17th July 2010, 14:57 | #961 | Link | |
But I think that the registration isn't the cause of my problem anyways, as the filter actually tries to play back the file. |
17th July 2010, 22:17 | #963 | Link | |
Software Developer
However it should be noted that the problem I'm observing is different from what you describe: I do get output and the output is constantly updated, the only problem is that the output looks completely "scrambled". Also it doesn't crash here.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th July 2010 at 10:29. |
26th July 2010, 17:16 | #965 | Link |
At the end of the month. I am delayed by something recently.
The Next Generation Internet Video Codec project.[/url]. |
18th August 2010, 00:42 | #967 | Link |
schweinsz has been busy on this:
http://forum.doom9.org/showthread.ph...10#post1426910 Perhaps now he will find time for the 64-bit support. |
18th August 2010, 09:16 | #969 | Link | |
> 4-C 343-45DF-A46E-EC1711E4EE32}\\rgtcode" and "CLSID\\{083863F1-70DE-11d0-BD40-00A0C911CE86}\\instance\\{5DFA20A4 > -C3 43-45DF-A46E-EC1711E4EE32}\\password", then run the DiAVC Registration.exe to generate the machine code and input the password, then try it in the MPC-HC.
18th August 2010, 09:44 | #970 | Link |
No, still crashes.
With the previous version it would not instantly crash but instead show a few of the first frames. As it seems to attempt to play the file I'm not sure if the activation is the right spot to look at in finding a solution. |
18th August 2010, 10:34 | #971 | Link | |
unzip it and run the now1.bat, check that if it crashes.
18th August 2010, 19:41 | #975 | Link |
No, the activation is in the decoder. your information means that the problem is within the filter.
18th August 2010, 20:46 | #976 | Link |
Ok, I did something different: instead of installing "for all users", I only installed "for me". Now MPC-HC doesn't instantly crash but instead shows a black screen and playback does not start.
Could it have something to do with any rights? If I start MPC-HC "normally" and open the filter settings it does not list the registration data. If I open as administrator it does list the registration data - but it does not play nonetheless. I'm on Windows 7 x64 with UAC enabled. |
18th August 2010, 21:19 | #977 | Link |
20th August 2010, 10:38 | #979 | Link |
Hello schweinsz.
How do I access the DiAVC properties page ? I have got it working from DGAVCdecDI and MPC-HC, but I can't get to configure DiAVC itself. thanks audyovydeo >>> UPDATE : forget it - just found it from MPC-HC !!! cheers a/v |
22nd August 2010, 07:40 | #980 | Link |
ZZZzzzz...
I've noticed that while DiAVC plays H.264 files properly, using it makes MPC-HC sluggish. During playback, MPC's menus' respond to clicks very slowly and sometimes not at all. I checked my system's cpu usage during playback, at it is below 12%. My cpu is an Intel Core2 6400 btw. It should be noted that videos play just fine (no dropped or delayed frames). Is this normal?
avc, diavc, fastest decoder, h.264, software |
