Old 6th October 2008, 05:59   #2081  |  Link
Ramir Gonzales
Originally Posted by swaaye View Post
Just a heads up: it looks like there was a quality bug in x264 996 so it's probably best to use 999. No command line changes since 996.
http://x264.nl/
commit cc510478de710f86ab400f610b6e075304d902cb r999
Author: Loren Merritt <pengvado@akuvian.org>
Date:   Thu Oct 2 20:57:08 2008 -0600
    rm gtk, avc2avi.
    I don't remember why I allowed a gui into the repository in the first place. There's
    nothing that makes this one special relative to all the other x264 guis.
    avc2avi doesn't compile since we removed the bitstream reader. And avc doesn't belong in avi.
commit 6768543b76ee5ed65d096444fda2bc282b41dd91 r998
Author: Jason Garrett-Glaser <darkshikari@gmail.com>
Date:   Thu Oct 2 18:11:13 2008 -0700
    Resolve quality regression in r996
    Accidentally removed the wrong line of code.  I think this classifies as a "10l".
    Thanks to techouse for initial bug report and skystrife for helping me find it.
commit 65b837fc75bdbabcc34f5e12048c10d77932eee2 r997
Author: Ralf Terdic <contact@jswiff.com>
Date:   Thu Oct 2 08:52:33 2008 -0700
    Fix minor memory leak accidentally added with the addition of b-adapt 2
Just copy the v999 over the v996, all will be well.
Ramir Gonzales is offline
Old 6th October 2008, 10:00   #2082  |  Link
stax76
stax76's Avatar
@RickA
Thanks for the hint, I've uploaded a new beta with rev 999.
stax76 is offline
Old 6th October 2008, 11:03   #2083  |  Link
GrimRe
First off thanks for the amazingly simple to use software
I'm trying to archive my Family Guy dvds. I'm trying with Season 1 to include everything including chapters and subtitles.
Chapters isn't a problem when I use robot4rip but I can never seem to get the subtitles to work properly. If I use StaxRip it creates the .idx file for subtitle and adds it to the container properties. However when I go to transcode the video at the very end it comes up with the error:
                           Muxing
"C:\Program Files (x86)\MKVtoolnix\mkvmerge.exe" -o "D:\dvds\familyguys1\VTS_02_1.mkv" --noaudio --nosubs --default-duration 0:25.000fps "D:\dvds\familyguys1\VTS_02_1_EncoderOutput.264" --language 0:eng --track-name "0:English" "D:\dvds\familyguys1\VTS_02_1 01 en-English 2_0ch 192Kbps DELAY 0ms_AudioOutput.mkv" --language 0:eng -s 0 "D:\dvds\familyguys1\VTS_02_1.idx" --engage keep_bitstream_ar_info
mkvmerge v2.2.0 ('Turn It On Again') built on Mar  4 2008 12:58:13
'D:\dvds\familyguys1\VTS_02_1_EncoderOutput.264': Using the AVC/h.264 ES demultiplexer.
'D:\dvds\familyguys1\VTS_02_1 01 en-English 2_0ch 192Kbps DELAY 0ms_AudioOutput.mkv': Using the Quicktime/MP4 demultiplexer.
'D:\dvds\familyguys1\VTS_02_1.idx': Using the VobSub subtitle reader (SUB file 'D:\dvds\familyguys1\VTS_02_1.sub').
Track 0 of 'D:\dvds\familyguys1\VTS_02_1_EncoderOutput.264': Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 751/576.
'D:\dvds\familyguys1\VTS_02_1_EncoderOutput.264' track 0: Using the MPEG-4 part 10 ES video output module.
'D:\dvds\familyguys1\VTS_02_1 01 en-English 2_0ch 192Kbps DELAY 0ms_AudioOutput.mkv' track 1: Using the AAC output module.
'D:\dvds\familyguys1\VTS_02_1.idx' track 0: Using the VobSub subtitle output module (language: eng).
Warning: 'D:\dvds\familyguys1\VTS_02_1 01 en-English 2_0ch 192Kbps DELAY 0ms_AudioOutput.mkv': A track with the ID 0 was requested but not found in the file. The corresponding option will be ignored.
The file 'D:\dvds\familyguys1\VTS_02_1.mkv' has been opened for writing.
The cue entries (the index) are being written...
Muxing took 5 seconds.
                           Error
MKV muxing failed
The final video still works fine but the subtitles do not. Any ideas?
GrimRe is offline
Old 6th October 2008, 12:04   #2084  |  Link
stax76
stax76's Avatar
@GrimRe
Welcome to the forum. Please try the latest beta and post the diagnostic file if it still fails. How to create the diagnostic file is described in the first post of the bug report thread, the link to this thread is in my signature.
The log file shows your audio file is mkv, is this on purpose? Usually the audio file passed to the muxer is either AAC or AC3. MKV as audio file might not work but if you post the specs of the file using MediaInfo I might be able to fix it. I didn't think somebody would want to add a mkv file as audio source file.
stax76 is offline
Old 6th October 2008, 22:01   #2085  |  Link
meatwad
meatwad's Avatar
Stax, I've been a long time user of staxrip and I must say it's still my favorite. That's why I've been trying to get DGAVCIndexNV to work with it. I was hoping to do a simple renaming of the programs to substitute them for DGAVCIndex and DGDecode.dll. By changing the names of the files I can get staxrip to use DGAVCIndexNV but after it's done making the dga file it reports a mismatch of DGDecode.dll even though I changed and renamed the one in the avisynth plugins directory. Anyway, is there anything I can do with my extremely limited knowledge to get this to work?
Also, I'm using the latest beta and avisynth 2.58r4a. I can easily switch back to 2.57 but I've tested it with both and the results were the same.
Last edited by meatwad; 7th October 2008 at 05:45. Reason: I guess I should post this under requests-- my bad.
meatwad is offline
Old 7th October 2008, 10:25   #2086  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
No.
Neuron2 has to fix this bug. It will not work with StaxRip or MeGUI until he fixed it. Renaming doesn't help like you already saw.
Deinorius is offline
Old 9th October 2008, 04:19   #2087  |  Link
meatwad
meatwad's Avatar
@Deinorius
You're correct, but I'm sure it will be fixed soon. I have faith in Neuron2's abilities.
meatwad is offline
Old 17th October 2008, 14:25   #2088  |  Link
flebber
Practising Schemer
Sorry to ask such a simple question. I was trying to add avisynth filters into staxrip(I have not yet succeeded). Staxrip came up with an unhandled exception when I closed the profiles idalog I was trying to create, as I used [NOISE] as the category now I cannot add noise filters from the add filters dialog to the staxrip box. Is there anyway to fix this ?
I am searching in C:\Documents and Settings\flebber\Local Settings\Application Data\StaxRip but cannot find anything to alter.
Is there a "safe" method to add avisynth filters in ? I found this thread http://forum.doom9.org/showthread.ph...ip+add+filters but that didn't work well it has led to my above error.
PS I am using version 2115
flebber is offline
Old 17th October 2008, 16:13   #2089  |  Link
stax76
stax76's Avatar
Regarding unhandled exceptions please read here.
stax76 is offline
Old 17th October 2008, 22:43   #2090  |  Link
flebber
Practising Schemer
I didn't file a bug report because I created the error trying to add an avisynth filter. It wasn't your fine work that caused the problem.
flebber is offline
Old 18th October 2008, 09:12   #2091  |  Link
SlipGun
I've noticed that all my encodes are slightly longer than the original VOBs (is this a result of the IVTC from 29.97 to 23.976 fps?). While the audio is synced correctly, this throws all my chapters out of sync. How can I work get my audio/video to the original DVD lengths?
SlipGun is offline
Old 18th October 2008, 20:16   #2092  |  Link
lilhobo
are there any size control and determination in this tool? ie say i would like to fit onto one CD, can it determine the bitrate to do so?
lilhobo is offline
Old 19th October 2008, 17:19   #2093  |  Link
Ramir Gonzales
Sure, it's upright in the main window
Old 20th October 2008, 06:29   #2094  |  Link
Ahmed28
I want to convert xvid avi to x264 mkv using staxrip, also I wanna put a sub in the mkv result, how do I accomplish it using just staxrip ?
Thanks
Ahmed28 is offline
Old 20th October 2008, 06:36   #2095  |  Link
flebber
Practising Schemer
Originally Posted by LRN View Post
StaxRip supports avisynth scripts as "filters". It's somewhat annoying, but i think it is necessary, because StaxRip IS NOT an avisynth-based transcoder.
If you need to use some external script in StaxRip, you should add it, in the same way as you do with Deinterlace, Resize and other AviSynth filters.
Few pages back i posted here my own ripped-off variant of seesaw.avs script, adapted for StaxRip.
I found this post, I had just totally screwed up staxrip trying to add filters. Can you point me in the direction of a guide on how to add filters or scipts ?
I basically want to be able to use convolution3d, mipsmooth and fft3dfilter in different instances.
I am using Staxrip 1.1.1.0
In the Guides under Help in Staxrip this link for screencast by ORION and for alex nigma are not workinghttp://www.thecrave.info/walkthrough...ugh/index.html i(File Not Found). and http://alex.nigma.info/2006/how-to-c...amable-mpeg-4s
flebber is offline
Old 20th October 2008, 20:46   #2096  |  Link
lilhobo
i didnt remember seeing it.....all i saw was the default 640x480
i cant convert to HD resolutions?
lilhobo is offline
Old 21st October 2008, 14:49   #2097  |  Link
flebber
Practising Schemer
Finally Figured it new it would be simple. n
# You can add custom categories, filters and parameters here.
[Source]
Automatic  =
MPEG-2     = MPEG2Source("%source_file%")
MPEG-2 Deblocked = MPEG2Source("%source_file%", CPU=6)
AVC        = AVCSource("%source_file%")
AVI        = AVISource(%source_files_comma%,audio=false)
DirectShow = DirectShowSource("%source_file%", audio=false, convertfps=true)
[Crop]
Crop Borders = Crop(%crop_left%,%crop_top%,-%crop_right%,-%crop_bottom%)
[Field]
FieldDeinterlace = FieldDeinterlace()
TomsMoComp = TomsMoComp(-1,5,1)
Yadif      = LoadCplugin("%application:Yadif%") Yadif()
IVTC       = Telecide(guide=1).Decimate()
[Resize]
Soft       = BilinearResize(%target_width%,%target_height%)
Neutral    = BicubicResize(%target_width%,%target_height%,0,0.5)
Sharp      = LanczosResize(%target_width%,%target_height%)
Very Sharp = Lanczos4Resize(%target_width%,%target_height%)
[Noise]
Low        = FluxSmoothST(2)
Medium     = FluxSmoothST(4)
Heavy      = FluxSmoothST(8)
Extreme    = UnDot.Deen()
[Sharpness - Convolution3D]
High	   = Convolution3d (preset="movieHQ")
Low        = Convolution3d (preset="movieLQ")
AnimeHQ    = Convolution3d (preset="animeHQ")
AnimeLQ    = Convolution3d (preset="animeLQ")
vhsBQ      = Convolution3d (preset="vhsBQ")
[Sharpness - MipSmooth]
MovieHQ    = MipSmooth(preset = "movieHQ")
MovieHQ2   = MipSmooth(preset = "movieHQ2")
MovieLQ    = MipSmooth(preset = "movieLQ")
MovieLQ2   = MipSmooth(preset = "movieLQ2")
VHS        = MipSmooth(preset = "VHS")
AnimeHQ    = MipSmooth(preset = "animeHQ")
AnimeLQ    = MipSmooth(preset = "animeLQ")
[FFt3dFilter]
Best(slow) = fft3dfilter(sigma=1.5, bt=5, bw=32, bh=32, ow=16, oh=16, sharpen=0.4)
Mine       = fft3dfilter(sigma=1.8, bt=4, sharpen=0.6)
[RemoveGrain]
Default    = RemoveGrain(mode=2, modeU=2, modeV=2)
Light(safe)= RemoveGrain(mode=5)
Light      = RemoveGrain(mode=5).RemoveGrain(mode=5)
Medium     = RemoveGrain(mode=2).RemoveGrain(mode=2)
Smart      = RemoveGrain(mode=17)
Smart(safe)= RemoveGrain(mode=18)
Unsure     = RemoveGrain(mode=18).RemoveGrain(mode=18)
[Subtitle]
VobSub     = VobSub()
TextSub    = TextSub()
[Audio]
AC3 Source = AudioDub(last, NicAC3Source("%audio_file1%"))
MP123 Source = AudioDub(last, NicMPG123Source("%audio_file1%"))
[Misc]
Convert To YV12 = ConvertToYV12()
flebber is offline
Old 26th October 2008, 11:56   #2098  |  Link
alaxa
excuse me,
how does the macro editor works? I tried building up some macro to recognize audio stream but a simple %eval_vb: (msgbox('aaa'))% fails with syntax error.
thanks,
a.
alaxa is offline
Old 28th October 2008, 02:37   #2099  |  Link
lilhobo
so how do i set it to use CD 650MB or DVD-5 4Gb size?
lilhobo is offline
Old 1st November 2008, 22:26   #2100  |  Link
Ramir Gonzales
Can this program be flagged "abandoned" now, or is there any change it will still get updated before people step away from it ?
gui, h.264, h.265, hevc, mkv, x264, x265
