12th August 2009, 19:27 | #521 | Link |
I choose the same framerate as input and output, both 29.97, how come the output timecode is slightly different than the input?
One example: Input: start: 00:55:28.070 end: 00:55:32.100 Ouput: start: 00:55:28.058 end: 00:55:32.095 Also is there a way to not convert the images? I just want to extract the subpictures generated from PunkGraphicStream to png+xml. Last edited by hamletiii; 12th August 2009 at 19:32. |
12th August 2009, 20:41 | #522 | Link | ||
Author of BDSup2Sub
Then again, if there are palette animations etc., BDSup2Sub will remove them. Then again, stuff like this is not supported by the BDN XML format anyway. |
12th August 2009, 21:41 | #523 | Link | |
Is there a way to keep the timecodes as is? I noticed that this feature didn't get introduced prior to ver2.0. Last edited by hamletiii; 12th August 2009 at 21:59. |
12th August 2009, 22:11 | #524 | Link | |
Author of BDSup2Sub
Besides: what possible benefit could it have to start or end a subtitle in between frames? Most obviously nothing can be displayed between two frames anyway. No, as this would make absolutely no sense. |
18th August 2009, 16:33 | #527 | Link |
Standalone Player that supports vobsubs
Hello,
does anyone know which standalone player already supports vobsubs in mkv? I already know that the wd-media player support it. But I'm looking for a standalone player with network support. So I tested the new player: Asus O!Play HDP-R1 and Xtreamer. Both doesn't play vobsubtitles. |
19th August 2009, 17:46 | #532 | Link |
In the AVS2BDNXML thread we discovered a problem that seems to be an error in BDSup2Sub.
The problem is that when doing a BDN XML to BR Sup conversion the subtitles sometimes appear and/or disappear 1 frame too late. In this sample you'll see that while the subtitle should appear on frame 24 (timecode "00:00:01:00" in bdn xml notation, first frame being frame #0) it appears on frame 25 in the resulting .sup file. When re-converting the file you'll get the correct timing (timecode "00:00:01:00") in the resulting xml though. |
25th August 2009, 07:22 | #533 | Link |
Suptitle, MediaPlayer.NET
I'd like to run some effect filters over my subs (PGS sup files), such as drop shadow, brightness / contrast adjust etc.
BDSup2Sub probably doesn't do this yet but I'd like to see it implemented. Ideally, I'd like to use the plugin filters written for Paint.NET. |
28th August 2009, 00:03 | #536 | Link |
Thanks so much!
I just wanted to drop by and say thank you so much for this project/utility! My general philosophy on DVD and now Blu Ray archiving is that if the original disc has it, I want to archive it - including all the subtitles in languages that I don't even know how to read :P I had started looking at some .sup to .srt (text) tools that use OCR but that doesn't really work for me with languages like Arabic and Thai which don't use the Roman alphabet. I have successfully archived two blu ray movies so far (with all their subtitles in tact) to .mkv files and I used BDSuptoSub for the subtitles (and mkvmerge GUI in the mkvtoolnix to mux them back in to the mkv file.) I think I might even work on writing a guide and I'll be sure to include a link to this thread.
Thanks so much! Note: I have written a guide detailing how to create a digital archive copy of a Blu Ray movie and I included a section on using BDSup2Sub. It can be found here. Last edited by minerva.thegift; 28th August 2009 at 20:27. |
30th August 2009, 16:15 | #538 | Link | |
Author of BDSup2Sub
"Some technical background / Palette Modes". In an nutshell: multicolored text is lost when converting from 255 to 3 opaque colors. |
30th August 2009, 20:43 | #539 | Link | |
