#7941 | Link | |
Broadcast Encoder
![]() They're indeed in Dolby Vision with the HLG profile, so BT2020nc HLG HDR 4:2:0 10bit planar in H.265. Too bad for the VFR stuff which mobiles seem to love and everyone else in the world hates... (especially us, working in broadcast!) I'm not in the edit room in which I have an HDR monitor and scope, so I can't tell you exactly how many nits there actually are, but Apple claims to reach 699 nits... I think they're way too many for such a tiny sensor. From a very quick analysis, it looks like it's more or less 300 nits, which, for a mobile phone, looks quite alright. For the records: this is from a colleague of mine who bought it, I actually went for a Google Pixel 5 in early November.
Broadcast Encoder Avisynth memes Videotek - Audacity XP LUT Collection - FFAStrans SafeColorLimiter - AAA Last edited by FranceBB; 7th January 2021 at 10:18. |
#7943 | Link |
Because the Yuuki mod appears to be well maintained, I tried to download and build this one alternatively in an interactive shell in MABS. Unfortunately, in contrast to the original x265 git, this modified fork apparently needs Ruby. A compatible version was found in the MSYS2 installation of MABS (2.7.0; minimum required is 1.8.0); but several include directories were missing, so cmake halted. I guess I could make it work if I knew where to include which shell variable exports?
#7944 | Link |
結城有紀
>tree /f D:\dev\x265-Yuuki-Asuna\include D:\DEV\X265-YUUKI-ASUNA\INCLUDE │ lsmash.h │ ├─avisynth │ │ avisynth.h │ │ avisynth_c.h │ │ │ └─avs │ alignment.h │ capi.h │ config.h │ cpuid.h │ minmax.h │ posix.h │ types.h │ win.h │ └─vapoursynth VapourSynth.h VSHelper.h VSScript.h For msvc multi lib build you need to -DLSMASH_SOURCE_DIR=../../x265-Yuuki-Asuna/include -DEXTRA_LINK_FLAGS="/LIBPATH:../../../x265-Yuuki-Asuna/lib-msvc /LIBPATH:.." something like that. For gcc you just compile and make install dependencies into system directories. That includes ffmpeg, avisynth (header only), vapoursynth(header only), lsmash. Ruby script was to compose version number, so it's not absolute necessary and can be replaced by you own code to produce your own version number. I use Ruby because I'm a Ruby developer. It may not be easy to use yuuki mod in mabs due to extra libraries being linked. |
#7945 | Link | |
One hurdle after another ... the first one looked rather low to me, as a layman:
#7948 | Link |
結城有紀
That's weird. I'm getting a similar error but cmake did generate all the project files without any problem.
-- Found Nasm 2.15.05 to build assembly primitives -- Could NOT find Ruby (missing: Ruby_LIBRARY) (found suitable version "2.7.1", minimum required is "1.8.0") -- x265 version 3.4+13-g729a838d3+38 |
#7949 | Link |
So maybe the reason is somewhere else, like the cmake command line may need more explicit parameters than the vanilla x265 multilib configuration.
... -- Found nasm: E:/MABS/msys64/mingw64/bin/nasm.exe (found version "2.15.05") -- Found Nasm 2.15.05 to build assembly primitives CMake Deprecation Warning at dynamicHDR10/CMakeLists.txt:13 (cmake_minimum_required): Compatibility with CMake < 2.8.12 will be removed from a future version of CMake. Update the VERSION argument <min> value or use a ...<max> suffix to tell CMake that the project does not need compatibility with older versions. -- Found Git: E:/MABS/msys64/usr/bin/git.exe (found version "2.30.0") -- Could NOT find Ruby (missing: Ruby_INCLUDE_DIR Ruby_LIBRARY Ruby_CONFIG_INCLUDE_DIR) (found suitable version "2.7.2", minimum required is "1.8.0") -- x265 Release Version -- The ASM_NASM compiler identification is NASM -- Found assembler: E:/MABS/msys64/mingw64/bin/nasm.exe -- Looking for strtok_r -- Looking for strtok_r - found CMake Error at CMakeLists.txt:637 (list): list GET given empty list CMake Error at CMakeLists.txt:638 (list): list GET given empty list -- Configuring incomplete, errors occurred! See also "E:/MABS/x265-Yuuki-Asuna-Yuuki/build/msys64_hdr10_ml/12bit/CMakeFiles/CMakeOutput.log". See also "E:/MABS/x265-Yuuki-Asuna-Yuuki/build/msys64_hdr10_ml/12bit/CMakeFiles/CMakeError.log". make: *** No targets specified and no makefile found. Stop. cp: cannot stat 'libx265.a': No such file or directory make: *** No rule to make target 'clean-generated'. Stop. |
#7950 | Link |
結城有紀
Please open an issue ticket.
EDIT: Actually, I think you are on the wrong branch. Please switch to Asuna branch to test. Yuuki branch is not ready yet because 3.5 is not ready yet. As soon as 3.5 is tagged I'm going to revise the version generation code, which should solve the issue you are seeing.
Projects x265 - Yuuki-Asuna-mod Download / GitHub TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median Last edited by MeteorRain; 11th January 2021 at 18:40. |
#7951 | Link |
![]() The Asuna branch passed. PS: OK, adding a few parameters of the modification may break the attempt, e.g. L-SMASH headers need to be found if I want to enable MP4 output... Seems I could create a build with AVS and VPY input and MKV output, yet without LAVF input and without MP4 output. And with unknown version. To be tested... Works with AviSynth input and MKV output. Last edited by LigH; 12th January 2021 at 13:51. |
#7952 | Link |
結城有紀
FYI: MKV output is not supported and is provided as best effort because one of my friends actively uses it. I was thinking maybe I should add a warning message saying it's unsupported.
If possible, please try to integrate l-smash using the flags above (post #7944). |
#7953 | Link |
Your repo does not provide an include directory, so I tried to configure the cmake flags to use the liblsmash git directory which is retrieved by MABS when building all its projects, up to ffmpeg:
-DENABLE_LSMASH=ON -DLSMASH_SOURCE_DIR=/build/liblsmash-git/ Configuring finished, make started ... all these NASM warnings are a PITA ... hmm, no. Obviously I have no clue how to point to the lsmash.h file so that it is found: Code:
In file included from F:/MABS/x265-Yuuki-Asuna-Asuna/source/output/output.cpp:44: F:/MABS/x265-Yuuki-Asuna-Asuna/source/output/mp4.h:8:10: fatal error: lsmash.h: No such file or directory 8 | #include <lsmash.h> | ^~~~~~~~~~ compilation terminated. Code:
CMake Warning: Manually-specified variables were not used by the project: LSMASH_SOURCE_DIR Next hurdle: I guess MABS used liblsmash somewhere but did not make and install it separately, so it is not a registered package. Code:
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -llsmash Meh. Did not help. Without explicit source dir it doesn't find the header, with it it can't link the library. "It's complicated"... Last edited by LigH; 12th January 2021 at 22:13. |
#7954 | Link |
結城有紀
Ooooh you are using GCC.
>make install-lib install -d /mingw64/include install -m 644 ./lsmash.h /mingw64/include install -d /mingw64/lib/pkgconfig install -m 644 liblsmash.pc /mingw64/lib/pkgconfig install -m 644 liblsmash.a /mingw64/lib Try this and see if pkg-config gets you the command line. Code:
pkg-config --libs liblsmash
Projects x265 - Yuuki-Asuna-mod Download / GitHub TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median Last edited by MeteorRain; 13th January 2021 at 05:57. |
#7955 | Link |
Yes, the media-autobuild suite is based on MSYS2, MinGW, and usually GCC (could use clang if configured). And I even run the interactive shell instead of patching the automated build scripts. So I mostly profit from MABS keeping MSYS2/MinGW and GCC and all projects linked into ffmpeg up-to-date, before sometimes also experimenting interactively.
Using ./configure without extra parameters, it gets installed into /usr/local ... I guess I should add a parameter to change the prefix, because MABS uses /local64 (or /local32) as target directories. OK, MABS requires e.g. ./configure --prefix="/local64" to install the header and library where the packages are expected. Compilation seems to be successful. |
#7956 | Link |
Last missing puzzle piece: Linking issues with libav libraries ... but ffmpeg had been built before and has been found by the compiler. So the reason must be in a different magnitude.
[ 96%] Linking CXX executable x265.exe F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x11): undefined reference to `avcodec_free_context' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x1a): undefined reference to `avformat_close_input' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x19d): undefined reference to `av_init_packet' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x1c0): undefined reference to `avcodec_receive_frame' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x1d8): undefined reference to `av_read_frame' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x1f4): undefined reference to `av_packet_unref' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x204): undefined reference to `av_init_packet' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x226): undefined reference to `avcodec_send_packet' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x23d): undefined reference to `avcodec_receive_frame' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x2a4): undefined reference to `av_packet_unref' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x2b8): undefined reference to `av_packet_unref' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x4aa): undefined reference to `avcodec_find_decoder' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x4ba): undefined reference to `avcodec_alloc_context3' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x4d3): undefined reference to `avcodec_parameters_to_context' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x4e7): undefined reference to `avcodec_open2' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x5ad): undefined reference to `av_packet_unref' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x60c): undefined reference to `av_frame_alloc' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x62e): undefined reference to `avformat_open_input' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x64b): undefined reference to `avformat_find_stream_info' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x6c9): undefined reference to `avcodec_find_decoder' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x6d8): undefined reference to `avcodec_alloc_context3' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x6f4): undefined reference to `avcodec_parameters_to_context' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x707): undefined reference to `avcodec_open2' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x72c): undefined reference to `av_dict_set' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x73f): undefined reference to `avcodec_open2' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x761): undefined reference to `av_dict_free' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x82b): undefined reference to `av_pix_fmt_desc_get' F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x2c): undefined reference to `av_frame_free' collect2.exe: error: ld returned 1 exit status |
#7958 | Link |
Undefined reference usually means that symbol is not reachable. For example, there is no library with such names supplied to the linker. Check generated build files if all needed ffmpeg libs are actually provided for linking.
#7960 | Link | |
Software Developer
![]() Join Date: Jun 2005
If a C/C++ application depends on library 'XYZ', the you will need to do two things:
Of course you will need to build library 'XYZ' before you build your "main" application, because otherwise the required library file libXYZ.a (the "build file") has not been created yet ![]() Quote:
(If you try to link against a library, but the linker couldn't find the requested library file, it would be a different error message) Another "fun" thing needs to be considered: Libraries can be compiled as either a "static" library (.a) or a "shared" library (.dll). Specifically on Windows, the actual symbol names differ between the "static" and "shared" libraries! Usually the header files support both variants, via #ifdef's, but default often is the "shared" variant. So, a special #define needs to be set, at compile-time, if you intend to link against the "static" library. Could also be the other way around tough ![]()
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 15th January 2021 at 01:06. |
