Old 4th September 2018, 22:28   #701  |  Link
poisondeathray
Originally Posted by preludium975 View Post
I tried DNxHR HQX and GoPro CineForm. All of them, after exporting, at 30 seconds-1 minute intervals duplicate frames. Like fps drop, but not fps drop, its just sometimes duplicate frames.
Here is a test encode for example, at 00:43-00:47. here
Who has an idea?
Did you check at what stage of the process that it occurred ? e.g. is it in your source, in resolve after decoding , after export, or after decoding the export then encoding to your final format ?
What about other export formats ? eg. uncompressed . If that has problem too then that suggests problem with your settings (maybe fps mismatch) or problem with source decoding in resolve
Maybe a mod should move these last few posts , because they have nothing to do with magicyuv
Old 5th September 2018, 00:26   #702  |  Link
WorBry
The 'test encode' is a 720x302, 23.976, AVC.mkv file - there's no way it came out of Resolve.
True.
@Preludium975. I see you registered on the Blackmagic Forum:
https://forum.blackmagicdesign.com/v...it=HDR#p434386
Probably best to address all of your Resolve-related issues there. I'd suggest you give more contextual information though, if you want answers.
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 5th September 2018, 06:08   #703  |  Link
preludium975
Yes, i encoded it with x264. But in the source file also there is the lag. I just don't want to send a 500GiB file.
preludium975 is offline   Reply With Quote
Old 5th September 2018, 06:24   #704  |  Link
WorBry
I'm assuming by that you mean the Resolve export (DNxHR, Cineform) that you used as source for the x264 encoding, not the original (HDR) source? If so then it would point to some FPS-mismatch (likely settings related) going on in Resolve.
Quite honestly if that is your target x264 format and you are only using Resolve for the HDR>SDR conversion, why jump through these hoops, generating large intermediate files in the process - you could do it all with AVISynth(+) or VapourSynth, like Kolak suggested?
Originally Posted by kolak View Post
Is Resolve HDR to SDR conversion any decent? I think you may get as good results natively in avs or vs and avoid whole Resolve route.
Old 5th September 2018, 13:28   #705  |  Link
preludium975
The best Tone Mapper for now the DaVinci Resolve. Yes, I tone mapped HDR->SDR, then I exported it to DNxHR HQX.
I need the Resolve, because this is the best solution.
The last thing, what need to be works, the DNxHR HQX. Because this is a visually lossless encoder. Cineform are great too, but this is also duplicating frames...
Old 5th September 2018, 15:44   #706  |  Link
WorBry
Well if there's a FPS mismatch going on it will appear in the Resolve export whatever the format. Like Poisondeathray said, to pin-point where that is occurring means going through your Resolve project set-up. Really this is not the place for that, but if it brings closure on this issue (and this segment of the thread gets moved anyway):
1. What is the format and FPS of your original HDR source, as declared (Clip Details or Clip Attributes) by Resolve on import ?
2. What is the declared project timeline frame-rate after you have loaded your clips on the timeline. Check in Project Settings > Master Settings > Timeline Format. Resolve defaults to 24FPS. If your source frame-rate is different, when you import the first clip you will be given the option to change the project frame-rate to match the source or leave at default 24FPS, in which case it will be 'locked' at 24FPS - can't be changed subsequently. Otherwise you should set-up the project Timeline Format beforehand. Your problem could be right there. 23.976p source in 24p project maybe ?
3. I'm assuming you didn't mess with Clip Speed/Duration/Retime on the timeline ?
4. What was the render (Delivery) frame-rate setting on export to Cineform, DNxHD ?. Default is the project frame-rate, but there may be other options. A 24 FPS project timeline for example will give the option of exporting at 24, 23.976 or 30 (3:2) FPS. Potential for FPS discontinuity there also.
With that advice you should be able to figure out where FPS discontinuity occurred, if it did. Don't bring it back here though. If you still have issues, address it on the Blackmagic Forum.
Based on what ? Again though, not a point for discussion in this thread.
Edit: Incidentally where exactly (frame sequence position) are the duplicate frames occurring in your 'Test.mkv' file ? Started manually frame stepping through the file with VDub2 but got fed up about a third of the way .
Old 13th July 2019, 14:41   #707  |  Link
Stereodude
According to the e-mail I got earlier in the week v2.1 is out now.
2.1.0
Released: 2019.07.11.
NEW: Added v308, v408 pixel format support (YUV 4:4:4).
NEW: Added 10-bit YUV 4:4:4 compressed format.
FIX: Core: Fixed a bug that prevented encoding of 16-bit planar RGB pixel formats.
Stereodude is offline   Reply With Quote
