#581 | Link | |
Now, I wonder, why I can't upload no chapters? I have an account and I'm logged in and when I try to upload it asks me if everything is correct, I click to confirm it is and... nothing happens. Nothing, nada. Can you please confirm it works? Maybe my account has some problem or something? |
#585 | Link |
Matroska find' ich toll
chapterEditor(cE) rev1.23 is available.
Windows Linux Important bugfix for the chapter database because the upload no longer worked. Code:
Change chapterEditor added & fixed * improved # changed % rev1.23 2020-05-13 // chapterEditor & Support for BSPlayer .chf files # OGG/OGM.txt files from ChapterDB Webside - "Next line" is only displayed with one character // Matroska Chapters * Missing translation for "Edition entry" - when loading simple chapter files - new Disc2mkv chapters - Multi chapters // Multi chapters * insert chapters after the selected chapter does not work if there is no next chapter (only Matroska) // Chapter database * Uploading chapters no longer worked @tormento I have started to implement multi selection of chapters but it is not so easy and not included in this rev. |
#586 | Link |
Thanks!! I just tested it and it is working well now.
Edit: I want to request something regarding the chapter database. Is it possible you could allow us to choose more than one language for the chapter? I have some chapters with multiple languages but I can only pick one when uploading them. Thanks! Last edited by darksen; 13th May 2020 at 20:22. |
#587 | Link |
Hi darksen
Many thanks for uploading the Avengers chapters. Multiple languages for the chapters DB I don't know if this so easy possible. I will have a look but to change the database design is maybe not possible. |
#589 | Link |
Yeah, that causes by a translation(used only one time at start if the cE language is not german) which uses Chapter, but in the combo-box list the entry use chapter.
What do you prefer? I can change the entries from the combo-box list. |
#590 | Link | |
Acid fr0g
To me, Chapter (and translations) is ok.
@turment on Telegram |
#593 | Link |
Hi tormento
I have not much time currently to work on cE, but here is a Windows 1.24 branch for testing. The chapter names in the combo-box have now capital letters. |
#595 | Link |
I've been using cE to remux some Blu-rays and DVDs and so far so good but there are some things I would like to request.
1- An option to hide the duplicate entries/playlists would be great. There were some times where there have been two or more playlists that pointed to the same file/s (m2ts) so the duration and the tracks where exactly the same, in those cases would be great if cE could hide all but one of them and only show that one. There are some cases where the segments differ (like in Disney's Blu-rays where they combine different segments according to the language one chooses or multi cut releases) and in those cases cE should obviously show all those playlists. 2- An option to automatically clean the temp folders after remuxing. This mostly applies to DVD2mkv as cE copies the entire files to the temp folder to process, but would also be handy for BD2mkv as I for one don't have any use for the job files and the other stuff. 3- Automatically replace illegal characters from the filename when remuxing. Otherwise we get errors and everything "hangs" until we close and reopen cE. Like if (in Windows) we put "AAAAA: AAAA BBBBB" as the filename and start remuxing the application will show an error on the log and, after finishing the batch, cE wouldn't start any other operation, all of this because it couldn't create the file with the ":" character on the filename. I think I had one additional request but I forgot lol. Thanks for all your work! |
#596 | Link |
Hi darksen
1.) That's maybe not so easy for me. To find all the correct mpls files I use the output of eac3to which selects only the important mpls titles. If MTX is the analysis part in the chain then all mpls files are shown. I have not much knowledge about the index.bdmv to parse it by my self. I personally trust eac3to fully. Sometimes there are duplicated mpls titles and one of them have chapters and the other not, I know. You can send me a chunk of the disc if you like. You can use my DiscShare tool for that. 2.) Ok, I will think about it. Could be useful. 3.) <-- fixed Oops, that's an ugly bug, I will fix it. The strange thing is that MTX does its job as if everything is OK(sends progress numbers and reported all done fine), but there isn't really an output file. Last edited by hubblec4; 25th June 2020 at 01:05. |
#597 | Link | |
#598 | Link |
Hi darksen
Here is a new test rev1.24 branch (Windows exe only). The fix of point 3. is included and also the new feature delete temp folder (2.). Code:
Automatically delete temp folder (settings) - MKV file must not be created in the temp folder - if there were errors when muxing, the temp folder is not deleted - Gray state of the checkbox: the temp folder is only deleted if there was no warning You can set a minimum of chapters(settings) for a playlist, this should hide chapterless playlists. |
#599 | Link |
Thank you hubblec4, I tested it and everything is working great.
Just one thing, I saw you now don't allow special chars on the "file name" box but we still can input double quotes (") which -at least in Windows- are invalid for filenames. Can you please also add that character to the blacklist? |
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag |
