2nd December 2013, 22:32 | #1003 | Link |
I just updated MPC-HC to 1.7.1 from sourceforge to see the internal HEVC codec and how well it runs on my computer.
I was however suprised to see that the tv tuner functionality actually works now. I have a Leadtek Winfast 2000XP Expert tuner and it never worked right with previous versions and with VLC and other players. Now it actually works. There is however a small issue and I can't seem to find any way to fix it: the framerate is locked to 29-30 fps while I'm in PAL land and my tv box outputs 25 fps. Basically I can watch TV but it keeps stuttering due to the framerate. Any suggestions about fixing this? (tv box from isp outputs s-video/composite through scart , i'm connecting the composite to composite in on the tv tuner, audio through line in ) Made some screenshots of the filters involved and a snapshot of the main mpc-hc window with the view > renderer settings > display stats text on top of the page to see the stats. Images are in this imgur gallery : http://imgur.com/a/9kSiN In case it helps the pin info text for what I think it's more relevant: Code:
Filter : Smart Tee - CLSID : {CC58E280-8AA1-11D1-B3F1-00AA003761C5} - Connected to: CLSID: {17CCA71B-ECD7-11D0-B908-00A0C9223196} Filter: WinFast TV2000 XP Expert WDM Video Capture. Pin: Capture - Connection media type: Video: YUY2 720x576 25fps 20736kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YUY2 {32595559-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 829440 cbFormat: 88 VIDEOINFOHEADER: rcSource: (0,0)-(0,0) rcTarget: (0,0)-(0,0) dwBitRate: 20736000 dwBitErrorRate: 0 AvgTimePerFrame: 400000 BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 16 biCompression: YUY2 biSizeImage: 829440 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0 pbFormat: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020: 00 68 3c 01 00 00 00 00 80 1a 06 00 00 00 00 00 .h<.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 10 00 (...Ð...@....... 0040: 59 55 59 32 00 a8 0c 00 00 00 00 00 00 00 00 00 YUY2.¨.......... 0050: 00 00 00 00 00 00 00 00 ........ Code:
Filter : WinFast TV2000 XP Expert WDM Crossbar. - CLSID : {71F96460-78F3-11D0-A18C-00A0C9118956} - Connected to: CLSID: {266EEE40-6C63-11CF-8A03-00AA006ECB65} Filter: WinFast TV2000 XP Expert WDM TVTuner. Pin: Analog Video - Connection media type: Unknown AM_MEDIA_TYPE: majortype: MEDIATYPE_AnalogVideo {0482DDE1-7817-11CF-8A03-00AA006ECB65} subtype: MEDIASUBTYPE_None {E436EB8E-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_AnalogVideo {0482DDE0-7817-11CF-8A03-00AA006ECB65} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 48 pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 e0 01 00 00 ........Ð...à... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 e0 01 00 00 ........Ð...à... 0020: d0 02 00 00 e0 01 00 00 00 00 00 00 00 00 00 00 Ð...à........... |
4th December 2013, 01:52 | #1005 | Link |
I didn't even check before but yes, it : see picture
Don't know if it should matter because the filter defaults to composite in + audio line in and that input can normally accept various framerates and the card supports both ntsc and pal so it must support 23.976, 25fps, 29.97 fps etc etc ... I should be able to select the framerate somehow. |
4th December 2013, 12:45 | #1006 | Link | ||
MPC-HC Developer
But don't worry, we're working on improving the performance of the ISR so that it should be fast enough for the complex animated subtitles that are becoming the norm. Last edited by Armada; 4th December 2013 at 12:53. |
5th December 2013, 09:56 | #1008 | Link |
I was watching this ep of HIMYM and noticed the video didn't feel very sharp. Took a screencap here: http://i.imgur.com/DWedBLX.jpg
What might cause this? Source is 720p TVrip, player is MPCHC 1.7.0.7851. Looks like the default video decoder is LAV but I haven't touched it. |
5th December 2013, 10:25 | #1009 | Link |
Did you consider that the encode is just bad?
6th December 2013, 17:06 | #1012 | Link |
I'm having an issue opening h264 video (any container it seems) via an Avisynth DirectShowSource script with MPC-HC. Well it's more than an issue. I can't get it to work no matter what I try. I'm not really sure when it stopped working. Same problem with MPC-HC on two different PCs (both XP). MPC-HC displays an Avisynth error message:
DirectShowSource: Renderfile, the filter graph manager won't talk to me. The same script will open fine using MPC-BE (it results in two Haali Media Splitter and ffdshow icons running, which I think was normal), so could this be something to do with the switch to LAV Filters? I've tried disabling MPC-HC's internal filters and adding the ffdshow video decoder as a preferred external filter, but nothing has worked so far. I've even tried changing renderers. Other methods such as FFVideoSource and AVISource seem to work as they always have (even if the source file contains h264 video). If it helps any, after attempting to open a "problem" DirectShowSource script with MPC-HC and then using the Play/Filters menu, there's three filters listed as follows (in this case the source file was an MKV containing h264 video): Video Mixing Renderer 9 (renderless) Color Space Converter AVI/WAV File source Repeating the process with MPC-BE (which successfully open the script), shows these three filters listed: Video Renderer AVI Decompressor (YV12) AVI/WAV File source Thanks in advance for any help. Last edited by hello_hello; 6th December 2013 at 17:09. |
8th December 2013, 10:25 | #1013 | Link |
recording from capture card by MPC-HC has been crashing for years
is there a solution to this yet?
preview from HD capture card can work pretty awesome with EVR Custom, I can play from xbox in 1080p60 from 1080p60 capable card. but I cant record. -(( is there any combination of record settings that works? thanks |
8th December 2013, 22:36 | #1014 | Link |
Hello all,
I've been using MPC-HC for years. I've been having a problem since a few days and I can't find the solution. The EVR CP renderer has suddenly started being slow, ie, it takes 4-5 seconds to start a video on launch. Things to consider : - This behaviour is new, has been happening for a few days, but I am almost positive nothing special happened on the PC (no new CG drivers, no hardware / software changes...). - Selecting other renderers (for example Haali), videos do start instantly, so it is really EVR CP - specific. - Have tried updating to the latest MPC-HC (1.7.1). Didn't change anything. Player itself launches instantly, but there is a 4-5 seconds lag before video starts playing. - This only applies to the first video being launched. If I hit the "next" button, the next video will start playing immediately. For reference, my setup is Win7 64bits, MPC-HC 64 bits, nVidia 560 Ti. Do you guys have any idea what could be causing this, and how to solve it ? Thanks for your help. I know it shouldn't, but it's driving me crazy. Last edited by ParkerLewis; 8th December 2013 at 22:39. |
9th December 2013, 00:02 | #1016 | Link |
MPC-HC Helper xD
Those who want to help us with localizations please do so here.
https://www.transifex.com/projects/p/mpc-hc/ |
9th December 2013, 01:09 | #1017 | Link |
I'm having crashes with some WMV files. When loading one of the affected files, MPC-HC crashes immediately.
Here is a MediaInfo log from one of the files General Format : Windows Media File size : 193 MiB Duration : 13mn 7s Overall bit rate mode : Variable Overall bit rate : 2 058 Kbps Maximum Overall bit rate : 4 096 Kbps Encoded date : UTC 2013-09-01 22:57:41.375 Video ID : 2 Format : VC-1 Format profile : MP@HL Codec ID : WMV3 Codec ID/Info : Windows Media Video 9 Codec ID/Hint : WMV3 Description of the codec : Windows Media Video 9 - Professional Duration : 13mn 7s Bit rate mode : Variable Bit rate : 2 000 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.072 Stream size : 188 MiB (97%) NumberOfFrames : 23580 Audio ID : 1 Format : WMA Format profile : Pro Codec ID : 162 Codec ID/Info : Windows Media Audio Description of the codec : Windows Media Audio 10 Professional - 48 kbps, 44 kHz, 2 channel 16 bit 2-pass VBR Duration : 13mn 7s Bit rate mode : Variable Bit rate : 49.3 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 4.63 MiB (2%) NumberOfFrames : 2174 Not having problems when using Windows Media Player. Edit: found a workaround, had to disable VC1 playback at LAV filter. Last edited by vio_man; 9th December 2013 at 01:33. |
9th December 2013, 07:50 | #1019 | Link | |
Are you sure nothing changed on your PC? Things like Antivirus or Windows Update do things in background. Check your event logs, Taskmanager etc for anything fishy. You can try to reinstall DirectX and do a "SFC /SCANNOW" from the command line as admin. |
9th December 2013, 10:53 | #1020 | Link | |
MPC-HC Helper xD
dxva, media player classic, mpc, mpc-hc |
