8th May 2006, 09:36 | #1081 | Link | |
2. The added features of the .divx format are stored in parts of the avi container that will not be read by applications that do not support them. Likewise these feature should not cause problems. However if you edit an .avi (.divx) file with these features and save it the added special features should be lost (not 100% sure about this). 3. Different applications mux audio und video slightly differently which means that the resulting files might be more or less compatible. Since Divx, Inc. created the Divx profiles and certifies Divx players they should know best how to mux files the most compatible way. The bottom line is: Using DivxMux means that you use Divx, Inc. own muxer. This will give you the possibility of enhanced features and might also lead to better compatibility of your encodes without causing any problems (well, I never had one). Edit: You might also want to read these posts by Divx Team members on the topic: http://forum.doom9.org/showpost.php?...0&postcount=59 http://forum.doom9.org/showpost.php?...7&postcount=93 Last edited by Warrex; 8th May 2006 at 10:44. |
9th May 2006, 17:20 | #1082 | Link |
Stax,
You may have fixed this already (I'm a version or two behind at the moment). But currently there does not seem to be a check for available disk space, or even a good mechanism for failing upon reaching that point. I had this happen to me and it took forever to figure out why StaxRip just quit. Of course it can't even write the error to the log because there isn't enough disk space. I was using the command line x264 encode btw. |
10th May 2006, 15:49 | #1083 | Link |
Update for RMVB source.
I do some conversion from rmvb ---> avi and i get avi with audio out of sync.
Doing some tests for looking why that happened I have discovered that problem is in video. I found tutorial for conversion rmvb to avi with VirtualDubMod and proper Avisynth script: DirectShowSource ("filename", fps=25, convertfps=true) fps parameter can be also 23,976 or 29,976. Is any possibility to set this parameter automatically or manually in staxrip? link to tutorial: http://www.jakeludington.com/dv_hack...vert_rmvb.html |
11th May 2006, 07:25 | #1085 | Link |
Bitrate: 75.02 kbps
Video Bitrate: 314 -> 271 This is probably a noob question concerning besweet, but I can't find an answer. I try to encode with a custom audio profile HE-AAC 32 kbps (based on the default profile he-aac vbr 50-70 kbps). How come the audio came out with 75 kbps and my video bitrate suffers because of that? Anyway to correct this situation? Thanks |
11th May 2006, 08:22 | #1086 | Link |
Network XXIII
@nohead
Two ways of reducing the actual bitrate i can think of: VBR Internet
This should lower the bitrate a touch,else use CBR as opposed to VBR: CBR 64
Asus PC-DL | 2 x Xeon 3.06@3.52 | 2GB OCZ PC4000 | Raptors x 2 RAID 0 | 6800Ultra | ATA2400a RAID 5 | Watercooled | Vista Ultimate 32bit | StaxRip 1.0.0.1 |
11th May 2006, 13:31 | #1087 | Link | |
Right. I tried this out and works . Another problem is choose proper fps 23.976, 25 or 29,976 which depense of source video. StaxRip, when file is loaded, shows fps from script not real fps which man can check with Mediainfo. |
11th May 2006, 13:41 | #1088 | Link |
Aging Video Hobbyist
Having trouble processing Jobs
Lately my Jobs list isn't getting processed properly, and I wonder where/how this info is used by StaxRip?
My most recent example: I process an HD Transport Stream (1080i) to a .d2v file, then desire to make two separate .rip jobs from it, first an HD conversion (720p) and then an SD conversion, saving each to the Jobs list. But then only the SD .rip is processed, and it is processed TWICE and the HD is not processed at all. Might it have something to do with how StaxRip parses my filenames ie. that they are too long or something? Here are the names I used: Boston Legal 225 - Squid Pro Quo HD.rip Boston Legal 225 - Squid Pro Quo.rip Yesterday I attempted to run Jobs in the above order, but the 2nd one was run first, and then it appears it was run AGAIN, and when Stax was done the HD hadn't been run at all. Where to look to troubleshoot this? Thanks! |
11th May 2006, 19:25 | #1089 | Link | |
DirectShowSource ("filename", fps=%source_rate%, convertfps=true)
(!sig) |
11th May 2006, 20:31 | #1090 | Link | |
I'm not Avisynth script expert I've do that and error occured during loading file into Staxrip. Audio was demuxed properly. Last edited by pablak; 11th May 2006 at 21:06. |
12th May 2006, 08:45 | #1091 | Link |
Sorry about the delay, I hope I've a couple of hours time sunday.
12th May 2006, 16:25 | #1092 | Link |
As per stax's request here I will explain what I meant.
It is really a matter of me not having Internet connection available where I do the encoding (yes weird, but some computers still are not connected). When I use other GUIs (like MeGUI) I just prepare everything by manually downloading everything I need of the latest version and then keeping track of changelogs and such to keep track of new requirements. The problem I got with StaxRip was that it kept asking me for programs I had not used before, so I did not have them available. If there just would have been some way of knowing which programs it would need to have before I ran StaxRip I could have brought them along too. So the solution would probably have been either a list on the webpage with "these are the programs we use in the latest version" or like a "StaxRip-Standalone_package.zip" which would have included all the required installers alongside with the latest version. The way I solved it was to install StaxRip on another computer, tell it to download each component and then bring it all with me. I would not like to have to do this with every new release though... I understand that this is probably not a common problem and basically "my own fault", so I don't expect anyone to do anything about it but... ...you asked. |
12th May 2006, 22:33 | #1093 | Link |
TeMa=) team member
Location: Universe, Galaxy, Solar System, Earth, Russia, Moscow
-dimzon( -dllname bse_Nero7WA.dll ... ) probuces buggy ouput. There's 50% chance to get corrupted AAC file (muxed movie looses all sound at some point and will remain silenced until i reopen it) and 30% chance to get invalid AAC file (won't mux at all). I observed this only for HE-AAC; LC-AACs produced by this library is fine as far as i can tell.
-bsn(...) works fine as always. EDIT---- No, not fine bsn performs incorrect channel mapping for 5.1 AACs. -azid ( -o ... ) doesnt' works. Looks like i have to continue to tinker with bse_Nero7WA...
Without effort, you can't even pull a fish out of the pond. Without a pond you can't pull it out even with effort. Last edited by LRN; 13th May 2006 at 12:30. |
13th May 2006, 18:31 | #1094 | Link |
Go Nero Digital
I have encountered a problem. I exported from Nero Vision a DV file Type 2....and even though I have ffdshow installed and the file plays in media player, when i do avisource, directshowsource, or any source, the file is unable to be opened, and the codec (dvds or something like that) is not found (thats the error message).
What do I do? |
13th May 2006, 19:11 | #1095 | Link |
Unable to add new Preparer to Project Options
I Added an "Extract audio and index MPEG-2 using DGindex" preparer, edit it, and Rename it and all looks good, but my new option does not survive an Exit from StaxRip--it's gone the next time I launch the program.
Bug? What could I be doing wrong? Could use some help or ideas, as for the other Jobs problem noted a few posts ago. |
13th May 2006, 20:18 | #1096 | Link |
Used Stax before and loved it, but this time I'm running into some problems.
I used DVD Shrink to rip a DVD to VOB files so i can backup this rare release DVD i own. Stax only wants to convert it to MKV not AVI, so I said OK, i guess i have to convert VOB > MKV > AVI. I started the process, went thru the steps carefully, and when BeSweet runs to begin the encoding, I see these CRC errors: E7: CRC Error.. Stream Error : Sync found after 1117 bytes So far I only see 5 of the errors and no more since, so I suppose it's okay. Should I be concerned with this or just leave it running? Thankyou. Last edited by Kupotek; 13th May 2006 at 20:21. |
14th May 2006, 09:14 | #1097 | Link | |
Hi Stax!
I wonder if StaxRip support (or you are planning to support) .srt subtitles or just VobSub ones Quote:
@b9AcE you can try to overwrite old StaxRip with the new one when Stax release a new version Last edited by sterlina; 14th May 2006 at 09:16. |
14th May 2006, 10:08 | #1098 | Link | ||
Network XXIII
What encoder are you choosing? Quote:
14th May 2006, 10:16 | #1099 | Link | |
TeMa=) team member
Without effort, you can't even pull a fish out of the pond. Without a pond you can't pull it out even with effort. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
