20th February 2008, 15:06 | #1981 | Link | |
I can't get DirectShowSource to work with mkv/mp4/x264 source files to encode to xvid, I wonder if that might work for me. |
22nd February 2008, 13:21 | #1983 | Link |
I have two OTA HD recordings that I wish to encode using MeGUI but for some reason the source can not be detected using the analyze in the AviSynth Script Creator. What can I post so that someone can help me figure out what deinterlace settings to use?
EDIT: Forgot to mention that these files are 720p @ 59.94fps. Last edited by rack04; 22nd February 2008 at 14:22. |
22nd February 2008, 14:59 | #1984 | Link |
Assuming it isn't mixed, just find a clip with lots of motion & step through it using something like VDub (anything that will show the content of each frame without applying lots of processing to it first), a frame at a time. Look for frames which have combing around movement & for 20 or so consecutive frames post whether they show any significant interlacing or seem to be progressive.
The resulting pattern tells you all you need to know in most cases (excluding rare horrid messes). For example, if every frame is interlaced, you need to deinterlace; yadif is nice imho. OTOH if you had a pattern of iipppiippp... this would be typical for film that had been hard telecined to ntsc frame rates & so would need ivtc I'm not sure what patterns are typical for 720p, as it's been a while since I touched any. Iirc I think I've seen iiiipppppp, where every other frame is a duplicate, so keep an eye out for duplicate frames too & report on that. Or just put a short clip up on some file sharing site. Last edited by mroz; 22nd February 2008 at 21:30. |
22nd February 2008, 15:10 | #1985 | Link | |
22nd February 2008, 15:26 | #1986 | Link | |
A few suitable seconds would do, but 10 to 30s would be nice. Just make sure it's from a well lit section with lots of motion - not inside a dungeon with the lights out. |
22nd February 2008, 15:44 | #1987 | Link | |
22nd February 2008, 19:11 | #1988 | Link |
Here is a sample 720p OTA HD MPEG2 clip. Using the analyze function of MeGUI's AviSynth Creator I get source not detected. Could someone analyze the source and tell me how to convert the 59.94 framerate to 23.976? Thanks.
22nd February 2008, 20:32 | #1989 | Link |
rack4: no interlacing, just lots of duplicated frames. The source you want to recover is the sequence abcdef... The material you have presents as aabbbccdddeefff...
So, the pattern repeats with a length of five. From each such block of five frames you want to throw three away. In Megui>AVISynthScriptCreator>Filters, set source as M-in-5 Decimation Required & set M as 3. You can now set the 'deinterlace option' to Tritical Decimate. If you look at the resulting AVISynthScript you should see the line: TDecimate(cycleR=3) Just before any cropping or resizing is done. That's doing the job for you. Preview the script to make sure before encoding. |
22nd February 2008, 20:47 | #1990 | Link | |
24th February 2008, 03:27 | #1992 | Link |
help! cant encode since update
Hi all, I recently got a movie in MKV and I am trying to re-encode it in divx format... I start the encode and everything is running fine... I have a quad core, and I set it to 3 threads but it only uses 50% CPU... anyways, thats not my problem... 20 mins into an encode my monitor goes blank and I cant restore it... I tried turning screensaver off, and nothing works... computer is still on, I think it may have crashed or something... tried multiple times, still nothing... No overheating, so I doubt its any hardware problems... This is since the newest version... any help would be appreciated
25th February 2008, 00:34 | #1993 | Link |
same here. on 2 diff pc;s running vista 64. 1 with and 1 without SP1
C2D E6600, Corsair Nautilus 500 W/C, D975XBX mobo 2x1GB PC6400 G.Skill ZX, 7950 GX2, 4x 74GB Raptor RAID-0, 750GB Seagate, 30" Dell 3007fpw |
26th February 2008, 22:30 | #1995 | Link |
Hi everyone, im trying to convert some videos with Megui but it doesnt convert the audio when nero audio codec is selected, says "error".
I remember that nero audio encoder doesnt get downloaded in the updates, ive instaled nero on: C:\Programas\megui\tools\ndaac can anyone help? Thanks |
26th February 2008, 22:31 | #1996 | Link | |
27th February 2008, 00:41 | #1999 | Link |
MeGUI Version: 0.2.6.1044 OS used: Microsoft Windows XP Professional Service Pack 2 Framework used: 2.0 SP1 ------------------------------------------------------ Generating jobs. Desired size: 2 MB Desired size of this job series: 2 MB Split size of this job series: N/A Looking for job processor for job... Processor found! ------------------------------------------------------ Starting job job5 at 23:59:34 Starting preprocessing of job... Preprocessing finished! successfully started encoding Processing ended at 23:59:34 ------------------------------------------------------ Log for job job5 Error: ------------------------------------------------------ End of log for job5 ------------------------------------------------------ Last edited by ricardo.santos; 27th February 2008 at 00:47. |
megui |
