Old 25th July 2019, 23:14   #56941  |  Link
Asmodian
Sorry, smooth motion is the frame blending I mentioned. Smooth motion syncs to the audio even more perfectly than with it off, the difference is unimportant but smooth motion is the most accurate.
You will not have any sync issues when using smooth motion.
madVR options explained
Asmodian is online now   Reply With Quote
Old 25th July 2019, 23:19   #56942  |  Link
ScrooW
Thank you so much for your attention and patience.
ScrooW is offline   Reply With Quote
Old 27th July 2019, 23:21   #56943  |  Link
XTrojan
Hi! Been reading around here in the forums about OS HDR vs Nvidia HDR. Is it still recommended to use NV HDR over OS HDR or are they the same thing by now? I've red that OS HDR handles everything by itself and sends no metadata but other posters have disputed this.
XTrojan is offline   Reply With Quote
Old 28th July 2019, 00:04   #56944  |  Link
Asmodian
As far as I am aware the situation has not changed in anyway. Use NV HDR because Windows' is a one size fits all solution that will mess with the video while madVR can control Nvidia's HDR.
Old 28th July 2019, 17:36   #56945  |  Link
-Michael-
Is it possible to save a movie with the settings of madvr?
Is it possible to save a movie with the settings of madvr? For example, if I have an SD video, can I convert it to HD with the madvr upscaler?
-Michael- is offline   Reply With Quote
Old 28th July 2019, 18:07   #56946  |  Link
this is practical possible but madVR is not design for that and there are multiply problems with recording.
Old 28th July 2019, 18:15   #56947  |  Link
-Michael-
How can this be done?
Old 28th July 2019, 18:24   #56948  |  Link
-Michael-
It would be wonderful madvr could be used with premiere adobe or other similar software. Until now, I haven't found any software that makes the upscaler like Madvr. Precisely for this reason I asked if there is a way to save a movie using the madvr upscaler.
Old 28th July 2019, 18:52   #56949  |  Link
el Filou
el Filou's Avatar
If you use a screen recorder that outputs AVC or HEVC using the hardware encoders available with modern graphics cards, or something like FRAPS if you want lossless output (other better apps can be available, I haven't followed recent development), you should be able to grab the result of madVR rendering that way. I've never tested it so can't guarantee the results, try it.
madVR outputs with Direct3D so it should work like when recording a game. (Edit: the only exception is if you use overlay rendering, I think)
Old 29th July 2019, 00:43   #56950  |  Link
Annisman
Hey guys, when I play 4K HDR content MadVR (cntrl+j) reads 'BT2020 -> DCI-P3.... Can someone tell me is this what I want ? What does that mean ?
Annisman is offline   Reply With Quote
Old 29th July 2019, 00:51   #56951  |  Link
Asmodian
It means the content is DCI-P3 gamut inside BT.2020 format video. This is normal and what you want in that situation.
Old 29th July 2019, 02:09   #56952  |  Link
Annisman
Thank you friend
Old 29th July 2019, 07:05   #56953  |  Link
-Michael-
Originally Posted by el Filou View Post
If you use a screen recorder that outputs AVC or HEVC using the hardware encoders available with modern graphics cards, or something like FRAPS (....)
I tried to record with Bandicam and managed to capture the video stream. Thank you.
I make a proposal to the developer: If you make MadVr available as a plug-in for Adobe press, Magix video deluxe and Pro X, etc. etc. you will make many people happy.
In addition to the plug in, a simple converter to save a movie directly with MadVr (stand alone), would be greatly appreciated.
Thank you for your work so far. Hoi tried many programs to make the video upscaler, but MadVr, for me, is the best ever.
Old 29th July 2019, 07:28   #56954  |  Link
cremor
I don't have experience with this, but aren't there upscalers for video encoders that are far better than what madVR can do? madVR upscalers are limited to what can be done in real time, but an upscaler designed for video encoding is allowed to be far slower - and therefore might have a higher quality.
cremor is offline   Reply With Quote
Old 29th July 2019, 09:37   #56955  |  Link
they usually use the CPU and are not even close.
vapoursynth/avisynth integration is or at least was a planned feature.
Old 29th July 2019, 11:01   #56956  |  Link
Klaus1189
But why are these not even close?
Old 29th July 2019, 12:03   #56957  |  Link
mrmojo666
Microsoft released a fox for banding 10bit
https://support.microsoft.com/en-us/...date-kb4505903
Hope it helps
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
mrmojo666 is offline   Reply With Quote
Old 29th July 2019, 12:10   #56958  |  Link
i can't find a single line that talks about banding.
"Updates an issue that may display colors incorrectly when viewing an image on 10-bit display panels." this should have nothing todo with it. the problem is present on all types of display from 6 to 10 bit.
@Klaus1189
image processing is super slow on a CPU even a mainstream GPU is a lot faster then a high end GPU.
there is waifux2 which is "better" but i hope you have time a lot of time.
Old 29th July 2019, 12:17   #56959  |  Link
Alexkral
I think CNN super-resolution could be used for video encoding, I have no idea why this has not been developed. Maybe you need lossless or very high bitrate encoding to notice the difference.
Alexkral is offline   Reply With Quote
Old 29th July 2019, 12:23   #56960  |  Link
nnedi3 is a neural network scaler waifux2 is one and NGU is nearly for sure also trained by a NN too.
there even is nvidia DLSS with questionable quality.
