1st January 2006, 15:25 | #282 | Link | |
Happy new year to the community. First release this year is a urgent bug fix release as I've received more then ten bug reports about a weird bug I wasn't able to reproduce. Thanks to everybody for all the feedback, it'll keep me busy for some time.
0.9.1.8 (2006-01-01) Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 1st January 2006 at 16:35. |
1st January 2006, 16:16 | #283 | Link | |||||
@swaaye
I wasn't able to reproduce the freeze issue, maybe you can mail some log files. I've changed auto crop for the next release: Code:
AutoCrop(mode=2,wmultof=4,hmultof=4,samples=10) Quote:
@Aladdin thanks for posting the code, I'll need to work on this stuff. Quote:
@mulrich Latest build allows to add multiple forced subtitles. Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 1st January 2006 at 16:20. |
1st January 2006, 16:47 | #284 | Link |
although i dont use x264 for backups i decided to try it using staxrip new version.
i get audio sync problems when playing the file, tried 4different video files. when i open Staxrip one of the first things i do is to picck the encoder and muxer, i opened Staxrip picked x264 and mp4box and then opened the video file waited for dgindex to do his work, after dgindex finishes the encoder and muxer options are reverted to the default ones that in my case are divx and virtualdubmod, Ricardo |
1st January 2006, 18:08 | #285 | Link | ||
1st January 2006, 21:27 | #286 | Link | |
can i use another muxer instead of mp4box? |
2nd January 2006, 13:48 | #287 | Link | |
*while demuxing, maybe another demuxer can be used, you could config StaxRip to load audio and video with AviSynth and then play the script in a media player to check if the demuxer is the problem. *while audio encoding, StaxRip audio profiles don't handle delay and the StaxRip muxers will notice if the delay wasn't handled and thus handle it, check the command line, you could also use -ota( -d %delay% ) in the audio profile, the muxer wouldn't handle the delay then. *while muxing, check the command line, for most containers there aren't many alternative muxers. *while playback, try different DirectShow filters and try players that don't rely on DirectShow like VlC and mplayer.
2nd January 2006, 13:58 | #288 | Link |
i dunno what staxrip does internally, but mp4box will set 25fps by default when importing a raw video stream. so when you import from raw video with a different fps you need to use the -fps switch
also mp4box handles setting a delay, but this isnt taken into account by many players, so always make sure you correct the delay already while audio encoding
2nd January 2006, 14:04 | #289 | Link | ||
2nd January 2006, 19:30 | #290 | Link |
TeMa=) team member
Location: Universe, Galaxy, Solar System, Earth, Russia, Moscow
About this new x264...How to configure 1st and 2nd passes separately? I have to set decision quality to 1 (fastest) for 1st pass, but not for 2nd pass...
Without effort, you can't even pull a fish out of the pond. Without a pond you can't pull it out even with effort. |
2nd January 2006, 21:13 | #291 | Link |
@LRN
The intermediate concept of the old dialog is to not ideal for novice users, I'm trying to make StaxRip as easy as possible as announced in a posting about a focus shift. What I can do is letting users customize the turbo switches if that aren't too many (5-10) so please tell me what exactly is decision quality. I've seen quite a few people struggle with the StaxRip intermediate concept and the MeGUI turbo/automated concept, I also received quite a few bug reports caused by misconfiguration of the intermediate feature (there aren't verifications for the settings). That's why in the new dialog I'm previewing the command lines of all passes together.
3rd January 2006, 04:20 | #292 | Link |
TeMa=) team member
Look at http://www.mplayerhq.hu/DOCS/HTML/en...feat-x264.html
"Moreover, two passes need not take twice as long as one pass. You can tweak the options in the first pass for higher speed and lower quality. If you choose your options well, you can get a very fast first pass. The resulting quality in the second pass will be slightly lower because size prediction is less accurate, but the quality difference is normally much too small to be visible. Try, for example, adding subq=1:frameref=1 to the first pass x264encopts. Then, on the second pass, use slower, higher-quality options: subq=6:frameref=15:4x4mv:me=3" As i understand, Subpixel Motion Estimation and Max Consecutive B-Frames should be 1 (both) for first pass. As i sad before, in my previous post, it's not so easy to configure x264 for optimal speed/quality.
3rd January 2006, 21:12 | #293 | Link |
Mr. Woof
To interject in this conversation...
I've noticed that using StaxRip I get occasional frames in my encodes that still look interlaced even though the source is FILM...I dont' think I ever saw this in GK. Has anyone else noticed this? If I set the option to deinterlace I don't see this that much, but the source is progressive FILM. Also, is it possible when calculating bitrate from final file size (if DivX is used as the encoder) can you take the calculating function inside StaxRip from the calculator found in the codec config? Last edited by chipzoller; 3rd January 2006 at 21:28. |
4th January 2006, 14:17 | #294 | Link |
TeMa=) team member
I just finished backup of "Cast Away" movie...At the end i got 1064 Mb mp4 file with only video. But! If i keep it in one directory with audio files (ac3, three of them - two language tracks and one audio comment track), it plays video AND ALL 3 audio files simultaneously! Sounds really weird and cool, but that's not what i want, really...Looks like it's Staxrip-mp4box compatibility issue. I should mention, what i used mp4 files for audio input (my first encoding attemt failed, but AAC encoder performed fine, and i got two mp4 AAC tracks, so i kept them as "Calculate size only").
I tried to mix everything manually with YAMB MP4box frontent and got full 1400 Mb mp4 movie without subtitles, with only one audiotrack (there MUST be another audiotrack in this file, but i did not found any way to switch tracks; i use MPC + ffdshow + Haali splitter), and this audio track is not syncronized with video. --------- Yayyyy! I'm really dumb Did'nt noticed "Mux AAC" Damn...
Without effort, you can't even pull a fish out of the pond. Without a pond you can't pull it out even with effort. Last edited by LRN; 4th January 2006 at 16:56. Reason: i'm dumb |
4th January 2006, 18:46 | #295 | Link | ||
@LRN I'll do x264 work shortly.
4th January 2006, 19:11 | #297 | Link | ||
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 4th January 2006 at 19:13. |
5th January 2006, 21:47 | #298 | Link | |
0.9.1.9 (2006-01-05)
6th January 2006, 00:40 | #299 | Link |
Thanks Stax, I'm just starting to use (and appreciate!) the StaxRip tool. Very nice
One problem: it tries to download an old XviD version, 1.1.0beta2. Maybe that needs to be fixed since the 1.1 final release is out. Testing now..
Soulcake. Duck. Mmmm. Good. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
