Old 2nd December 2020, 02:48   #961  |  Link
imhh11
Originally Posted by mczuzlak View Post
Are there any plans to support the Dolby Vision compatible mkv remuxes created by MakeMKV 1.5.3 ?
I wanted to use one as a source to mux it into a bluray iso but tsmuxer failed to load the mkv.
It would be nice to create backups with MakeMKV but still be able to convert back to UHD bluray structure while preserving the Dolby Vision metadata.
I would love that as well but i doubt it can be done without demuxing first
Originally Posted by SeeMoreDigital View Post
Hmmm...
MakeMKV v1.5.3 now converts 2-layer Dolby Vision sources into 1-layer .mkv muxes (primarily for playback with nVidia Shield owners). And previous versions of MakeMKV discarded the secondary Dolby Vision FEL/MEL stream altogether.
If the MakeMKV developers created a build with an .mkv muxer that preserved both Dolby Vision layers (like Mosu's MKVToolNix can), it would then be possible for the open source builds of TSmuxer to easily create 4K UHD Blu-ray compliant muxes. (Dolby TrueHD audio streams without AC3 core excepted).
MakeMKV does not convert dual-layer to single-layer. it does preserve both DV layers
It creates a single track with two layers (BL+EL+RPU) which can be extracted (with yusesope tool) and then can be rebuilt with tsmuxer.
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
imhh11 is offline   Reply With Quote
Old 2nd December 2020, 12:47   #962  |  Link
SeeMoreDigital
SeeMoreDigital's Avatar
Okay yes, for the sake of clarity, MakeMKV merges the two separate (video) tracks found on Dolby Vision encoded 4K UHD Blu-ray discs, into a single video stream.
Now that we have software that can merge these tracks. It would be handy to have software that could separate them too!
Old 2nd December 2020, 13:20   #963  |  Link
imhh11
we have one, I just gave you a link in my last post
Old 5th December 2020, 19:59   #964  |  Link
BloodyRipper
tsMuxeR developer(-ish)
BloodyRipper's Avatar
Due to a rather embarrassing error, only the Mac build was created in today's (2020-12-05) nightlies.
Things should be back to normal in tomorrow's build, which will include a GUI translation to Chinese.
aka xavery at GitHub
Nie poganiaj mnie, bo tracę oddech.
BloodyRipper is offline   Reply With Quote
Old 6th December 2020, 10:43   #965  |  Link
von Suppé
von Suppé's Avatar
I would like to ask again:
For quite some time now, latest tsMuxer's 3D-BD (re-)mux to ISO or BD-folderstructure is not accepted by MakeMKV when importing, returning several errors.
Strange thing is, 3D muxing results from the older tsMuxer version 2.6.15 pass without problems.
Should this be looked into or am I maybe unaware of certain settings?
Old 6th December 2020, 14:30   #966  |  Link
cogira
I have the same problem
cogira is offline   Reply With Quote
Old 6th December 2020, 21:35   #967  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
A .meta file would help.
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
Old 7th December 2020, 10:01   #968  |  Link
von Suppé
von Suppé's Avatar
Would you care to explain what a .meta file is? Do you mean the error log of MakeMKV perhaps?
Edit: Doh... got it. This is the meta from tsMuxer GUI git-bfeee07, remuxing a (mounted) movie-only ISO to movie-only ISO:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --hdmv-descriptors --blu-ray --label="3D remux" --vbr --custom-chapters=00:00:00.000;00:03:55.401;00:06:51.994;00:11:47.706;00:14:29.451;00:18:37.653;00:22:15.834;00:26:51.151;00:30:31.287;00:36:41.364;00:40:48.320;00:44:49.936;00:48:47.797;00:51:16.447;00:54:22.217;00:57:32.657;01:00:31.168;01:04:41.543;01:06:49.045;01:11:01.881;01:16:53.692;01:21:18.037;01:24:30.354;01:28:08.533;01:30:54.157;01:34:14.564;01:37:20.542;01:39:20.203;01:42:40.319;01:46:50.069;01:49:02.661;01:52:18.314;01:57:29.876;02:00:23.841;02:05:41.323;02:07:31.268;02:13:38.466;02:16:21.881;02:19:39.995;02:23:19.799;02:30:12.334 --vbv-len=500 --start-time=524280
V_MPEG4/ISO/MVC, "M:\BDMV\PLAYLIST\00000.mpls", insertSEI, track=4114
V_MPEG4/ISO/AVC, "M:\BDMV\PLAYLIST\00000.mpls", insertSEI, track=4113
A_DTS, "M:\BDMV\PLAYLIST\00000.mpls", track=4352, lang=eng
S_HDMV/PGS, "M:\BDMV\PLAYLIST\00000.mpls", fps=23.976, 3d-plane=0, track=4608, lang=eng
S_HDMV/PGS, "M:\BDMV\PLAYLIST\00000.mpls", fps=23.976, 3d-plane=1, track=4609, lang=nld
Old 7th December 2020, 21:00   #969  |  Link
Emulgator
Emulgator's Avatar
Yes, I meant the .meta generated from tsMuxeR GUI.
track=4114 looks ok for a 3D .mvc dependent view.
I would swap lines, but that is me.
contSPS might be missing
Try
V_MPEG4/ISO/AVC, "M:\BDMV\PLAYLIST\00000.mpls", insertSEI, track=4113, contSPS
V_MPEG4/ISO/MVC, "M:\BDMV\PLAYLIST\00000.mpls", insertSEI, track=4114, contSPS
Forgot if this was needed for demuxing only:
subTrack		Used for combined AVC/MVC tracks only.
TsMuxeR always demultiplexes such tracks into separate AVC and MVC streams.
subtrack=1 defines the AVC part, subtrack=2 defines the MVC part.
Old 7th December 2020, 22:45   #970  |  Link
von Suppé
von Suppé's Avatar
Since day 1 I've been 3D muxing with the MVC stream as first in the list. I've read it to be the right way, ages ago in the old tsMuxer thread.
Of course I tried with H264 as first and it did not make a difference for the MakeMKV acceptance.
This switch is activated by checking the "Continually insert SPS/PPS" box, right? I tried, but switching this off or on also did not make a difference.
Again, ages ago I read that this box should not be checked when muxing 3D.
Never really having thought about this .meta file, your post made me think it maybe was a good idea to compare them from both version 2.6.15 and the latest nightly.
I spotted a difference. With both loading the same ISO, here are the first lines of their meta:
Version 2.6.15
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --vbv-len=500
Latest nightly:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --hdmv-descriptors --blu-ray --vbr --custom-chapters=00:00:00.000 --vbv-len=500
The latest nightly adds "--hdmv-descriptors". I don't know if this can make the difference?
I would love to try muxing without it, but I don't know how to delete that switch using the GUI.
I did notice, when I set the output to "TS muxing" or "M2TS muxing", at the General tab the option "Generate HDMV compatible TS" becomes available. Checking the box on/off results in "--new-audio-pes --hdmv-descriptors" being set or deleted. But for BD ISO or folderstructure it is greyed out.
Is there a way to view/export the whole command-line, working from the GUI?
Old 9th December 2020, 01:41   #971  |  Link
Emulgator
Emulgator's Avatar
Yes, you may use the GUI to create the meta.
Open that .meta in Editor and make your manual changes
Make a .bat, point to the .meta, start the .bat.
The CLI will start using that .meta.
CLI Examples:
All modes A (Track Detection) or B (Demuxing) or C (Muxing) need only a single line .bat file
+++++++  A: Track detection mode  +++++++++++++++++++++++++++++++
(path to\)tsMuxeR.exe <(path to\)input file>
pause
If tsMuxeR is run with only that input file argument
tsMuxeR will assume track detection mode, parse given input file and display found information which can be used to build meta file.
Example
"C:\_PROG\tsMuxeR\tsMuxeR.exe" "T:\BD Ratatouille\RATATOUILLE_DEU\BDMV\STREAM\00002.m2ts"
pause
If you want to inspect more than one stream at once, just add another line into that batch file
"C:\_PROG\tsMuxeR\tsMuxeR.exe" "J:\4_ES\BD RB\x264 V13 RB 1996.264"
"C:\_PROG\tsMuxeR\tsMuxeR.exe" "J:\4_ES\BD RB\V13 RB 1996.ac3"
pause
Again: In track detection mode no .meta file is needed or generated
+++++++  B and C Demuxing/Muxing mode  +++++++++++++++++++++++
Open Editor, make a batch file (plain text file with file extension .bat)
(path to\)tsMuxeR.exe <(path to\)meta file> <(path to\)output file or folder>
Arguments are separated by 1 space.
The <> are meant as delimiters for the full path.
(Full path delimited by "" is only needed for those arguments (.bat file, input files, output files) that reside in different folders than tsMuxeR.exe.)
If tsMuxeR is run with an additional path to a .meta file,
tsMuxeR parses that given .meta file and expects to start a demuxing or muxing process.
If output folder doesn't exist, tsMuxeR will generate one at given location.
"Generate HDMV compatible TS" is mandatory for Blu-ray, so it seems useful that it can not be checked off while opting for Blu-ray muxing.
The greyed-out tickbox shows the tick fixed to active, and this is what I would expect.
Ok, will have to make a 3D test mux soonish to see what MakeMKV finds.
Old 9th December 2020, 10:04   #972  |  Link
von Suppé
von Suppé's Avatar
Thanks for your help, Emulgator.
Hope your examples will steer me to be able and try different things with cli. Will report back.
Cheers
Old 9th December 2020, 13:07   #973  |  Link
Emulgator
Emulgator's Avatar
MIB3_3D ripped via Any (full .ssif):
MIB3_3D ripped via Make (.ssif.smap):
00800.mpls thrown on tsMuxeR GUI 2020-12-08 for Demux-Remux:
After 0,1% (some 35MB) tsMuxeR comes up with Error -1 "F".
Found BD folder structure, inside like ~35MB 0000.m2ts Main view + 3x Audio +3x Subs playable, ~8MB 00001.m2ts dependent view. mvc alone.
2.6.12 does that too, but can at least write the Error -1 "Fehlerhafter Parameter".
Individual streams demuxed following 00800.mpls by DGDemux46: The same.
No .ssif. If I specify .ssif in GUI trying to type extension while .m2ts radiobutten, radiobutton falls back to .mts.
Now having BD_Rebuilder 0.61.18 running a Main Movie on BD-R 25GB FRIM Re-encode.
Lets see what the BD_RB .meta says.
Old 9th December 2020, 13:18   #974  |  Link
von Suppé
von Suppé's Avatar
As a quick response to MIB3_3D, wasn't this one of those "problematic" discs in terms of demuxing?
To rule certain things out, maybe better to try with another title?
[EDIT] Well, finaly managed to get this working pfffff. Took half a bottle of single malt & almost an ambulance...
First off, hopelessly having lost track, can you please confirm what encodings must be used for creating the .bat and .meta file? UTF-8 or ANSI? And when I already opened a file in notepad, how can I tell what encoding is being used?
removing the "--hdmv-descriptors" from the .meta file did not make the difference I was hoping for.
Old 9th December 2020, 16:14   #975  |  Link
Emulgator
Emulgator's Avatar
Hrm. I had started this morning.
BD_RB finished ok.
Found the BD_RB .meta, had muxed all subs into 3dplane 1.
Should have been into 1,2,3 (says DGDemux)
MakeMKV finds faults, that confirms your findings.
MakeMKV v1.15.3 win(x64-release) gestartet
Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als C:\Users\l/MakeMKV_log.txt
Lade aktuelle SDF in C:\Users\l/.MakeMKV ...
Öffne Dateien auf Festplatte in J:/8_DISC_REMUX/BD_MIB3_3D_Any_BD-RB/MEN_IN_BLACK_3
AACS-Verzeichnis nicht vorhanden. Es wird angenommen, dass die Disk unverschlüsselt ist
Die Quell-Datei '00000.clpi' ist defekt oder ungültig bei Offset #1100. Es wird versucht, dies zu umgehen
Die Quell-Datei '00000.clpi' ist defekt oder ungültig bei Offset #1101. Es wird versucht, dies zu umgehen
Die Quell-Datei '00000.clpi' ist defekt oder ungültig bei Offset #1102. Es wird versucht, dies zu umgehen
Titel #00001.mpls wurde übersprungen
Titel #00000.m2ts wurde übersprungen
Das Öffnen der Disk schlug fehl.
BDEdit 0,49: 1100,1101,1102 are the 3 audio streams.
No fault message.
MPC-HC plays the mux with audio and subs, 2D tested
3D untested for now, need to burn to BD-RE25 and use the chain Oppo 205 -> LG OLED55E6V
Old 9th December 2020, 16:29   #976  |  Link
von Suppé
von Suppé's Avatar
Here is what MakeMKV says about importing a mounted iso from latest tsMuxer:
Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als C:\Users\***/MakeMKV_log.txt
Direkter Zugriffsmodus wird verwendet
DEBUG: Code 0 at <)@bC=_v7LB*WJKP:121262302
DEBUG: Code 0 at j_2*gIk0SDRBlYdA[&(.:29397771
DEBUG: Code 0 at )|-Dt0UfP<I#NHOVBsLn:121262348
DEBUG: Code 0 at )|-Dt0UfP<I#NHOVBsLn:121262210
DEBUG: Code 0 at )|-Dt0UfP<I#NHOVBsLn:121261773
DEBUG: Code 0 at sB1Ak-Qr63XhpI9v@LaQ:213136769
DEBUG: Code 0 at [`wp1Bv4=]`if>k%a-:121262049
DEBUG: Code 0 at [`wp1Bv4=]`if>k%a-:121262256
Dekodierung der Audio- und Videodaten von Titel #0 ist fehlgeschlagen. Ungültiger Mux oder interner Fehler. Der Titel wurde übersprungen.
DEBUG: Code 0 at GHaY;DP.*KMTFuAQ:213131387
DEBUG: Code 0 at G]}%-0xK4D#J5U5:29401934
DEBUG: Code 0 at *0,;c\PL0:J=9lq%:213116437
Titel #00000.mpls wurde übersprungen
Mind, that the iso's seem ok and play on pc and via NFS on my mediaplayers.
I don't use the iso's for burning. But I do use them sometimes to create a 3D-MKV.
Old 9th December 2020, 16:34   #977  |  Link
mikahawkins1
Private or not its good work. I will give you that.
mikahawkins1 is offline   Reply With Quote
Old 9th December 2020, 17:20   #978  |  Link
von Suppé
von Suppé's Avatar
I'm not sure I understand your post. If you mean the language in the code box, my apologies. I did this so it may be easier to read for Emulgator, who obviously uses german.
In english:
MakeMKV v1.15.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\***/MakeMKV_log.txt
Using direct disc access mode
AACS directory not present, assuming unencrypted disc
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
Title #00000.mpls was skipped
Title #00000.m2ts was skipped
Failed to open disc
Old 9th December 2020, 17:29   #979  |  Link
Emulgator
Emulgator's Avatar
3D Folder Mux using BD_RB's built-in tsMuxer4k (w32-nightly-2020-09-25--02-25-44, 32db2aa) tested successfully, burned to BD-RE25.
tsMuxer hasn't muxed .ssif, just all streams .avc. + mvc + 3x Audio + 3x Subs into 00000.m2ts
Playback Chain BD-RE25 -> Oppo 205 -> LG OLED55E6V plays it as 3D, no complaints.
Well, that is Oppo which might play even non-standard mux.
For nitpicking standalones I will have to throw that at a Panasonic BDT-110 at the weekend.
And I haven't tested muxing into .iso.
[EDIT]
...First off, hopelessly having lost track, can you please confirm what encodings must be used for creating the .bat and .meta file? UTF-8 or ANSI? And when I already opened a file in notepad, how can I tell what encoding is being used?
I use notepad++, this shows character encoding and allows to move between different character encodings.
tsMuxeR can be run in one of three modes.
A: Track detection mode or B: Muxing mode or C: Demuxing mode.
Only Track detection mode (see below) needs no .meta file.
To control any demuxing/muxing on runtime you have to generate a .meta file, either by hand or using the tsMuxeR GUI
This is a plain text file in ANSI coding (from 2.6.16 Unicode is possible too) and MUST have extension .meta.
tsMuxeR GUI 1.10.6 will generate .meta files with LF linebreaks,
tsMuxeR GUI 2.6.12 will generate .meta files with LF+CR linebreaks,
To be safe while generating .meta manually I suggest to use LF+CR.
The tsMuxeR GUI generates .meta file before muxing.
The tsMuxeR GUI is only there to write such .meta file, unfortunately it can not read any .meta file.
(You may use that feature to test-run as follows:
Use the GUI, save the .meta file from the GUI, let it test-mux, re-edit that .meta file, then run the CLI on that .meta)
.bat encoding: I suggest ANSI, haven't tested Unicode.
Old 10th December 2020, 09:18   #980  |  Link
von Suppé
von Suppé's Avatar
Ok, sticking to ANSI seems to work all the time. Thanks for the Notepad++ suggestion.
[EDIT] Just minutes ago I learned there was a new MakeMKV version out. This one also returns errors on 3D ISO import. But, apparently MakeMKV now has found a way to "get around" the errors and I was taken to the next screen to make a 3D mkv.
Of course I will test this further, but it's an improvement nevertheless from the MakeMKV guys.
For those who are interested here's the log. I could only put it partially as it was too long.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626056192, attempting to work around
DEBUG: Code 266257 at h*CYV;I&#^aU54?q0v+l:29395563
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626136064, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626222080, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626430976, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626516992, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626596864, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626682880, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626842624, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2626928640, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2627088384, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2627254272, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 2627334144, attempting to work around
DEBUG: Code 266257 at... etc etc this goes on and on and on.....
last two lines are:
File 00000.mpls was added as title #0
Operation successfully completed
