remux the MKV file with a different subtitle set as default, and probably a different audio stream set as default while you are at it. Since the language are identical I don't think the splitter could pick up styled against signs, since that field does not follow any standard labelling.
27th March 2012, 15:18 | #10126 | Link | |
For example If I have an entire TV series where the sub id and track name is identical in each episode, I can go to splitter settings and enter the track id or number. This will basically eliminate the time I need to manually change the default subs with the header editor for each episode. Anyway this problem only occurs when you have multiple subs with the same language, otherwise you just go in LAV Splitter settings and change the default lang. Last edited by sidi0us; 27th March 2012 at 15:22. |
27th March 2012, 15:28 | #10127 | Link |
LAV Filters 0.50
LAV Splitter - Improved support for H264 Elementary Streams - Fixed a regression with seeking in MPEG-TS files recorded by some HD-PVR devices LAV Video - New Worker Thread design for Decoding/Deinterlacing - WMV9+YADIF is up to 40% faster - Improved DXVA2 for MPEG-2 interlaced - Improved H264 DXVA2 on AMD with certain streams - Improved CUVID support for 4K streams on supported hardware (GT520, GTX680, other VP5 hardware) LAV Audio - Added support for RealAudio Lossless (RALF) This has been cooking for a while, and i think its ready now. Mostly small bugfixes, and of course the new worker thread in LAV Video. Right now, only the WMV9 decoder really benefits from it, but it was the slowest decoder too. I hope no problems with the worker thread remain, it should've been thoroughly tested by now. As a side note, the 301.10 NVIDIA driver seems to have fixed the MPEG4-ASP problems, at least it works on my new GTX680. Additionally, CUVID should now work with 4K streams on VP5 cards, although its not extremely fast (37-40 fps in my short tests), however DXVA2 seems to still have issues (crashes). I think its driver related. Just a quick FYI, development might be a bit slower for the next few month, i have another project that needs more attention (completely unrelated to Video things).
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 27th March 2012 at 15:35. |
27th March 2012, 15:32 | #10128 | Link | |
If you want to set the merits systemwide (of course, that'll depend on the player's preference as well), there's Win7DSFilterTweaker. I'm assuming you're on Windows 7. |
27th March 2012, 15:39 | #10129 | Link | |
27th March 2012, 15:39 | #10130 | Link | |
Wow~~ |
27th March 2012, 15:41 | #10131 | Link |
Matroska find' ich toll
hi nev
thanks for the new version. i hope the most of problems are solved and now you have time to implement -ordered chapter support - and the Tray-Icon to manage the Editions and other things. its very hard for me to see that LAV grow up and i cant use it. Is LAV splitter able to handle the MKV-Menu features (ChapterProcess; ChapterProcessCodecID...)? |
27th March 2012, 15:52 | #10132 | Link | |
http://bluesky23.yu-nagi.com/en/index.html (supports 32 & 64 bit) An other very handy one is DSFM http://www.softella.com/dsfm/index.en.htm (only 32 bit, but runs fine on Win7 x64) I use mainly these 2. Last edited by Pat357; 27th March 2012 at 15:57. |
27th March 2012, 17:22 | #10133 | Link |
Thx for the new version!
Is it possible to set up the splitter so that it prefers Danish subtitles - and English when no Danish are available? This has to be regardless of whether they are embedded or external. Right now I have a file that has Danish external subtitles but I have to select them manually once playback starts. If I set mpc-hc to prefer external it chooses the external ones regardless of language it seems. |
27th March 2012, 18:03 | #10134 | Link |
The splitter cannot control external subtitles. In fact, it doesn't know about them at all.
27th March 2012, 18:13 | #10135 | Link | ||
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 Last edited by DragonQ; 27th March 2012 at 18:17. |
27th March 2012, 21:30 | #10138 | Link | |
I don't really have much faith in free encoders for ac3 or dts tbh. You can use reclock if you absolutely need a software encoder. There are sound cards with dolby digital live and dts connect also. I'm not clear on how smart they are in determining when to encode (ie, do they only encode multichannel?) Also, not clear on if they properly downmix 7.1 to 5.1 before encoding. Or you can start using analog. |
