Old 20th December 2020, 21:06   #7921  |  Link
Patman
Patman's Avatar
Originally Posted by quietvoid View Post
Revert commit d926c02/606265a, "Fix version information reporting for x265 git archival"
There might be a fix getting pushed sooner or later.
Barough compiled with the latest commit. Maybe the version.txt was pimped up by him
Tools for StaxRip | x264 - x265
Patman is offline   Reply With Quote
Old 21st December 2020, 02:42   #7922  |  Link
Barough
Barough's Avatar
Nah, i haven't done anything.
Old 21st December 2020, 20:05   #7923  |  Link
GrampaD
GrampaD
GrampaD's Avatar
Originally Posted by HolyWu View Post
x265-3.2.1+1
x265-3.2.1+1 (UPX packed)
x265 [info]: HEVC encoder version 3.2.1+1-b5c86a64bbbe
x265 [info]: build info [Windows][Clang 9.0.0][64 bit] 8bit+10bit+12bit
x265 [info]: (lsmash 2.16.1)
x265 [info]: (libavformat 58.29.100)
x265 [info]: (libavcodec  58.54.100)
x265 [info]: (libavutil   56.31.100)
I have the same version of the codec, my source is MacPorts:
~> which x265
/opt/local/bin/x265
...But it's not showing 10-bit support:
~> x265 -V
x265 [info]: build info [Mac OS X][clang 11.0.0][64 bit] 8bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
...Is it because my hardware won't support 10-bit color? Will MacBook Pros EVER support 10-bit color?
Thanx in advance for answering
GrampaD is offline   Reply With Quote
Old 21st December 2020, 20:23   #7924  |  Link
sneaker_ger
It's not about your hardware. "Your" x265 binary simply wasn't compiled with 10 bit support. You have to download a different binary or compile one yourself.
Old 21st December 2020, 21:42   #7925  |  Link
qyot27
qyot27's Avatar
Related:
https://trac.macports.org/ticket/59860
qyot27 is online now   Reply With Quote
Old 22nd December 2020, 07:16   #7926  |  Link
LigH
LigH's Avatar
Originally Posted by LigH View Post
The media-autobuild suite supports custom patches; unfortunately, I am not experienced enough to create them from differences between forks. But if anyone here could help making them available from Yuuki-Asuna and DJATOM mods, it might be possible to build fresh modified builds conveniently.
Can anyone help me creating diff patches out of their current repos?
New German Gleitz board
Old 22nd December 2020, 14:18   #7927  |  Link
quietvoid
As in on top of both master branches?
You can just add a remote to your x265_git repo and do a diff on the branches:
git clone https://bitbucket.org/multicoreware/x265_git.git
cd x265_git
git remote add x265-Yuuki-Asuna https://github.com/msg7086/x265-Yuuki-Asuna.git
git remote update
# For example if you want to use the Yuuki branch
git diff origin/master x265-Yuuki-Asuna/Yuuki > x265_git-master-Yuuki-diff.patch
And you have a patch (that may be outdated in this case).
The same workflow should work for DJATOM's repo.
You'd have the origin remote (which has x265_git's branches) and whichever other remote repos you add.
quietvoid is online now   Reply With Quote
Old 23rd December 2020, 11:14   #7928  |  Link
stax76
stax76's Avatar
@Barough
Do you also have a MediaFire folder for your builds?
I've created a wiki page showing which builds and mods exist.
Old 23rd December 2020, 12:27   #7929  |  Link
Barough
Barough's Avatar
Originally Posted by stax76 View Post
@Barough
@stax76
I'll PM you.
Old 23rd December 2020, 13:23   #7930  |  Link
stax76
stax76's Avatar
Originally Posted by Barough View Post
@stax76
I'll PM you.
I've private messages disabled.
But my mail address is on my GitHub profile.
Old 23rd December 2020, 13:37   #7931  |  Link
Barough
Barough's Avatar
I'll have a look there when i get bk home
[EDIT]
Sent you a email
Old 26th December 2020, 20:10   #7932  |  Link
Kurogane
I'm trying to figure out why pmode give me this warning
x265 [warning]: Limit reference options 2 and 3 are not supported with pmode. Disabling limit reference
I'm using this basic config
--preset slow --crf 18.0 --profile main10 --output-depth 10 --pmode
When i use another preset than slow not give me this warning.
I'm using 3.4+9-g1fb7c7960
Kurogane is offline   Reply With Quote
Old 28th December 2020, 22:51   #7933  |  Link
benwaggoner
You can see here that Limit Refs 3 is used in presets 2-6 only:
https://x265.readthedocs.io/en/master/presets.html
Ben Waggoner
My Compression Book
Old 30th December 2020, 21:37   #7934  |  Link
Barough
Barough's Avatar
x265 v3.4+35-772bb4c84 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.2.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/Release_3.5
Old 2nd January 2021, 03:47   #7935  |  Link
Kurogane
I tested in all profiles and only the one give me this error is "slow".
Old 2nd January 2021, 03:53   #7936  |  Link
Greenhorn
The table is out-of-date/wrong. Limit-refs 1 is only used on "Slow" these days. Everything else uses 3 (slower, medium and lower) or none (veryslow/placebo.)
@kurogane: it's just saying that a setting used by the preset is incompatible with pmode. It should probably be setting it to "1" instead of disabling it entirely, but you can use both features and the slow preset all together just by setting --preset slow --limit-refs 1 --pmode.
Greenhorn is offline   Reply With Quote
Old 2nd January 2021, 15:04   #7937  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by Greenhorn View Post
The table is out-of-date/wrong. Limit-refs 3 is only used on "Slow" these days. Everything else uses 3 (slower, medium and lower) or none (veryslow/placebo.)
--preset slower applies --limit-refs 1. I'm using it right now in my encodes and I don't have any separate --limit-refs call. The info section shows this:
x265 [info]: References / ref-limit cu / depth : 4 / off / on
Old 2nd January 2021, 18:55   #7938  |  Link
Greenhorn
Typo in my post. Woops.
Old 6th January 2021, 04:23   #7939  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
For those of you that use AVID Media Composer, from version 2020.12 it's possible to link and edit H.265 files. Considering that H.265 was released more than 8 years ago, it's about time, AVID! They should have done this long time ago!! What took them so long...?! -.- Still, habemus H.265 import support at last...
Old 6th January 2021, 23:37   #7940  |  Link
Barough
Barough's Avatar
x265 v3.4+36-5239276dd (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.2.0)
